Very Verbose Logging...how to stop?
eric
Post by eric »
I installed the new version of the plugin today 2022.23.66 and it seems to work well.
Except that the logging is so verbose that it overwhelms my log.
Is there any way to reduce the logging? I have tried the "toggle" function and it seems to have no effect.
Example of logs below. This a constant stream of text.
'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:ce:f0:8b-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights into Extended color light
Hue Lights updateDeviceState dev:Outdoor - Fence Light 6, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 6
Hue Lights dev :Outdoor Lights - Front Portico Light 1 bulb:{'state': {'on': True, 'bri': 254, 'hue': 8347, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 3', 'modelid': 'LCA009', 'manufacturername': 'Signify Netherlands B.V.', 'productname': 'Hue color lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 1680, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:0c:fd:95:bd-0b', 'swversion': '1.76.11', 'swconfigid': '37CD4C0D', 'productid': 'Philips-LCA009-1-A21ECLv1'}
Hue Lights updateDeviceState dev:Outdoor Lights - Front Portico Light 1, state:[]
Hue Lights updateDeviceState into list update Outdoor Lights - Front Portico Light 1
Hue Lights dev :Outdoor Lights - Front Portico Light 2 bulb:{'state': {'on': True, 'bri': 254, 'hue': 8347, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 4', 'modelid': 'LCA009', 'manufacturername': 'Signify Netherlands B.V.', 'productname': 'Hue color lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 1680, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:0c:fd:90:8f-0b', 'swversion': '1.76.11', 'swconfigid': '37CD4C0D', 'productid': 'Philips-LCA009-1-A21ECLv1'}
Hue Lights updateDeviceState dev:Outdoor Lights - Front Portico Light 2, state:[]
Hue Lights updateDeviceState into list update Outdoor Lights - Front Portico Light 2
Hue Lights dev :Outdoor Lights - Front Portico Light 3 bulb:{'state': {'on': True, 'bri': 254, 'hue': 8347, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 5', 'modelid': 'LCA009', 'manufacturername': 'Signify Netherlands B.V.', 'productname': 'Hue color lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 1680, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:0c:fd:92:a9-0b', 'swversion': '1.76.11', 'swconfigid': '37CD4C0D', 'productid': 'Philips-LCA009-1-A21ECLv1'}
Hue Lights updateDeviceState dev:Outdoor Lights - Front Portico Light 3, state:[]
Hue Lights updateDeviceState into list update Outdoor Lights - Front Portico Light 3
Hue Lights dev :Outdoor - Extension Light 1 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': '1980-01-01T01:11:31'}, 'type': 'Extended color light', 'name': 'Hue color lamp 1', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:4e:1d:9b-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Extension Light 1, state:[]
Hue Lights updateDeviceState into list update Outdoor - Extension Light 1
Hue Lights dev :Outdoor - Extension Light 2 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': '1980-01-01T01:28:17'}, 'type': 'Extended color light', 'name': 'Hue color lamp 2', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:51:c7:26-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Extension Light 2, state:[]
Hue Lights updateDeviceState into list update Outdoor - Extension Light 2
Hue Lights dev :Outdoor - Fence Light 1 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color Lamp 1', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:51:ca:8a-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 1, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 1
Hue Lights dev :Outdoor - Fence Light 2 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color Lamp 2', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:4e:17:d3-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 2, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 2
Hue Lights dev :Outdoor - Fence Light 3 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 1', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:cc:90:59-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 3, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 3
Hue Lights dev :Outdoor - Fence Light 4 bulb:{'state': {'on': False, 'bri': 1, 'hue': 0, 'sat': 0, 'effect': 'none', 'xy': [0.3804, 0.3768], 'ct': 247, 'alert': 'none', 'colormode': 'hs', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 2', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color light', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:cc:90:42-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 4, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 4
Hue Lights dev :Outdoor - Fence Light 5 bulb:{'state': {'on': False, 'bri': 1, 'hue': 0, 'sat': 0, 'effect': 'none', 'xy': [0.3804, 0.3768], 'ct': 247, 'alert': 'none', 'colormode': 'hs', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': '1980-01-01T12:07:06'}, 'type': 'Extended color light', 'name': 'Hue color lamp 3', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:ce:ee:86-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 5, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 5
Hue Lights dev :Outdoor - Fence Light 6 bulb:{'state': {'on': False, 'bri': 1, 'hue': 0, 'sat': 0, 'effect': 'none', 'xy': [0.3804, 0.3768], 'ct': 247, 'alert': 'none', 'colormode': 'hs', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 4', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:ce:f0:8b-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Z-Wave sent "Outdoor Lights - Garage - S" on
Re: Very Verbose Logging...how to stop?
In config at bottom you can set logging
Did that work?
eric
Post by eric »
Hi - Yes, that worked. Thank you!
danielw
Post by danielw »
Im also having this problem since 2 weeks. What settings in the config would remove this?
See previous post.
Switch off debug at bottom of config
Return to “Hue Lights”
