Logs are gigantic
Different Computers
Logs are gigantic
Post by Different Computers »
Having just installed the new Indigo Log Viewer, I'm able to see that the daily Roku Network Remote logs are literally more than ten times the size of ALL my other logs combined. And this is with debug turned to OFF.
I am getting a daily Roku log of approximately 120Mb!
Here's a sample, which seems to repeat over and over with slight variation.
2025-11-17 00:00:03.458	THREADDEBUG 	Plugin.threaddebug               Command queue has 1 command(s) waiting
2025-11-17 00:00:03.470	DEBUG       	Plugin.concurrent_command_processing_thread Executing full status update request...
2025-11-17 00:00:03.470	THREADDEBUG 	Plugin.threaddebug               Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:03.471	THREADDEBUG 	Plugin.threaddebug               Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:03.471	THREADDEBUG 	Plugin.threaddebug               Command queue has 2 command(s) waiting
2025-11-17 00:00:03.471	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/device-info
2025-11-17 00:00:03.471	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.90:8060/query/device-info
2025-11-17 00:00:03.488	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<device-info>
	<udn>280000c0-0000-1000-8000-38c804a39de1</udn>
	<serial-number>X00300K4EGHL</serial-number>
	<device-id>S05PY214EGHL</device-id>
	<advertising-id>8feecc9b-2b06-5627-b363-4b7072d98e76</advertising-id>
	<user-profile-type>none</user-profile-type>
	<vendor-name>TCL</vendor-name>
	<model-name>75S535</model-name>
	<model-number>A120X</model-number>
	<model-region>US</model-region>
	<is-tv>true</is-tv>
	<is-stick>false</is-stick>
	<screen-size>75</screen-size>
	<panel-id>32</panel-id>
	<mobile-has-live-tv>true</mobile-has-live-tv>
	<ui-resolution>1080p</ui-resolution>
	<tuner-type>ATSC</tuner-type>
	<supports-ethernet>true</supports-ethernet>
	<wifi-mac>38:c8:04:a3:9d:e1</wifi-mac>
	<wifi-driver>realtek</wifi-driver>
	<has-wifi-5G-support>true</has-wifi-5G-support>
	<ethernet-mac>c0:79:82:04:65:3a</ethernet-mac>
	<network-type>ethernet</network-type>
	<friendly-device-name>Bar TV</friendly-device-name>
	<friendly-model-name>TCL•Roku TV</friendly-model-name>
	<default-device-name>TCL•Roku TV - X00300K4EGHL</default-device-name>
	<user-device-name>Bar TV</user-device-name>
	<user-device-location>Bar</user-device-location>
	<build-number>88G.04E05537A</build-number>
	<software-version>15.0.4</software-version>
	<software-build>5537</software-build>
	<lightning-base-build-number />
	<ui-build-number>88G.04E05537A</ui-build-number>
	<ui-software-version>15.0.4</ui-software-version>
	<ui-software-build>5537</ui-software-build>
	<secure-device>true</secure-device>
	<ecp-setting-mode>permissive</ecp-setting-mode>
	<language>en</language>
	<country>US</country>
	<locale>en_US</locale>
	<closed-caption-mode>On</closed-caption-mode>
	<time-zone-auto>true</time-zone-auto>
	<time-zone>US/Eastern</time-zone>
	<time-zone-name>United States/Eastern</time-zone-name>
	<time-zone-tz>America/New_York</time-zone-tz>
	<time-zone-offset>-300</time-zone-offset>
	<clock-format>12-hour</clock-format>
	<uptime>261943</uptime>
	<power-mode>Ready</power-mode>
	<supports-suspend>true</supports-suspend>
	<supports-find-remote>false</supports-find-remote>
	<supports-audio-guide>true</supports-audio-guide>
	<supports-rva>true</supports-rva>
	<has-hands-free-voice-remote>false</has-hands-free-voice-remote>
	<developer-enabled>false</developer-enabled>
	<keyed-developer-id />
	<device-automation-bridge-enabled>false</device-automation-bridge-enabled>
	<search-enabled>true</search-enabled>
	<search-channels-enabled>true</search-channels-enabled>
	<voice-search-enabled>true</voice-search-enabled>
	<supports-private-listening>true</supports-private-listening>
	<private-listening-blocked>false</private-listening-blocked>
	<supports-private-listening-dtv>true</supports-private-listening-dtv>
	<supports-warm-standby>true</supports-warm-standby>
	<headphones-connected>false</headphones-connected>
	<supports-audio-settings>false</supports-audio-settings>
	<expert-pq-enabled>1.0</expert-pq-enabled>
	<supports-ecs-textedit>true</supports-ecs-textedit>
	<supports-ecs-microphone>true</supports-ecs-microphone>
	<supports-wake-on-wlan>true</supports-wake-on-wlan>
	<supports-airplay>true</supports-airplay>
	<has-play-on-roku>true</has-play-on-roku>
	<has-mobile-screensaver>false</has-mobile-screensaver>
	<support-url>support.tcl.com/us</support-url>
	<grandcentral-version>14.15.15</grandcentral-version>
