Error Installing HomeKitLink-Siri Plugin
akimball
Post by akimball »
I hope you've seen this one before. When I double click the HomeKitLink plugin, I get the following error messages in the Indigo Event Log:
Installing and enabling plugin HomeKitLink Siri v0.6.75
Error ReloadPlugin() caught exception: FileIOError -- rename/move of file or folder failed -- check file/folder permissions
Reloading plugin "Web Server 2024.2.0" using API v3.6
Stopping plugin "Web Server 2024.2.0" (pid 1341)
Reflector shutdown reflector connection
Stopped plugin "Web Server 2024.2.0"
Starting plugin "Web Server 2024.2.0" (pid 1350)
Started plugin "Web Server 2024.2.0"
Web Server starting internal Web server on http://localhost:8176
Bonjour registered "Indigo - BridgePort 1" for type _http._tcp
Web Server cache contains 0 tokens
Web Server starting cache cleaning background process
Reflector starting reflector connection to https://akimball.indigodomo.net
Not sure what file or folder failed and I don't know where or how to check this.
TIA,
-al Kimball
-Al
DaveL17
Re: Error Installing HomeKitLink-Siri Plugin
Post by DaveL17 »
Have you checked the plugin log? There might be a clue there.
My Plugins and Scripts
ryanbuckner
Post by ryanbuckner »
Have you tried deleting the old Plugin and pasting in the new one manually? Disable the plugin then delete and paste the new one here in Finder:
/Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins (Disabled)/
Also make sure once you disable it there is only 1 copy of the plugin in the above directory. Make sure there is not one in
/Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/
akimball
Post by akimball »
So a couple years ago I had HomeBridge installed but now I'm trying to move to HomeKitLink to regain that functionality. I've never had HomeKitLink installed before now. That said I looked through the plugins and preferences files located in the preceptive Automation folder in libraries: There is no reference to HomeKitLink... only HomeBridge.
I'm not completely sure I'm staring at the right location: Screenshot attached
Thank you.
-Al
GlennNZ
Post by GlennNZ »
Hi
That is a pretty low level indigo error. Would suggest will happen with any plugin install ?
Something is up with file permissions, the download plugin bundle or user permission settings.
Would check all of the above.
Rerun the indigo installer appears to be the standard advice for file permission errors.
akimball
Post by akimball »
Thanks, I will attempt to reinstall indigo.
-al
-Al
akimball
Post by akimball »
I reinstalled indigo and I get the same error. Tried loading some plugins that I haven't used before and they all installed except for
appleTV Plugin, and
HomeKitLink Siri plugin.
These both gave me the same error line in red:
Is there anything else I can try? Wife really wants HomeKit with Siri to work again. :(
-al
-Al
GlennNZ
Post by GlennNZ »
Unfortunately it does seem there is a wider issue here.
Alternatively it may be the permissions of the download bundle? Perhaps would check location of that - and the files permissions.
Would check user permissions settings - as Indigo does need user running to have elevated permissions
But failing a quick review/search of user permissions in this forum - this will probably need Matt/Jay to chime in…
Glenn
DaveL17
Post by DaveL17 »
Have you recently migrated to a new machine using Migration Assistant by chance?
Migration Assistant has been known to mess up user permissions sometimes.
GlennNZ
Post by GlennNZ »
Both those 2 plugins you have issues with,unzip the downloaded file into a new folder.
I wonder whether current user does not have permissions for that created folder?
Otherwise would have thought re running installer would sort out indigo app folder permissions ….
akimball
Post by akimball »
Interesting comments and it does sound like a permissions problem. I am however the admin on this computer and YES I have upgraded the computer (about 9 months ago) from a 2018 MacMini to a 2023 MacMini and I think I used the migration assistant.
(Side rant): I've had big issues with both Alexa and Siri for a couple of years... but I have decided to throw Alexa in the Trash and just support Siri going forward. Alexa has a horrible web interface and it completely does its own thing... my home has a couple of hundred devices and Alexa is not built for that. I'm so done with Alexa.
Is there a deeper level of permissions I can activate with "Terminal" that will allow me to install HomeKitLink-Siri?
I checked the permissions on the HomeKitLink plugin and some of the folders in the Perceptive Automation folder... It says that I have permissions to Read/Write on these.
Thanks for all the help... -al
-Al
GlennNZ
Post by GlennNZ »
My guess is it's permissions in the folder where you have unzipped the plugin Bundle from.
If you have re-run Indigo installer - that should sort out the Indigo permissions.
ryanbuckner
There are other unsolved issues with this error
durosity
Post by durosity »
akimball wrote: Sat Mar 15, 2025 2:14 pm
-al Kimball
You don't happen to have the plugin on iCloud Drive at present? If you do try moving it to your home folder first then run it from there.
ryanbuckner
akimball wrote: Sat Mar 15, 2025 3:17 pm I'm not completely sure I'm staring at the right location: Screenshot attached
Thank you.
What happens when you unzip the file and then manually paste it into the Plugins folder?
Return to “HomeKitLink Siri”
