Can this plugin work with another RGBW device
haavarda
Re: Can this plugin work with another RGBW device
Post by haavarda »
Hi Mike.
Here is the info for my devices:
Master:
  Script                          address : 72
batteryLevel : None
brightness : 100
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : zwColorDimmerType
displayStateImageSel : DimmerOn
displayStateValRaw : 100
displayStateValUi : 100
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 975827608
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          SupportsBatteryLevel : false (bool)
          SupportsEnergyMeter : false (bool)
          SupportsEnergyMeterCurPower : false (bool)
          SupportsEnergyMeterReset : false (bool)
          SupportsOnState : false (bool)
          SupportsSensorValue : false (bool)
          SupportsStatusRequest : true (bool)
          address : 72 (integer)
          propsPushTickler : 39 (string)
          tempAlwaysFalse : false (bool)
          userConfigVal001 : 80 (integer)
          userConfigVal002 : 16 (integer)
          userPollAfterActivity : true (bool)
          userPollInterval : 0 (integer)
          userPollingEnabled : true (bool)
          userWakeInterval : 60 (integer)
          zwAppVersMajor : 1 (integer)
          zwAppVersMinor : 5 (integer)
          zwAssociationsMap : (dict)
               g1 : (list)
                    Item : 1 (integer)
          zwAssociationsMapStr : 1:[1] (string)
          zwClassCmdBase : 38 (integer)
          zwClassCmdMap : (dict)
               c112 : 1 (integer)
               c114 : 1 (integer)
               c115 : 1 (integer)
               c122 : 1 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c38 : 1 (integer)
               c39 : 1 (integer)
               c51 : 1 (integer)
               c89 : 1 (integer)
               c90 : 1 (integer)
               c94 : 1 (integer)
               c96 : 2 (integer)
          zwClassCmdMapStr : 20v1 60v2 73v1 85v1 26v1 27v1 70v1 72v1 33v1 5Ev1 59v1 5Av1 7Av1 86v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 17 (integer)
               Item : 1 (integer)
          zwClassInstanceCountMap : (dict)
          zwClassInstanceCountMapStr : - none - (string)
          zwClassName : Dimmable Power Switch (string)
          zwConfigVals : (dict)
               p1 : 80 (integer)
               p2 : 16 (integer)
          zwConfigValsStr : 1:80 2:16 (string)
          zwDevSubIndex : 0 (integer)
          zwEndpointClassMap : (dict)
               e1 : (list)
                    Item : 38 (integer)
                    Item : 5 (integer)
          zwEndpointClassMapStr : 1:[26 05] (string)
          zwEndpointDevTypeMap : (dict)
               e1 : (list)
                    Item : 17 (integer)
                    Item : 1 (integer)
          zwEndpointDevTypeMapStr : 1:(11 : 01) (string)
          zwFeatureListStr : routing, beaming (string)
          zwLibType : 3 (integer)
          zwManufactureId : 305 (integer)
          zwManufactureName : Zipato (string)
          zwMeterSubTypeFlags : 0 (integer)
          zwMeterSupportsReset : false (bool)
          zwMeterType : 0 (integer)
          zwModelDefnVers : 1 (integer)
          zwModelId : 131074 (integer)
          zwModelName : RGBW LED Bulb (string)
          zwNodeNeighbors : (list)
               Item : 2 (integer)
               Item : 4 (integer)
               Item : 6 (integer)
               Item : 7 (integer)
               Item : 8 (integer)
               Item : 10 (integer)
               Item : 11 (integer)
               Item : 12 (integer)
               Item : 13 (integer)
               Item : 14 (integer)
               Item : 15 (integer)
               Item : 17 (integer)
               Item : 18 (integer)
               Item : 19 (integer)
               Item : 21 (integer)
               Item : 22 (integer)
               Item : 23 (integer)
               Item : 24 (integer)
               Item : 26 (integer)
               Item : 31 (integer)
               Item : 45 (integer)
               Item : 46 (integer)
               Item : 47 (integer)
               Item : 48 (integer)
               Item : 55 (integer)
               Item : 65 (integer)
               Item : 71 (integer)
          zwNodeNeighborsStr : 2, 4, 6, 7, 8, 10, 11, 12, 13, 14, 15, 17, 18, 19, 21, 22, 23, 24, 26, 31, 45, 46, 47, 48, 55, 65, 71 (string)
          zwProtoVersMajor : 3 (integer)
          zwProtoVersMinor : 83 (integer)
          zwShowMainUI : true (bool)
          zwShowPollingUI : true (bool)
          zwShowWakeIntervalUI : false (bool)
          zwWakeInterval : 0 (integer)
lastChanged : 2015-10-20 20:16:35
ledStates : []
model : RGBW LED Bulb
name : Lys - Bulb Hall
onBrightensToDefaultToggle : False
onBrightensToLast : True
onState : True
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
     brightnessLevel : 100 (integer)
     onOffState : on (on/off bool)
subModel : Mulitlevel Switch
supportsAllOff : False
supportsStatusRequest : True
version : 0
Slave:
 Script                          address : 72
batteryLevel : None
brightness : 0
configured : True
description :
deviceTypeId : zwDimmerType
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
errorState :
          zwDevEndPoint : 1 (integer)
          zwDevSubIndex : 1 (integer)
          zwShowMainUI : false (bool)
          zwShowPollingUI : false (bool)
ledStates : []
name : Lys - Bulb2 Hall
onState : False
protocol : ZWave
     brightnessLevel : 0 (integer)
version : 0
Håvard
Chameleon
Post by Chameleon »
Excellent - just what I needed.
