Can smartphone radar be used with Amazon Dash buttons?
Re: Can smartphone radar be used with Amazon Dash buttons?
Hmm... sure wish there was a way to make this more reliable. I can imagine them hidden under the coffee table, dinner table, night stand to activate all sorts of one touch scenes.
if you are into this:
the mac has to listen to the WAN port of the router. You could add a splitter between the router and the modem. Then connect that cable to the second port of a mac. and setup a 2. FING to listen to that ethernet...
Or some routers have an option to copy ALL traffic to specified port, connect that port to your mac.
Thats a real challenge..
here the inside of the amazon dash button:
it has an AAA battery in the back, which could be replaced, but it is soldered in, so a bit tricky
The front can be opened after you remove the plastic film which shows the product name. after that you need to unscrew three 8x corner very small screws , Then it falls apart.
It has
one button just under the REV01
one uFL antenna connector just left of the white label
one 8 pin programming socket top right
one microphone top end
It is not clear what chips are on there as many do not have a label on them or a private label.
BUT if the battery runs out it should be possible to replace it, or just buy a new switch for $5.
It has
- Screen Shot 2015-09-01 at 2.49.00 PM.png (130.46 KiB) Viewed 3728 times
- Screen Shot 2015-09-01 at 1.30.42 PM.png (311.5 KiB) Viewed 3740 times
- Screen Shot 2015-09-01 at 1.35.28 PM.png (140.7 KiB) Viewed 3740 times
There's a nice programming reference and early hack guide for the dash here:
https://learn.adafruit.com/dash-hacking ... g?view=all
Still a lot to learn but they've already made good progress.
Terry
Terry
