I've created a problem
jltnol
Post by jltnol »
Due to a few false starts, I added one device(a fan) to the HomeKit device, then deleted the HomeKit Device itself.
I've created a new HomeKit device, and now the previously added device(same fan) is not available. Here is the error code:
HomeKitLink Siri Error          (plugin.py: Function: show_device_publications  line: 4136):    Error :  Message : Missing ID:847216    1678997428
I have not added many devices to the new HomeKit Device so starting over if necessary won't be a problem...
GlennNZ
Post by GlennNZ »
There is a menu setting - unlink any orphaned devices or something similar.
Deletes devices that are attached to now deleted homekit bridge device.
Run that.
jltnol
Re: I've created a problem
Post by jltnol »
got it.
easy.
thanks
cjp767
Post by cjp767 »
I have a similar problem and the unlink orphaned devices didn't work. I was testing two different virtual devices that point to my office lights. Now they're really orphaned-- grayed out at the bottom of the device list. I was trying to start over but these two devices got caught.
Here's the text at the bottom of the list where we select devices to publish. The entries are grayed out:
Devices on other Bridges published to HomeKit:
Bridge Id: 234374 AG Office Lights:
Bridge id: 991783 HA Office Lights:
GlennNZ
Post by GlennNZ »
Unlink orphaned devices should remove these
Is the old orphaned bridge deleted?
If this bridge exists then they are not orphaned
- and essentially that would explain unlink not working
Post the menu items troubleshooting as per the wiki
Menu item Troubleshooting 1
http://www.github.com/ghawken/HomeKitLink-Siri/wiki
cjp767
Post by cjp767 »
This is the output from troubleshooting 1, 2, and 3. I don't have any bridges.
May 24, 2026 at 19:56:37
   HomeKitLink Siri                ==============================================================================================================================================================================================
   HomeKitLink Siri                ==================================================================================== Logging info follows ====================================================================================
   HomeKitLink Siri                ================================================ Initializing New Plugin Session =================================================
   HomeKitLink Siri                Plugin name:                   HomeKitLink Siri
   HomeKitLink Siri                Plugin version:                0.8.05
   HomeKitLink Siri                Plugin ID:                     com.GlennNZ.indigoplugin.HomeKitLink-Siri
   HomeKitLink Siri                Plugin Path:                   /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin
   HomeKitLink Siri                Indigo version:                2025.2.0
   HomeKitLink Siri                Silicon version:               arm64
   HomeKitLink Siri                Python version:                3.13.9 (v3.13.9:8183fa5e3f7, Oct 14 2025, 10:27:13) [Clang 16.0.0 (clang-1600.0.26.6)]
   HomeKitLink Siri                Python Directory:              /Library/Frameworks/Python.framework/Versions/3.13
   HomeKitLink Siri                FFmpeg :                       /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/homekitlink_ffmpeg/ffmpeg_binaries/arm/ffmpeg
   HomeKitLink Siri
   HomeKitLink Siri                ==================================================== Library Install Status: =====================================================
   HomeKitLink Siri                ✅ Found library install success marker: 3.13-pip-install-log-success.txt
   HomeKitLink Siri                ========================================= Contents of 3.13-pip-install-log-success.txt: ==========================================
   HomeKitLink Siri                Contents:
Collecting base36==0.1.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 2))
  Using cached base36-0.1.1-py2.py3-none-any.whl.metadata (2.0 kB)
Collecting cffi (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 3))
  Using cached cffi-2.0.0-cp313-cp313-macosx_11_0_arm64.whl.metadata (2.6 kB)
Collecting chacha20poly1305-reuseable==0.13.2 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 4))
  Using cached chacha20poly1305_reuseable-0.13.2-py3-none-any.whl.metadata (5.3 kB)
Collecting cryptography==46.0.5 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 5))
  Using cached cryptography-46.0.5-cp311-abi3-macosx_10_9_universal2.whl.metadata (5.7 kB)
Collecting h11==0.16.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 6))
  Using cached h11-0.16.0-py3-none-any.whl.metadata (8.3 kB)
Collecting homekitlink_ffmpeg (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 7))
  Using cached homekitlink_ffmpeg-0.0.30-py3-none-any.whl.metadata (2.9 kB)
Collecting ifaddr (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 8))
  Using cached ifaddr-0.2.0-py3-none-any.whl.metadata (4.9 kB)
Collecting orjson==3.11.7 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 9))
  Using cached orjson-3.11.7-cp313-cp313-macosx_15_0_arm64.whl.metadata (41 kB)
Collecting pycparser (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 10))
  Using cached pycparser-3.0-py3-none-any.whl.metadata (8.2 kB)
Collecting pypng==0.20220715.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 11))
  Using cached pypng-0.20220715.0-py3-none-any.whl.metadata (13 kB)
Collecting pyqrcode==1.2.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 12))
  Using cached pyqrcode-1.2.1-py3-none-any.whl
Collecting tlv8==0.10.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 13))
  Using cached tlv8-0.10.0-py3-none-any.whl
Collecting zeroconf==0.148.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 14))
  Using cached zeroconf-0.148.0-cp313-cp313-macosx_11_0_arm64.whl.metadata (6.3 kB)
Using cached base36-0.1.1-py2.py3-none-any.whl (3.5 kB)
Using cached chacha20poly1305_reuseable-0.13.2-py3-none-any.whl (8.6 kB)
Using cached cryptography-46.0.5-cp311-abi3-macosx_10_9_universal2.whl (7.2 MB)
Using cached h11-0.16.0-py3-none-any.whl (37 kB)
Using cached orjson-3.11.7-cp313-cp313-macosx_15_0_arm64.whl (125 kB)
Using cached pypng-0.20220715.0-py3-none-any.whl (58 kB)
Using cached zeroconf-0.148.0-cp313-cp313-macosx_11_0_arm64.whl (1.7 MB)
Using cached cffi-2.0.0-cp313-cp313-macosx_11_0_arm64.whl (181 kB)
Using cached homekitlink_ffmpeg-0.0.30-py3-none-any.whl (90.3 MB)
Using cached ifaddr-0.2.0-py3-none-any.whl (12 kB)
Using cached pycparser-3.0-py3-none-any.whl (48 kB)
Installing collected packages: tlv8, pyqrcode, pypng, ifaddr, base36, zeroconf, pycparser, orjson, homekitlink_ffmpeg, h11, cffi, cryptography, chacha20poly1305-reuseable
Successfully installed base36-0.1.1 cffi-2.0.0 chacha20poly1305-reuseable-0.13.2 cryptography-46.0.5 h11-0.16.0 homekitlink_ffmpeg-0.0.30 ifaddr-0.2.0 orjson-3.11.7 pycparser-3.0 pypng-0.20220715.0 pyqrcode-1.2.1 tlv8-0.10.0 zeroconf-0.148.0
   HomeKitLink Siri                ✅ ✅ Confirmed Library Installs have been successfully Completed ✅ ✅
   HomeKitLink Siri                ================================================ Xcode Command Line Tools Check: =================================================
   HomeKitLink Siri                ✅ Xcode Command Line Tools are needed for compiling native dependencies. Checking...
   HomeKitLink Siri                ✅ Xcode Command Line Tools are installed at: /Library/Developer/CommandLineTools
   HomeKitLink Siri                🔍🔍🔍 Checking Library dependencies, downloading and/or compiling in tempdirectory, without installing. 🔍🔍🔍
   HomeKitLink Siri                ✅ All dependencies listed in 'requirements.txt' are available for installation.
