Except that the logging is so verbose that it overwhelms my log.
Is there any way to reduce the logging? I have tried the "toggle" function and it seems to have no effect.
Example of logs below. This a constant stream of text.
'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:ce:f0:8b-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights into Extended color light
Hue Lights updateDeviceState dev:Outdoor - Fence Light 6, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 6
Hue Lights dev :Outdoor Lights - Front Portico Light 1 bulb:{'state': {'on': True, 'bri': 254, 'hue': 8347, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 3', 'modelid': 'LCA009', 'manufacturername': 'Signify Netherlands B.V.', 'productname': 'Hue color lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 1680, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:0c:fd:95:bd-0b', 'swversion': '1.76.11', 'swconfigid': '37CD4C0D', 'productid': 'Philips-LCA009-1-A21ECLv1'}
Hue Lights updateDeviceState dev:Outdoor Lights - Front Portico Light 1, state:[]
Hue Lights updateDeviceState into list update Outdoor Lights - Front Portico Light 1
Hue Lights dev :Outdoor Lights - Front Portico Light 2 bulb:{'state': {'on': True, 'bri': 254, 'hue': 8347, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 4', 'modelid': 'LCA009', 'manufacturername': 'Signify Netherlands B.V.', 'productname': 'Hue color lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 1680, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:0c:fd:90:8f-0b', 'swversion': '1.76.11', 'swconfigid': '37CD4C0D', 'productid': 'Philips-LCA009-1-A21ECLv1'}
Hue Lights updateDeviceState dev:Outdoor Lights - Front Portico Light 2, state:[]
Hue Lights updateDeviceState into list update Outdoor Lights - Front Portico Light 2
Hue Lights dev :Outdoor Lights - Front Portico Light 3 bulb:{'state': {'on': True, 'bri': 254, 'hue': 8347, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 5', 'modelid': 'LCA009', 'manufacturername': 'Signify Netherlands B.V.', 'productname': 'Hue color lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 1680, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:0c:fd:92:a9-0b', 'swversion': '1.76.11', 'swconfigid': '37CD4C0D', 'productid': 'Philips-LCA009-1-A21ECLv1'}
Hue Lights updateDeviceState dev:Outdoor Lights - Front Portico Light 3, state:[]
Hue Lights updateDeviceState into list update Outdoor Lights - Front Portico Light 3
Hue Lights dev :Outdoor - Extension Light 1 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': '1980-01-01T01:11:31'}, 'type': 'Extended color light', 'name': 'Hue color lamp 1', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:4e:1d:9b-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Extension Light 1, state:[]
Hue Lights updateDeviceState into list update Outdoor - Extension Light 1
Hue Lights dev :Outdoor - Extension Light 2 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': '1980-01-01T01:28:17'}, 'type': 'Extended color light', 'name': 'Hue color lamp 2', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:51:c7:26-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Extension Light 2, state:[]
Hue Lights updateDeviceState into list update Outdoor - Extension Light 2
Hue Lights dev :Outdoor - Fence Light 1 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color Lamp 1', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:51:ca:8a-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 1, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 1
Hue Lights dev :Outdoor - Fence Light 2 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color Lamp 2', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'sultanbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:4e:17:d3-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 2, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 2
Hue Lights dev :Outdoor - Fence Light 3 bulb:{'state': {'on': False, 'bri': 1, 'hue': 8348, 'sat': 147, 'effect': 'none', 'xy': [0.462, 0.4111], 'ct': 374, 'alert': 'none', 'colormode': 'ct', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 1', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:cc:90:59-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 3, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 3
Hue Lights dev :Outdoor - Fence Light 4 bulb:{'state': {'on': False, 'bri': 1, 'hue': 0, 'sat': 0, 'effect': 'none', 'xy': [0.3804, 0.3768], 'ct': 247, 'alert': 'none', 'colormode': 'hs', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 2', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color light', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:cc:90:42-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 4, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 4
Hue Lights dev :Outdoor - Fence Light 5 bulb:{'state': {'on': False, 'bri': 1, 'hue': 0, 'sat': 0, 'effect': 'none', 'xy': [0.3804, 0.3768], 'ct': 247, 'alert': 'none', 'colormode': 'hs', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': '1980-01-01T12:07:06'}, 'type': 'Extended color light', 'name': 'Hue color lamp 3', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:ce:ee:86-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Hue Lights updateDeviceState dev:Outdoor - Fence Light 5, state:[]
Hue Lights updateDeviceState into list update Outdoor - Fence Light 5
Hue Lights dev :Outdoor - Fence Light 6 bulb:{'state': {'on': False, 'bri': 1, 'hue': 0, 'sat': 0, 'effect': 'none', 'xy': [0.3804, 0.3768], 'ct': 247, 'alert': 'none', 'colormode': 'hs', 'mode': 'homeautomation', 'reachable': True}, 'swupdate': {'state': 'noupdates', 'lastinstall': None}, 'type': 'Extended color light', 'name': 'Hue color lamp 4', 'modelid': 'LCA003', 'manufacturername': 'Philips', 'productname': 'Hue color Lamp', 'capabilities': {'certified': True, 'control': {'mindimlevel': 200, 'maxlumen': 800, 'colorgamuttype': 'C', 'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], 'ct': {'min': 153, 'max': 500}}, 'streaming': {'renderer': True, 'proxy': True}}, 'config': {'archetype': 'classicbulb', 'function': 'mixed', 'direction': 'omnidirectional', 'startup': {'mode': 'safety'}}, 'uniqueid': '00:17:88:01:09:ce:f0:8b-0b', 'swversion': '1.55.7_r28193', 'swconfigid': '902F6A44', 'productid': 'Philips-LCA003-1-A19ECLv6'}
Z-Wave sent "Outdoor Lights - Garage - S" on
