autolog
Post by autolog »
Give V1.2.2 a go :)
Busta999
Post by Busta999 »
Getting it now
Busta999
Post by Busta999 »
Done
All good thanks!!
autolog
Post by autolog »
Busta999 wrote:Excellent - I get it - the SetPoint is set low to achieve an Off - ok
Spooked me there :-)
Actually, just been looking at the code and my system and it should be showing 20 deg C. It is OK for the controlled TRV (Spirit) to be 8 as it should be off as the Heat Setpoint has been reached. The TRV Controller should be showing 20 as that is the active target Heat setpoint.
Looks like you could have found a bug? :?
Busta999
Post by Busta999 »
Excellent.
I’ll roll out more TRVs tomorrow.
Busta999
Post by Busta999 »
I'm getting this now
Action Collection Error         State id (sensorValue) isn't available for device model Radiator Thermostat (HRT4-ZW) - action not configured correctly
Getting it every 3 minutes
Related?
52 is one of the TRVs under TRV Controller - Lounge Front
autolog
Post by autolog »
My first take is that it isn't the TRV Controller plugin, but I could be wrong. :)
If you disable the TRV Controller device controlling that TRV , does it stop?
Are you running a graphing action every 3 minutes e.g. CSV capture or some other action that is scheduled for every three minutes?.
I am turning in for the night and will pick this up again tomorrow. :)
Busta999
Post by Busta999 »
Same here - will look in the morning.
Thanks for all your help today.
Busta999
Post by Busta999 »
[Edit - changed captures to simply]
Maybe I am just misunderstanding the Plugin.
The rooms I have run by this plugin are very warm indeed!
An example the Kitchen.
Still delivering Heat when both the TRV and the external Thermostat are reporting over the target of 20C
This is graph of events over the last couple of days
siclark
Post by siclark »
Couple of questions.
Are you using remote temp sensor with Delta set to 5 degrees?
Could you also plot the TRV setpoint as well as the thermostat plugin device.
Finally it's showing that your trv is in hardware mode, have you pressed buttons on the TRV?
Busta999
Post by Busta999 »
Yes
Will do
Nope not touched a button on TRV since Inclusion and initial setup
BTW found the issue with the repeating error
All my fault {Blush} - worked it out
Busta999
Post by Busta999 »
Actually I am plotting the TRV Setpoint it is the Red line on the graph
autolog
Post by autolog »
Good morning :)
This is a useful bit of testing, can check that your Spirit device settings are setup as follows:
Spirit Device Settings
I suspect what is happening is that when the Spirit returns the Setpoint (which isn't needed by the plugin), the plugin can't tell whether that is the result of a poll or whether a physical button has been pressed. I suspect that is why it is showing it as being in TRV Hardware Mode.
autolog
Post by autolog »
re: previous post - you need all your Spirits to be setup the same way. Once all changed, reload the plugin to start with a clean-slate.
I will look at putting in a check for the required Spirit parameters and warning if not correct.
I will also add these requirements to the documentation. :wink:
Busta999
Post by Busta999 »
This is how it is setup now.
Return to “TRV Controller”