   HomeKitLink Siri                📝 Output:
   HomeKitLink Siri                ======================================================= Advanced Settings: =======================================================
   HomeKitLink Siri                Selected IP version: IPVersion.All
   HomeKitLink Siri                Select interfaces: None
   HomeKitLink Siri                  default_listen_address:         None
   HomeKitLink Siri                  ⚠ ip_version is IPVersion.All but the HAP server is IPv4-only. IPv6 mDNS sockets are created but serve no purpose. IPVersion.V4Only is recommended.
   HomeKitLink Siri                HKLS Advertised Ip address: None
   HomeKitLink Siri                HKLS Server Ipaddress: None
   HomeKitLink Siri                HKLS Advertised Ipaddress and HKLS Server Ipaddress are None, which is acceptable. The server will decide the best option.
   HomeKitLink Siri                ========================================================================= Device Bridges enabled and up and Running ==========================================================================
Troubleshooting 2:
May 24, 2026 at 20:00:58
   HomeKitLink Siri                ================================================================================== Network Trouble Shooting ==================================================================================
   HomeKitLink Siri                ======================================================= System Information =======================================================
   HomeKitLink Siri                  macOS version:   26.5
   HomeKitLink Siri                  Architecture:    arm64
   HomeKitLink Siri                ================================================ Apple Local Network Access Check ================================================
   HomeKitLink Siri                  macOS Sequoia (15.x+) requires Local Network Access for plugins to use mDNS.
   HomeKitLink Siri                  If this is not enabled, HomeKit bridges will NOT be discoverable.
   HomeKitLink Siri                  --- Detecting local network interface ---
   HomeKitLink Siri                  Auto-detected local IP: 10.0.1.11
   HomeKitLink Siri                  --- Test: mDNS Multicast Send (definitive LNA test) ---
   HomeKitLink Siri                  ✅ Successfully sent multicast packet to 224.0.0.251:5353 via 10.0.1.11
   HomeKitLink Siri                     Local Network Access is ENABLED.
   HomeKitLink Siri                  --- Test: mDNS Multicast Group Join ---
   HomeKitLink Siri                  ✅ Successfully joined mDNS multicast group 224.0.0.251:5353
   HomeKitLink Siri                  --- Test: Outbound UDP Connectivity ---
   HomeKitLink Siri                  ✅ Outbound UDP connectivity OK. Local IP: 10.0.1.11
   HomeKitLink Siri                  --- Test: Local Gateway Reachability ---
   HomeKitLink Siri                  Derived likely gateway: 10.0.1.1
   HomeKitLink Siri                  ℹ️ Gateway 10.0.1.1:80 returned error code 61 (port may be closed, but host may still be reachable).
   HomeKitLink Siri                ======================================================== Firewall Status =========================================================
   HomeKitLink Siri                  --- Check firewall status (socketfilterfw) ---
   HomeKitLink Siri                    Firewall is disabled. (State = 0)
   HomeKitLink Siri                  --- Check firewall stealth mode ---
   HomeKitLink Siri                    Firewall stealth mode is off
   HomeKitLink Siri                  --- Check firewall block-all setting ---
   HomeKitLink Siri                    Firewall has block all state set to disabled.
   HomeKitLink Siri                ================================================== Plugin Network Configuration ==================================================
   HomeKitLink Siri                  HKLS Advertised IP address: None
   HomeKitLink Siri                  HKLS Server IP address:     None
   HomeKitLink Siri                  Starting port number:       51826
   HomeKitLink Siri                  Active drivers:             0
   HomeKitLink Siri                  Active bridges:             0
   HomeKitLink Siri                ======================================================= Bridge Port Checks =======================================================
   HomeKitLink Siri                ====================================================== DNS Resolution Check ======================================================
   HomeKitLink Siri                  apple.com resolves to: ['17.253.144.10', '2620:149:af0::10']
   HomeKitLink Siri                  github.com resolves to: ['140.82.116.3']
   HomeKitLink Siri                ======================================================== Recommendations =========================================================
   HomeKitLink Siri                  ✅ Local Network Access appears to be working (multicast send test passed).
   HomeKitLink Siri
   HomeKitLink Siri                  To check/enable Local Network Access on macOS Sequoia (15.x+):
   HomeKitLink Siri                    1. Open System Settings > Privacy & Security > Local Network
   HomeKitLink Siri                    2. Find 'IndigoPluginHost3' (and the Indigo Server application) in the list
   HomeKitLink Siri                    3. Ensure the toggle is ENABLED
   HomeKitLink Siri                    4. If it is not listed, try restarting the plugin — macOS should prompt for permission
   HomeKitLink Siri
   HomeKitLink Siri                  If Local Network Access is blocked, mDNS service advertisement will silently fail
   HomeKitLink Siri                  and HomeKit bridges will not be discoverable in the Home app.
   HomeKitLink Siri
   HomeKitLink Siri                  Additional tips:
   HomeKitLink Siri                    - If the firewall is enabled, ensure IndigoServer/IndigoPluginHost3 is allowed.
   HomeKitLink Siri                    - If Stealth Mode is on, incoming mDNS responses may be blocked.
   HomeKitLink Siri                    - Verify bridge ports are accessible (see port checks above).
   HomeKitLink Siri                    - Copy and paste the above output when reporting network issues.
   HomeKitLink Siri                ============================================================================= Network Trouble Shooting Complete ==============================================================================
Troubleshooting 3-
May 24, 2026 at 20:02:09
   HomeKitLink Siri                ==================================================================================== mDNS Troubleshooting ====================================================================================
   HomeKitLink Siri Warning          ⚠ ip_version is IPVersion.All.  The HAP server is IPv4-only. IPv6 mDNS sockets will be created but serve no purpose. IPVersion.V4Only is strongly recommended.
