Is there still a "setup code" like the older plugin?
scs
Post by scs »
back story: earlier today I was trying to rename a indigo device in hopes I wouldn't need to republish, that didn't work and the Apple home device failed to respond anymore, so I deleted the device (just 1 of the 40) from the home app. Big mistake in retrospect, All the devices in the home app disappeared.
I eventually deleted the entire home from the Home app and tried to reconnect the bridge.
Ive been troubleshooting for the past 5 hours, and every time I try to discover the bridge using the QR Code, it fails with (accessory not found)
Been through all 3 of the Xcode troubleshooting tools in the plugin config sheet. no trouble found naturally , it's been working for years.
So, if I open up the home app to a new "Home" and Add accessory > More options The HomkitLink Bridge is shown as an icon (next to the two HomePods) . If I select the bridge It gives me the "uncertified accessory" prompt ... and when I "add anyway" it prompts for the setup code .
Where's this code located ?
iPhone and iPad both run Tahoe, Indigo server is Sequoia , latest indigo release and plugin.
Indigo 2025.1 w/ Insteon and Z-Wave lights and outlets
Security integration.
Energy monitoring
GlennNZ
Re: Is there still a "setup code" like the older plugin?
Post by GlennNZ »
Hi
The QR code includes the code - so ideally this is the method that should be used.
Make sure you are not reusing a browser QR code from earlier - new code for each bridge. Reopen the details.
Otherwise:
The code is - actually no clue -
Okay checked
And pincode is saved as a bridge state.
Indigo device - HKLS Bridge
Custom State
pincode -
Edit:
Also changing the name in indigo should not matter.
Nor deleting the device in Home - unless delete the whole bridge.
Seems like somehow you home install got into a bad state.
scs
Post by scs »
I just got it (the discovery) working by filling in the "advertised interfaces" and the "Server IP address" fields at the bottom of the plugin configuration page, and it discovered it with the QR code , no problem .... is that a head scratcher, or what? :?
thanks for the quick response just the same
Energy monitoring
GlennNZ
Post by GlennNZ »
Those can be blank - unless multiple networks, LAN/wifi/VPN etc.
Check on latest version.
And can check troubleshooting 1,2,3 menu items
Return to “HomeKitLink Siri”
