I can't seem to figure out if there's a way to push the display of a video device to a client. I'd like the video feed to pop up like a control page when a particular trigger fires.
Possible?
Push Video Device to client?
- Different Computers
- Contact:
Re: Push Video Device to client?
A few years ago I did something like that - trigger fired and it switched to a different control page with the video, then it switched back after a set time. Let me see if I can find it…
Used trigger (see below) to switch control page - then next action delayed by 50 seconds send it back (same action a first one but points it back to the original control page).
- 2022-02-07_10-50-37.png (119.03 KiB) Viewed 3644 times
_______
Norm
Norm
- Contact:
This was my first thought too. But the video feed is not a control page, and can't be imbedded in a control page, unless I'm missing some other trick there.
I’m using security spy for that - I think I remember you said you have security spy as well as Camect (like me). If so and you can use security spy for your video I can post how it is set up.
_______
Norm
Norm
- Contact:
Alas, no security spy. Camect only.
Likely it can be done if your camera works with a web browser but I would not be the person to ask - maybe someone else has some ideas, good luck and sorry I could not help…
_______
Norm
Norm
- RogueProeliator
No, but can consider it for an enhancement in the near future... is this for an always-showing console in the home or on a mobile device? There are some restrictions on mobiles about directly showing foreground content from a notification, but reacting to it while DP is already up is definitely doable.I can't seem to figure out if there's a way to push the display of a video device to a client. I'd like the video feed to pop up like a control page when a particular trigger fires. Possible?
Adam
- Contact:
Yup, for me it would be an always on, always domopad in the foreground situation.
Awesome, thanks in advance!