   HomeKitLink Siri                Starting Port Number: 51826
   HomeKitLink Siri                Ports currently in use: set()
   HomeKitLink Siri                =================================================== Running Bridges / Drivers ====================================================
   HomeKitLink Siri                Number of active drivers: 0
   HomeKitLink Siri                Number of active bridges: 0
   HomeKitLink Siri                =================================================== Network Adapters (ifaddr) ====================================================
   HomeKitLink Siri                  lo0                  IPv4   127.0.0.1
   HomeKitLink Siri                  lo0                  IPv6   ::1
   HomeKitLink Siri                  lo0                  IPv6   fe80::1
   HomeKitLink Siri                  en0                  IPv6   fe80::4bd:49ee:cb2b:292e
   HomeKitLink Siri                  en0                  IPv6   2601:603:301:82fb:1002:adcb:42c7:c8ca
   HomeKitLink Siri                  en0                  IPv6   2601:603:301:82fb:10aa:ca61:e83c:688b
   HomeKitLink Siri                  en0                  IPv4   10.0.1.11
   HomeKitLink Siri                  en0                  IPv6   2601:603:301:82fb:7822:aea2:523d:ec51
   HomeKitLink Siri                  en0                  IPv6   2601:603:301:82fb:1192:8030:80af:5db0
   HomeKitLink Siri                  en0                  IPv6   2601:603:301:82fb:ed86:ce8a:aab3:4000
   HomeKitLink Siri                  en0                  IPv6   2601:603:301:82fb:188d:ced5:6b80:8d83
   HomeKitLink Siri                  en1                  IPv6   fe80::1400:8c38:ab2e:6634
   HomeKitLink Siri                  en1                  IPv6   2601:603:301:82fb:ce3:b8ae:6409:ebd6
   HomeKitLink Siri                  en1                  IPv6   2601:603:301:82fb:4845:a15e:6c06:f0e2
   HomeKitLink Siri                  en1                  IPv6   2601:603:301:82fb:5c89:33a1:ef84:f646
   HomeKitLink Siri                  en1                  IPv6   2601:603:301:82fb:281f:3b0a:c5f2:798a
   HomeKitLink Siri                  en1                  IPv4   10.0.1.9
   HomeKitLink Siri                  en1                  IPv6   2601:603:301:82fb:34d2:ab35:d566:e5a5
   HomeKitLink Siri                  en1                  IPv6   2601:603:301:82fb:341d:d66c:a70e:63ff
   HomeKitLink Siri                  (filtered 13 virtual/tunnel adapter entries: awdl0(1), llw0(1), utun0(1), utun1(1), utun10(3), utun2(1), utun3(1), utun5(1), utun6(1), utun7(1), utun8(1))
   HomeKitLink Siri                ================================================== Zeroconf Detected Addresses ===================================================
   HomeKitLink Siri                  IPv4 addresses: ['10.0.1.9', '100.84.110.91', '127.0.0.1', '10.0.1.11']
   HomeKitLink Siri                  IPv6 addresses (28): ['fe80::9e76:eff:fe4c:d402', 'fe80::2410:2b11:a983:212f', 'fe80::77c7:dfea:3cec:e073', '2601:603:301:82fb:7822:aea2:523d:ec51', '::1', '2601:603:301:82fb:341d:d66c:a70e:63ff', '2601:603:301:82fb:10aa:ca61:e83c:688b', 'fe80::1', 'fe80::98ad:95ff:fed1:aaba', 'fe80::86e2:8496:9298:c9a7', '2601:603:301:82fb:281f:3b0a:c5f2:798a', '2601:603:301:82fb:188d:ced5:6b80:8d83', 'fe80::c64f:9535:fae1:23ac', '2601:603:301:82fb:1002:adcb:42c7:c8ca', '2601:603:301:82fb:ed86:ce8a:aab3:4000', 'fe80::f24:f167:d70e:b986', 'fe80::9ac:4432:ee58:1ed0', 'fe80::4bd:49ee:cb2b:292e', '2601:603:301:82fb:34d2:ab35:d566:e5a5', 'fe80::575:4bd3:5019:50c4', '2601:603:301:82fb:5c89:33a1:ef84:f646', 'fe80::1400:8c38:ab2e:6634', 'fe80::ce81:b1c:bd2c:69e', '2601:603:301:82fb:ce3:b8ae:6409:ebd6', 'fd7a:115c:a1e0::1001:6ebf', '2601:603:301:82fb:4845:a15e:6c06:f0e2', '2601:603:301:82fb:1192:8030:80af:5db0', 'fe80::98ad:95ff:fed1:aaba']
   HomeKitLink Siri                ================================================= Socket Local Address Detection =================================================
   HomeKitLink Siri                  Detected local IPv4 address: 10.0.1.11
   HomeKitLink Siri                ======================================================= IPv6 Support Check =======================================================
   HomeKitLink Siri                  socket.has_ipv6: True
   HomeKitLink Siri                  IPv6 is available on this system (but the HAP server is IPv4-only).
   HomeKitLink Siri                ====================================================== mDNS Port 5353 Check ======================================================
   HomeKitLink Siri                  Port 5353 (mDNS): Successfully bound — port is available.
   HomeKitLink Siri                =========================================== Zeroconf: Browse _hap._tcp.local. Services ===========================================
   HomeKitLink Siri Warning          No HAP (_hap._tcp) services discovered on the local network.
   HomeKitLink Siri Warning          This may indicate mDNS is not functioning correctly, or no bridges are running.
   HomeKitLink Siri                ================================================== Terminal Diagnostic Commands ==================================================
   HomeKitLink Siri                  (Note: dns-sd is a continuous browse command; timeout is expected)
   HomeKitLink Siri                  --- dns-sd -B _hap._tcp local. ---
   HomeKitLink Siri                  (command timed out after 6s, partial output below)
   HomeKitLink Siri                    Browsing for _hap._tcp.local.
   HomeKitLink Siri                    DATE: ---Sun 24 May 2026---
   HomeKitLink Siri                    20:02:14.438  ...STARTING...
   HomeKitLink Siri                    Timestamp     A/R    Flags  if Domain               Service Type         Instance Name
   HomeKitLink Siri                    20:02:14.451  Add        3  17 local.               _hap._tcp.           Rachio-BDFAB6
   HomeKitLink Siri                    20:02:14.451  Add        2  19 local.               _hap._tcp.           Rachio-BDFAB6
   HomeKitLink Siri                  --- scutil --dns (DNS Configuration) ---
   HomeKitLink Siri                    DNS configuration
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #1
   HomeKitLink Siri                      search domain[0] : tail97c2bb.ts.net
   HomeKitLink Siri                      search domain[1] : hsd1.wa.comcast.net
   HomeKitLink Siri                      nameserver[0] : 100.100.100.100
   HomeKitLink Siri                      nameserver[1] : fd7a:115c:a1e0::53
   HomeKitLink Siri                      if_index : 34 (utun10)
   HomeKitLink Siri                      flags    : Supplemental, Request A records, Request AAAA records
   HomeKitLink Siri                      reach    : 0x00000003 (Reachable,Transient Connection)
   HomeKitLink Siri                      order    : 101800
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #2
   HomeKitLink Siri                      nameserver[0] : 216.146.35.35
   HomeKitLink Siri                      nameserver[1] : 216.146.36.36
   HomeKitLink Siri                      flags    : Request A records, Request AAAA records
   HomeKitLink Siri                      reach    : 0x00000002 (Reachable)
   HomeKitLink Siri                      order    : 200000
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #3
   HomeKitLink Siri                      domain   : tail97c2bb.ts.net.