I'm assuming that the first output is the Master and the second is the Slave. Is that right?
You've just made it to the top of my priority list - I'll start on this in the morning :D
Regards
Mike
Chameleon
Post by Chameleon »
And if I'd read the information you'd sent I'd have realised that you'd already answered that question lol :mrgreen:
haavarda
Post by haavarda »
Nice :)
Yepp, the first is the master and the second is the slave.
Håvard
haavarda
Post by haavarda »
A bit to quick with the reply there me to :D
Håvard
Chameleon
Post by Chameleon »
Chameleon wrote:And if I'd read the information you'd sent I'd have realised that you'd already answered that question lol :mrgreen:
How do you set the colour temperature - has Matt included a field in the configuration for the slave device?
I'll look online for the manual - I'm sure it'll tell me :D
Mike
haavarda
Post by haavarda »
I set it in the edit device settings...
Skjermbilde 2015-10-20 kl. 21.03.47.png (114.57 KiB) Viewed 6597 times
Håvard
haavarda
Post by haavarda »
....And the strange thing is that the color temperature adjusted there is only reflected when using the slave device. When using the "white" field when setting a rgbw value there is a different color temperature.
Håvard
haavarda
Post by haavarda »
Hi Mike,
Not sure where you want the feedback from a Zipato user, so I am posting it here...
I am sucessfully controlling the bulb now :). I am still testing, but this is my experience so far.
I am getting a log entry on Problems turning on the device. Not sure what this means.
 Z-Wave                          sent "Lys - Bulb2 Hall" set brightness to 66
  LED Light Manager               Colour of LED LYS - RGBW HALL MANAGER is now Antique White
  LED Light Manager               Problems turning on the device1579947277
  LED Light Manager               LED Device LYS - RGBW HALL MANAGER has been updated
  Z-Wave                          sent "Lys - Bulb Hall" set RGBW to 98, 92, 84, 0
25. okt. 2015, 12.53.48
  Z-Wave                          sent "Lys - Bulb Hall" status request
  Z-Wave                          sent "Lys - Bulb2 Hall" status request
  Z-Wave                          received "Lys - Bulb Hall" status update brightness 66
One thing that could be nice is an update button when setting or selecting the color. To update the color whit out closing the dialog box.
Greate work!
Håvard
BradTombaugh
Post by BradTombaugh »
Mike, I have an Aeotec ZW098-A52, but I'm unable to get it to be recognized...
I had it added previously just as a plain "dimmer" device ( 011 - Dimmable Power Switch) which allowed me to turn on/off, and adjust brightness, but not the color. After installing the latest version of LED Device Manager 3.20, I have it configured for both "RGBW and RGB Devices" but it's not recognizing the device.
Below is the log from startup, adding and editing the device, sending the report to the log, and running the device info script that you posted in the forum.
Oct 26, 2015, 7:57:18 PM
Started plugin "Action Collection 1.4.14"
Started plugin "LED Light Manager 0.3.20"
LED Light Manager Updating your LED Manager to client version 4... Please wait...
