Shims feature request
berkinet
Post by berkinet »
-> a "nice to have"
The Shim device offers options to display battery level, energy usage, and power load. It would be nice to have an option for an arbitrary state name. For example, I have a device with: rssi, voltage, humidity. I can display those using one of the built-in state names. But, it would be nicer to properly name them. BTW, this is Value Sensor Device.
Re: Shims feature request
You mean when the sensor type is set to generic, you want to be able to append a custom label to the value for the UI?
berkinet
Post by berkinet »
FlyingDiver wrote: Fri Dec 05, 2025 7:48 am You mean when the sensor type is set to generic, you want to be able to append a custom label to the value for the UI?
Here is a screenshot of what I what I see today. I am using the hard-coded power load property to display signal strength. I would like to change the label to something other than "Current power."
Screenshot 2025-12-06 at 11.18.53.png (219.25 KiB) Viewed 143 times
Post a screen clip of what you see in the UI (where you want to change the label).
berkinet
Post by berkinet »
FlyingDiver wrote: Sat Dec 06, 2025 6:33 am Post a screen clip of what you see in the UI (where you want to change the label).
Screenshot 2025-12-06 at 17.23.19.png (92.97 KiB) Viewed 119 times
That’s generated by the Indigo client. I could change the units displayed, but not the label.
The right way to do it is to create another sensor device just to display the rssi value.
berkinet
Post by berkinet »
FlyingDiver wrote: Sat Dec 06, 2025 11:27 am That’s generated by the Indigo client. I could change the units displayed, but not the label.
Actually, that makes sense. Thanks for looking into it.
Return to “MQTT”