   HomeKitLink Siri                      order    : 101801
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #4
   HomeKitLink Siri                      domain   : local
   HomeKitLink Siri                      options  : mdns
   HomeKitLink Siri                      timeout  : 5
   HomeKitLink Siri                      reach    : 0x00000000 (Not Reachable)
   HomeKitLink Siri                      order    : 300000
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #5
   HomeKitLink Siri                      domain   : 254.169.in-addr.arpa
   HomeKitLink Siri                      order    : 300200
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #6
   HomeKitLink Siri                      domain   : 8.e.f.ip6.arpa
   HomeKitLink Siri                      order    : 300400
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #7
   HomeKitLink Siri                      domain   : 9.e.f.ip6.arpa
   HomeKitLink Siri                      order    : 300600
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #8
   HomeKitLink Siri                      domain   : a.e.f.ip6.arpa
   HomeKitLink Siri                      order    : 300800
   HomeKitLink Siri
   HomeKitLink Siri                    resolver #9
   HomeKitLink Siri                      domain   : b.e.f.ip6.arpa
   HomeKitLink Siri                      order    : 301000
   HomeKitLink Siri
   HomeKitLink Siri                    DNS configuration (for scoped queries)
   HomeKitLink Siri
   HomeKitLink Siri                      search domain[0] : hsd1.wa.comcast.net
   HomeKitLink Siri                      if_index : 17 (en0)
   HomeKitLink Siri                      flags    : Scoped, Request A records, Request AAAA records
   HomeKitLink Siri
   HomeKitLink Siri                      nameserver[0] : 2601:603:301:82fb:dea4:caff:fe5b:8c4d
   HomeKitLink Siri                      nameserver[1] : 10.0.1.1
   HomeKitLink Siri                      if_index : 19 (en1)
   HomeKitLink Siri                      reach    : 0x00020002 (Reachable,Directly Reachable Address)
   HomeKitLink Siri
   HomeKitLink Siri                  --- ifconfig (Network Interfaces) ---
   HomeKitLink Siri                    lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
   HomeKitLink Siri                    	options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
   HomeKitLink Siri                    	inet 127.0.0.1 netmask 0xff000000
   HomeKitLink Siri                    	inet6 ::1 prefixlen 128
   HomeKitLink Siri                    	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
   HomeKitLink Siri                    	nd6 options=201<PERFORMNUD,DAD>
   HomeKitLink Siri                    gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
   HomeKitLink Siri                    stf0: flags=0<> mtu 1280
   HomeKitLink Siri                    anpi2: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	options=400<CHANNEL_IO>
   HomeKitLink Siri                    	ether 36:bc:70:20:41:a3
   HomeKitLink Siri                    	media: none
   HomeKitLink Siri                    	status: inactive
   HomeKitLink Siri                    anpi3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:bc:70:20:41:a4
   HomeKitLink Siri                    anpi0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:bc:70:20:41:a1
   HomeKitLink Siri                    anpi1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:bc:70:20:41:a2
   HomeKitLink Siri                    en6: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:bc:70:20:41:81
   HomeKitLink Siri                    en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:bc:70:20:41:82
   HomeKitLink Siri                    en8: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:bc:70:20:41:83
   HomeKitLink Siri                    en9: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:bc:70:20:41:84
   HomeKitLink Siri                    en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	options=460<TSO4,TSO6,CHANNEL_IO>
   HomeKitLink Siri                    	ether 36:e3:59:02:c4:80
   HomeKitLink Siri                    	media: autoselect <full-duplex>
   HomeKitLink Siri                    en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:e3:59:02:c4:84
   HomeKitLink Siri                    en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:e3:59:02:c4:88
   HomeKitLink Siri                    en5: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 36:e3:59:02:c4:8c
   HomeKitLink Siri                    en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	options=567<RXCSUM,TXCSUM,VLAN_MTU,TSO4,TSO6,AV,CHANNEL_IO>
   HomeKitLink Siri                    	ether 9c:76:0e:4c:d4:02
   HomeKitLink Siri                    	inet6 fe80::4bd:49ee:cb2b:292e%en0 prefixlen 64 secured scopeid 0x11
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:1002:adcb:42c7:c8ca prefixlen 64 autoconf secured
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:10aa:ca61:e83c:688b prefixlen 64 deprecated autoconf temporary
   HomeKitLink Siri                    	inet 10.0.1.11 netmask 0xffffff00 broadcast 10.0.1.255
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:7822:aea2:523d:ec51 prefixlen 64 deprecated autoconf temporary
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:1192:8030:80af:5db0 prefixlen 64 deprecated autoconf temporary
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:ed86:ce8a:aab3:4000 prefixlen 64 deprecated autoconf temporary
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:188d:ced5:6b80:8d83 prefixlen 64 autoconf temporary
   HomeKitLink Siri                    	media: autoselect (10Gbase-T <full-duplex>)
   HomeKitLink Siri                    	status: active
   HomeKitLink Siri                    ap1: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 72:36:cf:44:20:95
   HomeKitLink Siri                    	media: autoselect (none)
   HomeKitLink Siri                    en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
   HomeKitLink Siri                    	ether d6:8b:7b:0d:7a:27
   HomeKitLink Siri                    	inet6 fe80::1400:8c38:ab2e:6634%en1 prefixlen 64 secured scopeid 0x13
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:ce3:b8ae:6409:ebd6 prefixlen 64 autoconf secured
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:4845:a15e:6c06:f0e2 prefixlen 64 deprecated autoconf temporary
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:5c89:33a1:ef84:f646 prefixlen 64 deprecated autoconf temporary
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:281f:3b0a:c5f2:798a prefixlen 64 deprecated autoconf temporary
   HomeKitLink Siri                    	inet 10.0.1.9 netmask 0xffffff00 broadcast 10.0.1.255
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:34d2:ab35:d566:e5a5 prefixlen 64 deprecated autoconf temporary
   HomeKitLink Siri                    	inet6 2601:603:301:82fb:341d:d66c:a70e:63ff prefixlen 64 autoconf temporary
   HomeKitLink Siri                    bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	options=63<RXCSUM,TXCSUM,TSO4,TSO6>
   HomeKitLink Siri                    	Configuration:
   HomeKitLink Siri                    		id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
   HomeKitLink Siri                    		maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
   HomeKitLink Siri                    		root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
   HomeKitLink Siri                    		ipfilter disabled flags 0x0
   HomeKitLink Siri                    	member: en2 flags=3<LEARNING,DISCOVER>
   HomeKitLink Siri                    	        ifmaxaddr 0 port 12 priority 0 path cost 0
   HomeKitLink Siri                    	member: en3 flags=3<LEARNING,DISCOVER>
   HomeKitLink Siri                    	        ifmaxaddr 0 port 13 priority 0 path cost 0
   HomeKitLink Siri                    	member: en4 flags=3<LEARNING,DISCOVER>
   HomeKitLink Siri                    	        ifmaxaddr 0 port 14 priority 0 path cost 0
   HomeKitLink Siri                    	member: en5 flags=3<LEARNING,DISCOVER>
   HomeKitLink Siri                    	        ifmaxaddr 0 port 15 priority 0 path cost 0
   HomeKitLink Siri                    	media: <unknown type>
   HomeKitLink Siri                    awdl0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	ether 9a:ad:95:d1:aa:ba
   HomeKitLink Siri                    	inet6 fe80::98ad:95ff:fed1:aaba%awdl0 prefixlen 64 scopeid 0x15
   HomeKitLink Siri                    llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	inet6 fe80::98ad:95ff:fed1:aaba%llw0 prefixlen 64 scopeid 0x16
   HomeKitLink Siri                    utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
   HomeKitLink Siri                    	inet6 fe80::77c7:dfea:3cec:e073%utun0 prefixlen 64 scopeid 0x17
   HomeKitLink Siri                    utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
   HomeKitLink Siri                    	inet6 fe80::575:4bd3:5019:50c4%utun1 prefixlen 64 scopeid 0x18
   HomeKitLink Siri                    utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
   HomeKitLink Siri                    	inet6 fe80::9ac:4432:ee58:1ed0%utun2 prefixlen 64 scopeid 0x19
   HomeKitLink Siri                    utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
   HomeKitLink Siri                    	inet6 fe80::ce81:b1c:bd2c:69e%utun3 prefixlen 64 scopeid 0x1a
   HomeKitLink Siri                    utun5: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
   HomeKitLink Siri                    	inet6 fe80::c64f:9535:fae1:23ac%utun5 prefixlen 64 scopeid 0x1c
   HomeKitLink Siri                    utun6: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
   HomeKitLink Siri                    	inet6 fe80::86e2:8496:9298:c9a7%utun6 prefixlen 64 scopeid 0x1d
   HomeKitLink Siri                    utun7: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
   HomeKitLink Siri                    	inet6 fe80::f24:f167:d70e:b986%utun7 prefixlen 64 scopeid 0x1e
   HomeKitLink Siri                    utun8: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
   HomeKitLink Siri                    	inet6 fe80::2410:2b11:a983:212f%utun8 prefixlen 64 scopeid 0x1f
   HomeKitLink Siri                    utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
   HomeKitLink Siri                    utun9: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
   HomeKitLink Siri                    en10: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
   HomeKitLink Siri                    	options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
   HomeKitLink Siri                    	ether ac:87:a3:38:9e:68
   HomeKitLink Siri                    utun10: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1280