LED Light Manager Update to client version 4 completed
Indigo Cocoa client authenticated (10.0.0.108)
Started interface "Z-Wave 1.0.355"
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem411 (firmware 1.00)
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Z-Wave found module included in controller with no matching device (missing or disabled): 011 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 014 - Keypad Door Lock
Oct 26, 2015, 7:58:17 PM
LED Light Manager Error Error in plugin execution UiAction:
File "plugin.py", line 1395, in getConfigDevice
<type 'exceptions.KeyError'>: key not found in database
Oct 26, 2015, 7:58:35 PM
LED Light Manager Colour of LED AEOTEC is now White
LED Light Manager Error Error in plugin execution UiValidate:
File "plugin.py", line 617, in validateDeviceConfigUi
File "plugin.py", line 84, in changeDeviceColours
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''
Oct 26, 2015, 7:59:02 PM
LED Light Manager LED Device BASEMENT 4 has been updated
Z-Wave Error could not find cached device for action
Oct 26, 2015, 7:59:45 PM
LED Light Manager
LED Light Manager -------------------------------------------------------------------------------------
LED Light Manager LED Light Manager Status Report
LED Light Manager Device: BASEMENT 4
LED Light Manager Device Type: Single
LED Light Manager Device with a single devices for Red, Green, Blue, White
LED Light Manager includes Zipato LED, AeoTech RGB, etc...
LED Light Manager
LED Light Manager Current Colour is:White which is colour number 138
LED Light Manager Red setting (0-100) is 100
LED Light Manager Green setting (0-100) is 100
LED Light Manager Blue setting (0-100) is 100
LED Light Manager White setting (0-100) is 0
LED Light Manager Composite setting (0-100) is 100
LED Light Manager
LED Light Manager Linked Devices (Direct):
LED Light Manager NONE
LED Light Manager
Oct 26, 2015, 8:01:03 PM
LED Light Manager Colour of LED AEOTEC is now Custom
LED Light Manager Problems turning on the device0
LED Light Manager LED Device NEW DEVICE has been updated
Oct 26, 2015, 8:01:44 PM
Oct 26, 2015, 8:02:39 PM
Embedded script executor host started
Script address :
batteryLevel : None
configured : True
description :
deviceTypeId : rgbwFibaro
displayStateId : presetColour
displayStateImageSel : SensorOn
displayStateValRaw : Custom
displayStateValUi : Custom
enabled : True
errorState :
folderId : 0
com.corporatechameleon.rgbplugBeta : (dict)
BlueDev : (string)
BlueId : (string)
BlueVal : 100 (string)
FibaroRGBComposite : 0 (string)
GreenDev : (string)
GreenId : (string)
GreenVal : 100 (string)
LEDRGBComposite : 0 (string)
MasId : (string)
MasVal : 100 (string)
RedDev : (string)
RedId : (string)
RedVal : 100 (string)
WhiteDev : (string)
WhiteId : (string)
WhiteVal : 100 (string)
colourMethod : Preset (string)
colourMine : (string)
colourSelect : 0 (string)
manufacturer : Aeotec (string)
rgbName : Aeotec (string)
rgbType : false (bool)
zipColour : 0 (string)
zipSlaveId : (string)
zipSlaveName : (string)
zipWhiteMode : false (bool)
lastChanged : 2015-10-26 20:02:47
model : RGBW LED device
pluginId : com.corporatechameleon.rgbplugBeta
protocol : Plugin
blueSetting : 100 (string)
colourNumber : -1 (integer)
colourType : Preset (string)
compositeSetting : 100 (string)
deviceLinks : ** No Links Found ** (string)
deviceStatus : On (string)
deviceType : Single (string)
greenSetting : 100 (string)
presetColour : Custom (string)
redSetting : 100 (string)
whiteSetting : 100 (string)
zipColourTemp : 0 (integer)
subModel :
supportsStatusRequest : False
version : 0
What am I missing?
