Tesla Batter Plugin New Version
GlennNZ
Post by GlennNZ »
Tesla Battery Plugin for Indigo Domo
Connect your Tesla Powerwall to Indigo Domo for live monitoring, automation, and control — entirely from your local network, with optional Tesla cloud features.
New Version: 1.0.30 Download / Install:
https://www.indigodomo.com/pluginstore/170/
Features
  • Battery Charge & State — Real-time charge percentage, with charging / discharging / idle state
  • Backup Reserve — Read and set your backup reserve percentage via action groups
  • Power Flow — Live watts for solar, battery, grid, and home load
  • Local Monitoring — Polls your Gateway directly — no cloud dependency for data collection
  • Tariff Awareness — Reads your Tesla TOU tariff plan and tracks the current rate period in real time
  • Grid Events — Detects grid loss, restoration, and faults with device state changes
  • Rich Indigo States — All values exposed as device states for triggers, scripts, and control pages
  • Automation — React to grid loss, battery state changes, solar export events, and tariff periods
Quick Setup
  1. Assign a static IP to your Powerwall Gateway in your router (DHCP reservation)
  2. Download the latest release and double-click the .indigoPlugin bundle to install
  3. Open Plugins → Tesla Battery → Configure — enter the Gateway IP, your Tesla account email, and local Gateway password
  4. Click Check Connection — then Generate Tesla Devices when it appears
  5. (Optional) Tick Allow Online Communication and add a Refresh Token for remote control and extended states
What Gets Created
Four devices inside a Tesla Battery Gateway folder:
  • Tesla Site Info — Site name, grid code, utility, current tariff rate and period name
  • Tesla Battery — Charge %, operational mode, backup reserve %, estimated time remaining, storm mode, firmware version
  • Tesla Grid Status — Grid connected / islanded boolean, raw status string, loss & restore timestamps, fault log
  • Tesla Meters — Live watts for solar / grid / home / battery, plus boolean states for solarGenerating, gridUsage, batteryCharging, batteryDischarging, sendingToGrid
Powerwall Control Page Images
Over 500 images are included for use in Indigo control pages. The batteryState_combined device state (e.g. charging_73) maps directly to filenames — Indigo selects the right image automatically.
Image Image Image
Charging 50% · Idle 50% · Discharging 75%
Image sets:
  • Device/ — 100 charge-level images (powerwall+1.png … powerwall+100.png)
  • Device/Combined/ — 300 combined state + charge images (charging / idle / discharging × 1–100%)
  • Device/Combined-small/ — Same at reduced size for compact layouts
Documentation
Full documentation is available in the GitHub Wiki:
  • Installation — Step-by-step setup, finding the gateway password, refresh token instructions, troubleshooting
  • Configuration — Every Plugin Config field explained, polling intervals, token lifecycle
  • Devices & States — All four devices with complete state reference tables
  • Actions — Set operational mode, change backup reserve, retry behaviour
  • Triggers & Automation — Device state triggers, grid loss/restore, tariff events, example automations
  • Control Pages & Images — Image sets, batteryState_combined wiring, step-by-step control page setup
  • Full Changelog — Complete version history from 0.0.5 (2018)
Changelog
1.0.30 — 2026-05-31
  • Add comprehensive GitHub wiki documentation (Installation, Configuration, Devices, Actions, Triggers, Control Pages, Changelog)
  • Update README with banner, feature table, wiki links, and inline Powerwall images
1.0.27 — 2026-05-31
  • Fixed TariffResolver exceptions crashing the background thread — now caught and logged gracefully
  • Fixed grid fault trigger never firing on first fault appearance (condition was inverted)
  • Fixed grid fault log message incorrectly labelled "BLANK" when faults were present
  • Fixed unbound dev variable crash when no battery devices exist during tariff update
  • Fixed setOperationalModeOnline TypeError on auth failure (datareturned is always None)
  • Fixed JSON string injection in sendcommand local login payload — replaced with json.dumps()
  • Fixed battery level image not updating when charge is exactly 25%
  • Fixed SystemIslandedReady grid state not handled — now treated same as SystemIslandedActive
  • Fixed fillmetersinfo exception handler logging wrong function name
  • Fixed OAuth authorized guard (was commented out) — prevents unnecessary token refresh on every loop call
  • Removed discarded getsiteInfoOnline() call in setOperationalModeOnline
  • Changed bare macOS version line from info to debug log level
Requirements
  • Tesla Powerwall with Gateway accessible on your local network
  • Indigo Domo 2022.1 or later (tested through 2025.2)
  • Python 3.10+ (bundled with modern Indigo)
  • Static / reserved IP address for the Gateway
  • (Online features only) Tesla account email + Refresh Token
Version 1.0.30 · Developed by Glenn Hawken · GitHub
Return to “Tesla Battery”