   HomeKitLink Siri                    	inet6 fe80::9e76:eff:fe4c:d402%utun10 prefixlen 64 scopeid 0x22
   HomeKitLink Siri                    	inet 100.84.110.91 --> 100.84.110.91 netmask 0xffffffff
   HomeKitLink Siri                    	inet6 fd7a:115c:a1e0::1001:6ebf prefixlen 48
   HomeKitLink Siri                  --- networksetup -listallhardwareports ---
   HomeKitLink Siri                    Hardware Port: Ethernet
   HomeKitLink Siri                    Device: en0
   HomeKitLink Siri                    Ethernet Address: 9c:76:0e:4c:d4:02
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Display Ethernet
   HomeKitLink Siri                    Device: en10
   HomeKitLink Siri                    Ethernet Address: ac:87:a3:38:9e:68
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Ethernet Adapter (en6)
   HomeKitLink Siri                    Device: en6
   HomeKitLink Siri                    Ethernet Address: 36:bc:70:20:41:81
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Ethernet Adapter (en7)
   HomeKitLink Siri                    Device: en7
   HomeKitLink Siri                    Ethernet Address: 36:bc:70:20:41:82
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Ethernet Adapter (en8)
   HomeKitLink Siri                    Device: en8
   HomeKitLink Siri                    Ethernet Address: 36:bc:70:20:41:83
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Ethernet Adapter (en9)
   HomeKitLink Siri                    Device: en9
   HomeKitLink Siri                    Ethernet Address: 36:bc:70:20:41:84
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Thunderbolt Bridge
   HomeKitLink Siri                    Device: bridge0
   HomeKitLink Siri                    Ethernet Address: 36:e3:59:02:c4:80
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Wi-Fi
   HomeKitLink Siri                    Ethernet Address: 9c:76:0e:36:3c:a1
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Thunderbolt 1
   HomeKitLink Siri                    Device: en2
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Thunderbolt 2
   HomeKitLink Siri                    Device: en3
   HomeKitLink Siri                    Ethernet Address: 36:e3:59:02:c4:84
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Thunderbolt 3
   HomeKitLink Siri                    Device: en4
   HomeKitLink Siri                    Ethernet Address: 36:e3:59:02:c4:88
   HomeKitLink Siri
   HomeKitLink Siri                    Hardware Port: Thunderbolt 4
   HomeKitLink Siri                    Device: en5
   HomeKitLink Siri                    Ethernet Address: 36:e3:59:02:c4:8c
   HomeKitLink Siri
   HomeKitLink Siri                    VLAN Configurations
   HomeKitLink Siri                =================================================== mDNSResponder Diagnostics ====================================================
   HomeKitLink Siri                  --- Check mDNSResponder process ---
   HomeKitLink Siri                    210 mDNSResponder
   HomeKitLink Siri                    260 mDNSResponderHe
   HomeKitLink Siri                  --- mDNSResponder process details (ps) ---
   HomeKitLink Siri                      210     1   0.1  0.1 04-13:43:42 /usr/sbin/mDNSResponder
   HomeKitLink Siri                      260     1   0.0  0.0 04-13:43:42 /usr/sbin/mDNSResponderHelper
   HomeKitLink Siri                  --- mDNSResponderHelper process ---
   HomeKitLink Siri                  --- mDNSResponder recent logs (last 2m, errors/faults) ---
   HomeKitLink Siri                    Timestamp               Ty Process[PID:TID]
   HomeKitLink Siri                  --- mDNSResponder recent logs (last 30s, all levels incl. info) ---
   HomeKitLink Siri                    2026-05-24 20:02:03.625 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157982] DNSServiceQueryRecord START -- qname: <mask.hash: '9wpV7MBSeXzzwoMWake1Bw=='>, qtype: A, flags: 0x1D000, interface index: 0, client pid: 36265 (Google Chrome H), name hash: 23a7572e
   HomeKitLink Siri                    2026-05-24 20:02:03.625 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157982->Q50684] Question for <mask.hash: '9wpV7MBSeXzzwoMWake1Bw=='> (Addr) assigned DNS service -- id: 213, type: Do53, source: sc, scope: none, interface: utun10/34, servers: {<IPv4:BBjlhvkc>:53, [<IPv6:BBwduhFp>]:53}, domains: {BBvgHJAA (102001), . (102000)}, attributes: {a-ok, aaaa-ok}, interface properties: {ipv4, ipv6, vpn}, use count: 1
   HomeKitLink Siri                    2026-05-24 20:02:03.626 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157983] DNSServiceQueryRecord START -- qname: <mask.hash: '9wpV7MBSeXzzwoMWake1Bw=='>, qtype: AAAA, flags: 0x1D000, interface index: 0, client pid: 36265 (Google Chrome H), name hash: 23a7572e
   HomeKitLink Siri                    2026-05-24 20:02:03.626 Df mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q50684] Sent 37-byte query #1 to <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0xA057 (41047), flags: 0x0100 (Q/Query, RD, NoError), counts: 1/0/0/0, BBtzZVVO IN A?
   HomeKitLink Siri                    2026-05-24 20:02:03.626 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157983->Q32572] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:03.626 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157983->Q32572] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: 23a7572e, type: AAAA, rdata: <mask.hash: 'k/BGjB4ekWUcSSTMZtV7Yg=='>
   HomeKitLink Siri                    2026-05-24 20:02:03.660 Df mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q50684] Received acceptable 53-byte response from <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0xA057 (41047), flags: 0x8180 (R/Query, RD, RA, NoError), counts: 1/1/0/0, BBtzZVVO IN A?, 105 IN A BBFXGRSC
   HomeKitLink Siri                    2026-05-24 20:02:03.660 I  mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q50684] Querier concluded -- reason: response
   HomeKitLink Siri                    2026-05-24 20:02:03.660 Df mDNSResponder[210:8170a2] [com.apple.mDNSResponder:Default] [Q50684] Handling concluded querier: BBtzZVVO A IN
   HomeKitLink Siri                    2026-05-24 20:02:03.660 Df mDNSResponder[210:8170a2] [com.apple.mDNSResponder:Default] mDNSCoreReceiveCacheCheck: rescuing RR with new TTL 133: <mask.hash: 'gUyxzvy5U7vbdgG7SKd1KQ=='>
   HomeKitLink Siri                    2026-05-24 20:02:03.660 Df mDNSResponder[210:8170a2] [com.apple.mDNSResponder:Default] [R157982->Q50684] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: 23a7572e, type: A, rdata: <mask.hash: 'hRyOvEAZf8EhSq84VuWiqA=='>
   HomeKitLink Siri                    2026-05-24 20:02:03.661 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157982] DNSServiceQueryRecord STOP -- name hash: 23a7572e, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:03.661 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157983] DNSServiceQueryRecord STOP -- name hash: 23a7572e, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:08.690 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(32bc9a06, bb71815d)] Received a previous IPv6 mDNS query from <mask.hash: 'tjk0iKS1+fRQf2sVBBnvvA=='> over unicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:08.690 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(32bc9a06, a56f4cab)] Received a previous IPv4 mDNS query from <mask.hash: 'X9g3fM4CYYJK0C66cCe9XA=='> over unicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:08.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(d37ce733, 8abf7c89)] Received a previous IPv4 mDNS query from <mask.hash: 'X9g3fM4CYYJK0C66cCe9XA=='> over multicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:08.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(d37ce733, 1e3cfc07)] Received a previous IPv6 mDNS query from <mask.hash: 'tjk0iKS1+fRQf2sVBBnvvA=='> over multicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:08.723 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(e0ff17b4, e9cd0600)] Sent a previous IPv4 mDNS response to <mask.hash: 'X9g3fM4CYYJK0C66cCe9XA=='> over unicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:08.786 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(d37ce733, 88bf7963)] Received a previous IPv4 mDNS query from <mask.hash: 'X9g3fM4CYYJK0C66cCe9XA=='> over multicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:08.786 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(d37ce733, 203cff2d)] Received a previous IPv6 mDNS query from <mask.hash: 'tjk0iKS1+fRQf2sVBBnvvA=='> over multicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:08.842 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(32bc9a06, b1c4d97b)] Received a previous IPv4 mDNS query from <mask.hash: 'X9g3fM4CYYJK0C66cCe9XA=='> over unicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:08.842 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(32bc9a06, b9717e37)] Received a previous IPv6 mDNS query from <mask.hash: 'tjk0iKS1+fRQf2sVBBnvvA=='> over unicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:08.880 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(33bd7a8e, 85ce4208)] Sent a previous IPv4 mDNS response to <mask.hash: 'X9g3fM4CYYJK0C66cCe9XA=='> over unicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:09.635 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157984] DNSServiceQueryRecord START -- qname: <mask.hash: 'vgROUrYg53BdqGa5vhFoSQ=='>, qtype: A, flags: 0x1D000, interface index: 0, client pid: 8397 (Spotify Helper), name hash: 1650e6a
   HomeKitLink Siri                    2026-05-24 20:02:09.636 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157984->Q1688] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:09.636 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157984->Q1688] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: 1650e6a, type: CNAME, rdata: <mask.hash: 'WHKHLAXc8PsYcidjazTN0w=='>
   HomeKitLink Siri                    2026-05-24 20:02:09.636 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [Q1688] AnswerQuestionByFollowingCNAME: following CNAME referral -- CNAME: <mask.hash: 'j3XSmP+OCnMV+xQhKtVjwA=='>, referral count: 0
   HomeKitLink Siri                    2026-05-24 20:02:09.636 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157984->Q13978] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:09.637 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157985] DNSServiceQueryRecord START -- qname: <mask.hash: 'vgROUrYg53BdqGa5vhFoSQ=='>, qtype: AAAA, flags: 0x1D000, interface index: 0, client pid: 8397 (Spotify Helper), name hash: 1650e6a
   HomeKitLink Siri                    2026-05-24 20:02:09.637 Df mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q13978] Sent 48-byte query #1 to <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0x9068 (36968), flags: 0x0100 (Q/Query, RD, NoError), counts: 1/0/0/0, BBdQqTTO IN A?