BradTombaugh
FYI, here is the log info when I add the Aeotec ZW098-A52 as a "Dimmable Power Switch" in case this helps:
Oct 26, 2015, 8:16:12 PM
Z-Wave Syncing - started for device "011 - Dimmable Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 9, 15, 16
Z-Wave Syncing - requesting neighbor list update of "011 - Dimmable Power Switch"
Z-Wave Syncing - neighbor list update complete (no change)
Z-Wave Syncing - assigning return route to "011 - Dimmable Power Switch"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Unknown - 01030062
Z-Wave Syncing - retrieved protocol version 4.05, app version 1.04
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 33v1 85v1 26v2 27v1 2Bv1 2Cv1 70v1 72v1 73v1 5Ev1 59v1 7Av1 86v1
Z-Wave Syncing - created device "011 - Unknown"
Z-Wave Syncing - complete
Z-Wave sent "011 - Unknown" status request
Z-Wave received "011 - Unknown" status update brightness 100
Oct 26, 2015, 8:16:58 PM
Z-Wave Indigo Device "Basement 4" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.355
Node ID: 11
Model: Unknown
Model ID: 01030062
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 4.05
Application Version: 1.04
Model Definition Version: 0
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 33v1 85v1 26v2 27v1 2Bv1 2Cv1 70v1 72v1 73v1 5Ev1 59v1 7Av1 86v1
Features: routing, beaming
Neighbors: 2, 3, 4, 5, 6, 7, 8, 9, 15, 16
Associations: 1:[1] 2:[]
Config Values: - none -
BradTombaugh
Sorry to inundate you with logs if it is not helpful... I also ran your script on the Aeotec RGBW after adding it as a simple dimmer device, in case this is easier for you:
Oct 26, 2015, 8:31:02 PM
Script address : 11
batteryLevel : None
brightness : 100
configured : True
description : 011 - Unknown
Aeotec ZW098-A52
enabled : True
errorState :
folderId : 0
address : 11 (integer)
propsPushTickler : 1 (string)
zwAppVersMinor : 4 (integer)
g1 : (list)
Item : 1 (integer)
g2 : (list)
zwAssociationsMapStr : 1:[1] 2:[] (string)
c112 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c32 : 1 (integer)
c38 : 2 (integer)
c39 : 1 (integer)
c43 : 1 (integer)
c44 : 1 (integer)
c51 : 1 (integer)
c89 : 1 (integer)
c94 : 1 (integer)
zwClassCmdMapStr : 20v1 33v1 85v1 26v2 27v1 2Bv1 2Cv1 70v1 72v1 73v1 5Ev1 59v1 7Av1 86v1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 17 (integer)
Item : 1 (integer)
zwConfigValsStr : - none - (string)
zwEndpointClassMapStr : - none - (string)
zwEndpointDevTypeMapStr : - none - (string)
zwManufactureId : 134 (integer)
zwManufactureName : Aeon Labs (string)
zwModelDefnVers : 0 (integer)
zwModelId : 16973922 (integer)
zwModelName : Unknown (string)
Item : 2 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 6 (integer)
Item : 7 (integer)
Item : 8 (integer)
Item : 9 (integer)
Item : 15 (integer)
Item : 16 (integer)
zwNodeNeighborsStr : 2, 3, 4, 5, 6, 7, 8, 9, 15, 16 (string)
zwProtoVersMajor : 4 (integer)
zwProtoVersMinor : 5 (integer)
lastChanged : 2015-10-26 20:29:19
ledStates : []
model : Unknown
name : Basement LED 4
onState : True
protocol : ZWave
subModel :
version : 0
Thanks for your help! Please let me know if there is anything that I can do to help...
Chameleon
Post by Chameleon »
BradTombaugh wrote:Sorry to inundate you with logs if it is not helpful... I also ran your script on the Aeotec RGBW after adding it as a simple dimmer device, in case this is easier for you:
Script address : 11
batteryLevel : None
brightness : 100
configured : True
Aeotec ZW098-A52
enabled : True
errorState :
folderId : 0
g1 : (list)
Item : 1 (integer)
g2 : (list)
c112 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c32 : 1 (integer)
c38 : 2 (integer)
c39 : 1 (integer)
c43 : 1 (integer)
c44 : 1 (integer)
c51 : 1 (integer)
c89 : 1 (integer)
c94 : 1 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 17 (integer)
Item : 1 (integer)
Item : 2 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 6 (integer)
Item : 7 (integer)
Item : 8 (integer)
Item : 9 (integer)
Item : 15 (integer)
Item : 16 (integer)
ledStates : []
model : Unknown
onState : True
protocol : ZWave
subModel :
version : 0
Thanks... more information is better than no information. I can work this one through for you. Let me look at it in the morning and I'll come back to you!
Regards
Mike
Chameleon
Post by Chameleon »
BradTombaugh wrote:Mike, I have an Aeotec ZW098-A52, but I'm unable to get it to be recognized...
LED Light Manager
LED Light Manager
LED Light Manager
post about it LED Light Manager Linked Devices (Direct):
LED Light Manager
What am I missing?
Brad
I've talked to Matt/Jay and they've told me that the AEO RGB isn't supported fully yet... There's a post about it here:
http://forums.indigodomo.com/viewtopic. ... 15#p103115
Until they expose the RGBW Channels to indigo I don't have anything to work with so we'll have to wait for them. Sorry - but I promise the moment they support the RGBW feature I'll create a driver for it the same day!
Regards
Mike
Chameleon
Post by Chameleon »
haavarda wrote:Hi Mike,
Greate work!
Havard
I'm working on this now. It isn't in tonight's release but it will be in one over the week end. I'll check the error message as well. I think it's probably a small error on selecting the SLAVE v MASTER device - easy to solve :D
Regards
Mike