   HomeKitLink Siri                    2026-05-24 20:02:09.637 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157985->Q60398] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:09.637 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157985->Q60398] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: 1650e6a, type: CNAME, rdata: <mask.hash: 'WHKHLAXc8PsYcidjazTN0w=='>
   HomeKitLink Siri                    2026-05-24 20:02:09.637 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [Q60398] AnswerQuestionByFollowingCNAME: following CNAME referral -- CNAME: <mask.hash: 'j3XSmP+OCnMV+xQhKtVjwA=='>, referral count: 0
   HomeKitLink Siri                    2026-05-24 20:02:09.637 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157985->Q25295] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:09.638 Df mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q25295] Sent 48-byte query #1 to <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0x2306 (8966), flags: 0x0100 (Q/Query, RD, NoError), counts: 1/0/0/0, BBdQqTTO IN AAAA?
   HomeKitLink Siri                    2026-05-24 20:02:09.668 Df mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q13978] Received acceptable 64-byte response from <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0x9068 (36968), flags: 0x8180 (R/Query, RD, RA, NoError), counts: 1/1/0/0, BBdQqTTO IN A?, 99 IN A BBwQMVad
   HomeKitLink Siri                    2026-05-24 20:02:09.668 I  mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q13978] Querier concluded -- reason: response
   HomeKitLink Siri                    2026-05-24 20:02:09.668 Df mDNSResponder[210:8172a2] [com.apple.mDNSResponder:Default] [Q13978] Handling concluded querier: BBdQqTTO A IN
   HomeKitLink Siri                    2026-05-24 20:02:09.669 Df mDNSResponder[210:8172a2] [com.apple.mDNSResponder:Default] [R157984->Q13978] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: 923f245e, type: A, rdata: <mask.hash: 'VLekIeh4b6BJgTQlMWax3Q=='>
   HomeKitLink Siri                    2026-05-24 20:02:09.672 Df mDNSResponder[210:8172a2] [com.apple.mdns:resolver] [Q25295] Received acceptable 76-byte response from <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0x2306 (8966), flags: 0x8180 (R/Query, RD, RA, NoError), counts: 1/1/0/0, BBdQqTTO IN AAAA?, 142 IN AAAA BBQzePmL
   HomeKitLink Siri                    2026-05-24 20:02:09.672 I  mDNSResponder[210:8172a2] [com.apple.mdns:resolver] [Q25295] Querier concluded -- reason: response
   HomeKitLink Siri                    2026-05-24 20:02:09.672 Df mDNSResponder[210:8170a2] [com.apple.mDNSResponder:Default] [Q25295] Handling concluded querier: BBdQqTTO AAAA IN
   HomeKitLink Siri                    2026-05-24 20:02:09.672 Df mDNSResponder[210:8170a2] [com.apple.mDNSResponder:Default] [R157985->Q25295] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: 923f245e, type: AAAA, rdata: <mask.hash: 'H2hiAUyOYmFY1YPYdMMFXg=='>
   HomeKitLink Siri                    2026-05-24 20:02:09.673 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157984] DNSServiceQueryRecord STOP -- name hash: 923f245e, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:09.673 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157985] DNSServiceQueryRecord STOP -- name hash: 923f245e, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:14.412 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [R157986] DNSServiceBrowse START -- service type: <mask.hash: 'hMvfcqJATQ88ffHMgK5UIQ=='>, domain: <mask.hash: 'sRBjZtHFfE5i1giDFVGl7w=='>, flags: 0x0, interface index: 0, client pid: 52240 (dns-sd),
   HomeKitLink Siri                    2026-05-24 20:02:14.415 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [R157986] DNSServiceBrowse -> SubBrowser START -- qname: <mask.hash: 'Phd8Qho72B1AKRBYntjjjw=='> (a5336bb)
   HomeKitLink Siri                    2026-05-24 20:02:14.416 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [R157986->mDNS] DNSServiceBrowse result -- event: add, expired: no, ifindex: 17, name hash: a5336bb, type: PTR, rdata: <mask.hash: 'qr/Ku6iCPGs0qQjxaGTBxw=='>
   HomeKitLink Siri                    2026-05-24 20:02:14.416 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [R157986->mDNS] DNSServiceBrowse result -- event: add, expired: no, ifindex: 19, name hash: a5336bb, type: PTR, rdata: <mask.hash: 'qr/Ku6iCPGs0qQjxaGTBxw=='>
   HomeKitLink Siri                    2026-05-24 20:02:19.553 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157987] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: A, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:19.554 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157987->Q8435] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:19.555 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157988] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: AAAA, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:19.555 Df mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q8435] Sent 43-byte query #1 to <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0xA495 (42133), flags: 0x0100 (Q/Query, RD, NoError), counts: 1/0/0/0, BBKoAduT IN A?
   HomeKitLink Siri                    2026-05-24 20:02:19.555 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157988->Q51209] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:19.556 Df mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q51209] Sent 43-byte query #1 to <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0xD8B3 (55475), flags: 0x0100 (Q/Query, RD, NoError), counts: 1/0/0/0, BBKoAduT IN AAAA?
   HomeKitLink Siri                    2026-05-24 20:02:19.613 Df mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q51209] Received acceptable 130-byte response from <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0xD8B3 (55475), flags: 0x8180 (R/Query, RD, RA, NoError), counts: 1/0/1/0, BBKoAduT IN AAAA?, 300 IN SOA BBJCPgxj BBjbxUTi 1 7200 900 1209600 86400
   HomeKitLink Siri                    2026-05-24 20:02:19.613 I  mDNSResponder[210:8170a2] [com.apple.mdns:resolver] [Q51209] Querier concluded -- reason: response
   HomeKitLink Siri                    2026-05-24 20:02:19.613 Df mDNSResponder[210:8170a2] [com.apple.mDNSResponder:Default] [Q51209] Handling concluded querier: BBKoAduT AAAA IN
   HomeKitLink Siri                    2026-05-24 20:02:19.613 Df mDNSResponder[210:8170a2] [com.apple.mDNSResponder:Default] [R157988->Q51209] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: AAAA, rdata: <none>
   HomeKitLink Siri                    2026-05-24 20:02:19.613 Df mDNSResponder[210:817307] [com.apple.mdns:resolver] [Q8435] Received acceptable 107-byte response from <IPv4:BBjlhvkc> over UDP via utun10/34 -- id: 0xA495 (42133), flags: 0x8180 (R/Query, RD, RA, NoError), counts: 1/4/0/0, BBKoAduT IN A?, 60 IN A BBxLYuRM, 60 IN A BBXfwpOv, 60 IN A BBKulUXu, 60 IN A BBUTaFNt
   HomeKitLink Siri                    2026-05-24 20:02:19.613 I  mDNSResponder[210:817307] [com.apple.mdns:resolver] [Q8435] Querier concluded -- reason: response
   HomeKitLink Siri                    2026-05-24 20:02:19.614 Df mDNSResponder[210:817307] [com.apple.mDNSResponder:Default] [Q8435] Handling concluded querier: BBKoAduT A IN
   HomeKitLink Siri                    2026-05-24 20:02:19.614 Df mDNSResponder[210:817307] [com.apple.mDNSResponder:Default] [R157987->Q8435] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'WW7MHQ0ssfs0C0IZidZURA=='>
   HomeKitLink Siri                    2026-05-24 20:02:19.614 Df mDNSResponder[210:817307] [com.apple.mDNSResponder:Default] [R157987->Q8435] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'bv+EFNHV2PVr/EoO9yoY3g=='>
   HomeKitLink Siri                    2026-05-24 20:02:19.614 Df mDNSResponder[210:817307] [com.apple.mDNSResponder:Default] [R157987->Q8435] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ItqDx3vIDRUkZSphKt7Jbg=='>
   HomeKitLink Siri                    2026-05-24 20:02:19.614 Df mDNSResponder[210:817307] [com.apple.mDNSResponder:Default] [R157987->Q8435] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ZRm+ftkD6jjBhkg+imNBQw=='>
   HomeKitLink Siri                    2026-05-24 20:02:19.614 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157987] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:19.614 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157988] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:19.985 I  mDNSResponder[210:817307] [com.apple.network:] nw_channel_create_block_invoke Channel destroyed with key: 8E3A777F-A562-4439-BC38-DFEF5377BE39-8 and fd: 1218
   HomeKitLink Siri                    2026-05-24 20:02:20.407 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [R157986] DNSServiceBrowse STOP -- name hash: a5336bb, duration: 6s
   HomeKitLink Siri                    2026-05-24 20:02:20.690 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157989] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: A, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:20.690 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157989->Q61280] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157990] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: AAAA, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157990->Q39522] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157989->Q61280] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'WW7MHQ0ssfs0C0IZidZURA=='>
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157989->Q61280] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'bv+EFNHV2PVr/EoO9yoY3g=='>
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157989->Q61280] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ItqDx3vIDRUkZSphKt7Jbg=='>
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157989->Q61280] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ZRm+ftkD6jjBhkg+imNBQw=='>
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157990->Q39522] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: AAAA, rdata: <none>
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157989] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:20.691 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157990] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:21.760 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157991] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: A, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:21.761 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157991->Q12148] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:21.762 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157992] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: AAAA, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:21.763 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157992->Q51044] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:21.763 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157991->Q12148] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'WW7MHQ0ssfs0C0IZidZURA=='>
   HomeKitLink Siri                    2026-05-24 20:02:21.763 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157991->Q12148] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'bv+EFNHV2PVr/EoO9yoY3g=='>
   HomeKitLink Siri                    2026-05-24 20:02:21.763 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157991->Q12148] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ItqDx3vIDRUkZSphKt7Jbg=='>
   HomeKitLink Siri                    2026-05-24 20:02:21.763 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157991->Q12148] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ZRm+ftkD6jjBhkg+imNBQw=='>
   HomeKitLink Siri                    2026-05-24 20:02:21.763 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157992->Q51044] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: AAAA, rdata: <none>
   HomeKitLink Siri                    2026-05-24 20:02:21.763 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157991] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:21.763 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157992] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:22.843 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157993] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: A, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:22.844 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157993->Q47451] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:22.845 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157994] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: AAAA, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:22.845 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157994->Q50569] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:22.846 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157993->Q47451] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'WW7MHQ0ssfs0C0IZidZURA=='>
   HomeKitLink Siri                    2026-05-24 20:02:22.846 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157993->Q47451] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'bv+EFNHV2PVr/EoO9yoY3g=='>
   HomeKitLink Siri                    2026-05-24 20:02:22.846 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157993->Q47451] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ItqDx3vIDRUkZSphKt7Jbg=='>
   HomeKitLink Siri                    2026-05-24 20:02:22.846 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157993->Q47451] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ZRm+ftkD6jjBhkg+imNBQw=='>
   HomeKitLink Siri                    2026-05-24 20:02:22.846 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157994->Q50569] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: AAAA, rdata: <none>
   HomeKitLink Siri                    2026-05-24 20:02:22.846 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157993] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:22.846 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157994] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:23.658 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(32bc9a06, 6d0024e2)] Received a previous IPv4 mDNS query from <mask.hash: '1/zA2vJYheQg1RQbVye/aw=='> over unicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:23.658 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(32bc9a06, dd4b686a)] Received a previous IPv4 mDNS query from <mask.hash: '1/zA2vJYheQg1RQbVye/aw=='> over unicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:23.659 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(d37ce733, 5b031f8)] Received a previous IPv4 mDNS query from <mask.hash: '1/zA2vJYheQg1RQbVye/aw=='> over multicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:23.659 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(32bc9a06, bb71815d)] Received a previous IPv6 mDNS query over unicast
   HomeKitLink Siri                    2026-05-24 20:02:23.659 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(32bc9a06, b9717e37)] Received a previous IPv6 mDNS query over unicast
   HomeKitLink Siri                    2026-05-24 20:02:23.659 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(d37ce733, 1e3cfc07)] Received a previous IPv6 mDNS query over multicast
   HomeKitLink Siri                    2026-05-24 20:02:23.699 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(e2242acd, 7c0686e0)] Sent a previous IPv4 mDNS response over multicast via lo0/1
   HomeKitLink Siri                    2026-05-24 20:02:23.699 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(e2242acd, 3916cfe0)] Sent a previous IPv6 mDNS response over multicast via lo0/1
   HomeKitLink Siri                    2026-05-24 20:02:23.699 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(e2242acd, 8c06a010)] Sent a previous IPv4 mDNS response over multicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:23.700 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(e2242acd, 4916e910)] Sent a previous IPv6 mDNS response over multicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:23.700 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(e2242acd, 8e06a336)] Sent a previous IPv4 mDNS response over multicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:23.700 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(e2242acd, 4b16ec36)] Sent a previous IPv6 mDNS response over multicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:23.850 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(d37ce733, 7b0351e)] Received a previous IPv4 mDNS query from <mask.hash: '1/zA2vJYheQg1RQbVye/aw=='> over multicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:23.850 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(d37ce733, 203cff2d)] Received a previous IPv6 mDNS query over multicast
   HomeKitLink Siri                    2026-05-24 20:02:23.971 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(1e66c87b, dac6b04c)] Received a previous IPv6 mDNS query from <mask.hash: 'X9GBdjY4JAnmIvXslzLpZw=='> over unicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:23.972 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(f47ad3e5, 6c3285ef)] Sent a previous IPv6 mDNS response to <mask.hash: 'X9GBdjY4JAnmIvXslzLpZw=='> over unicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:23.972 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(1e66c87b, c2b7d597)] Received a previous IPv4 mDNS query from <mask.hash: '1/zA2vJYheQg1RQbVye/aw=='> over unicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:23.973 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(f47ad3e5, 5b82eff4)] Sent a previous IPv4 mDNS response to <mask.hash: '1/zA2vJYheQg1RQbVye/aw=='> over unicast via en0/17
   HomeKitLink Siri                    2026-05-24 20:02:24.044 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(1e66c87b, f334af87)] Received a previous IPv4 mDNS query from <mask.hash: '1/zA2vJYheQg1RQbVye/aw=='> over unicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:24.044 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(1e66c87b, dcc6b372)] Received a previous IPv6 mDNS query from <mask.hash: 'X9GBdjY4JAnmIvXslzLpZw=='> over unicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:24.044 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:mDNS] [A(f47ad3e5, 5d82f31a)] Sent a previous IPv4 mDNS response to <mask.hash: '1/zA2vJYheQg1RQbVye/aw=='> over unicast via en1/19
   HomeKitLink Siri                    2026-05-24 20:02:24.156 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157995] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: A, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:24.156 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157995->Q20446] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:24.156 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157995->Q20446] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'WW7MHQ0ssfs0C0IZidZURA=='>
   HomeKitLink Siri                    2026-05-24 20:02:24.156 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157995->Q20446] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'bv+EFNHV2PVr/EoO9yoY3g=='>
   HomeKitLink Siri                    2026-05-24 20:02:24.156 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157995->Q20446] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ItqDx3vIDRUkZSphKt7Jbg=='>
   HomeKitLink Siri                    2026-05-24 20:02:24.156 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157995->Q20446] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: A, rdata: <mask.hash: 'ZRm+ftkD6jjBhkg+imNBQw=='>
   HomeKitLink Siri                    2026-05-24 20:02:24.156 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157996] DNSServiceQueryRecord START -- qname: <mask.hash: 'JQ1IN86A96OoV0P1Ud/Frg=='>, qtype: AAAA, flags: 0x1D000, interface index: 0, client pid: 51320 (IndigoPluginHos), name hash: ccdf022c
   HomeKitLink Siri                    2026-05-24 20:02:24.157 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157996->Q4494] Question assigned DNS service 213
   HomeKitLink Siri                    2026-05-24 20:02:24.157 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157996->Q4494] DNSServiceQueryRecord result -- event: add, expired: no, ifindex: 0, name hash: ccdf022c, type: AAAA, rdata: <none>
   HomeKitLink Siri                    2026-05-24 20:02:24.157 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157995] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                    2026-05-24 20:02:24.157 Df mDNSResponder[210:f71] [com.apple.mDNSResponder:Default] [R157996] DNSServiceQueryRecord STOP -- name hash: ccdf022c, duration: 0s
   HomeKitLink Siri                  --- Per-bridge dns-sd service lookup ---
   HomeKitLink Siri                  --- Multicast route for 224.0.0.251 (mDNS) ---
   HomeKitLink Siri                    route to: 224.0.0.251
   HomeKitLink Siri                    destination: 224.0.0.251
   HomeKitLink Siri                      interface: en0
   HomeKitLink Siri                          flags: <UP,HOST,DONE,LLINFO,WASCLONED,MULTICAST,IFSCOPE>
   HomeKitLink Siri                     recvpipe  sendpipe  ssthresh  rtt,msec    rttvar  hopcount      mtu     expire
   HomeKitLink Siri                           0         0         0         0         0         0      1500         0
   HomeKitLink Siri                1. IPVersion.V4Only is strongly recommended since the HAP server is IPv4-only.
   HomeKitLink Siri                2. If bridges are not appearing in Home app, check that mDNSResponder is running (pgrep output above).
   HomeKitLink Siri                   - If mDNSResponder shows high CPU/memory or very short uptime, it may be crash-looping.
   HomeKitLink Siri                   - Try restarting it in Terminal: sudo killall mDNSResponder  (macOS auto-restarts it within seconds)
   HomeKitLink Siri                3. If per-bridge dns-sd lookups fail to resolve, the service is not registered in mDNSResponder.
   HomeKitLink Siri                   - Restart the affected bridge or the entire plugin.
   HomeKitLink Siri                4. If using a custom interface, ensure the IP address is correct and reachable.
   HomeKitLink Siri                5. If the firewall is enabled, ensure HomeKit/Indigo are allowed through the firewall.
   HomeKitLink Siri                6. Verify your bridges appear in the Zeroconf browse with ** THIS PLUGIN ** tag and show [paired].
   HomeKitLink Siri                7. Copy and paste the above log output when reporting mDNS issues for faster troubleshooting.
   HomeKitLink Siri                ============================================ Manual Terminal Commands (require sudo) =============================================
   HomeKitLink Siri                The following commands require root privileges and cannot be run by the plugin.
   HomeKitLink Siri                Open Terminal.app and run them manually for deeper diagnostics:
   HomeKitLink Siri
   HomeKitLink Siri                  sudo tcpdump -i en0 -n port 5353 -v
   HomeKitLink Siri                      Capture live mDNS (port 5353) traffic on your network interface.
   HomeKitLink Siri                      Look for _hap._tcp entries to confirm HAP announcements are being sent/received.
   HomeKitLink Siri                      Optionally pipe through grep:  sudo tcpdump -i en0 -n port 5353 -v 2>&1 | grep -i hap
   HomeKitLink Siri                      Press Ctrl-C to stop. Replace 'en0' with your active interface if different.
   HomeKitLink Siri
   HomeKitLink Siri                  sudo lsof -i UDP:5353
   HomeKitLink Siri                      Show all processes with open UDP sockets on port 5353 (mDNS).
   HomeKitLink Siri                      Helps identify if mDNSResponder or another process is bound to the mDNS port.
   HomeKitLink Siri
   HomeKitLink Siri                  sudo killall mDNSResponder
   HomeKitLink Siri                      Restart mDNSResponder (macOS auto-restarts it within seconds).
   HomeKitLink Siri                      Use if mDNSResponder appears stuck, crash-looping, or has high CPU usage.
   HomeKitLink Siri
   HomeKitLink Siri                  sudo launchctl list com.apple.mDNSResponder
   HomeKitLink Siri                      Check the launchd status of the mDNSResponder service.
   HomeKitLink Siri                      Shows PID, exit status, and whether the service is loaded in the system domain.
   HomeKitLink Siri
   HomeKitLink Siri                  sudo log stream --predicate 'process == "mDNSResponder"' --info --style compact
   HomeKitLink Siri                      Stream live mDNSResponder system logs. Useful to see registration/deregistration events,
   HomeKitLink Siri                      errors, and query activity in real time. Press Ctrl-C to stop.
   HomeKitLink Siri                ==============================================================================================================================================================================================
   HomeKitLink Siri                =============================================================================== mDNS Troubleshooting Complete ================================================================================
cjp767
Re: I've created a problem
Post by cjp767 »
I did a full system restart and my devices have been released. I don't really know what happened. They were trapped after doing the menu item. but they're released now and available for publishing. Thank you for your help and sorry for any confusion.
GlennNZ
Post by GlennNZ »
No problem. Glad you fixed it.
Only thing I can think on is bridge wasn't completed deleted - hence orphaned device removal failed.
Obviously restarted fix that.
Return to “HomeKitLink Siri”