	<supports-trc>true</supports-trc>
	<trc-version>3.0</trc-version>
	<trc-channel-version>13.10.5</trc-channel-version>
	<av-sync-calibration-enabled>3.0</av-sync-calibration-enabled>
</device-info>
2025-11-17 00:00:03.488	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:03.488	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:03.489	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:03.489	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:03.489	DEBUG       	Plugin.update_device_status_info Received device info query response
2025-11-17 00:00:03.489	THREADDEBUG 	Plugin.threaddebug               Queuing TV query commands
2025-11-17 00:00:03.489	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:03.489	THREADDEBUG 	Plugin.threaddebug               Command queue has 2 command(s) waiting
2025-11-17 00:00:03.489	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/active-app
2025-11-17 00:00:03.489	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.90:8060/query/active-app
2025-11-17 00:00:03.499	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<active-app>
	<app id="562859" type="home" version="14.10.5" ui-location="home">Home</app>
</active-app>
2025-11-17 00:00:03.499	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:03.499	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:03.499	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:03.499	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:03.500	DEBUG       	Plugin.update_device_status_info Received active app query response
2025-11-17 00:00:03.500	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:03.500	THREADDEBUG 	Plugin.threaddebug               Command queue has 1 command(s) waiting
2025-11-17 00:00:03.500	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/tv-active-channel
2025-11-17 00:00:03.500	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.90:8060/query/tv-active-channel
2025-11-17 00:00:03.509	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<tv-channel>
	<channel />
</tv-channel>
2025-11-17 00:00:03.509	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:03.509	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:03.509	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:03.509	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:03.510	DEBUG       	Plugin.update_device_status_info Received active channel query response
2025-11-17 00:00:03.510	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:08.885	THREADDEBUG 	Plugin.threaddebug               Command queue has 1 command(s) waiting
2025-11-17 00:00:08.886	DEBUG       	Plugin.concurrent_command_processing_thread Executing full status update request...
2025-11-17 00:00:08.886	THREADDEBUG 	Plugin.threaddebug               Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:08.886	THREADDEBUG 	Plugin.threaddebug               Command queue has 2 command(s) waiting
2025-11-17 00:00:08.886	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/device-info
2025-11-17 00:00:08.886	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.241:8060/query/device-info
2025-11-17 00:00:08.909	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<device-info>
	<udn>296c0029-8809-1063-80fc-1c30080182aa</udn>
	<serial-number>YK00YR615420</serial-number>
	<device-id>JDA09Y615420</device-id>
	<advertising-id>3daba213-adee-5b01-9acf-0b5620d6b674</advertising-id>
	<model-name>32S327</model-name>
	<model-number>8116X</model-number>
	<is-tv>true</is-tv>
	<screen-size>32</screen-size>
	<panel-id>19</panel-id>
	<ui-resolution>720p</ui-resolution>
	<supports-ethernet>false</supports-ethernet>
	<wifi-mac>1c:30:08:01:82:aa</wifi-mac>
	<network-type>wifi</network-type>
	<network-name>Not Found</network-name>
	<friendly-device-name>TCL•Roku TV - YK00YR615420</friendly-device-name>
	<default-device-name>TCL•Roku TV - YK00YR615420</default-device-name>
	<user-device-name />
	<user-device-location />
	<build-number>48G.04E05534A</build-number>
	<software-build>5534</software-build>
	<ui-build-number>48G.04E05534A</ui-build-number>
	<ui-software-build>5534</ui-software-build>
	<ecp-setting-mode>enabled</ecp-setting-mode>
	<closed-caption-mode>Instant replay</closed-caption-mode>
	<uptime>117033</uptime>
	<grandcentral-version>14.14.16</grandcentral-version>
</device-info>
2025-11-17 00:00:08.909	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:08.909	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:08.909	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:08.909	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:08.909	DEBUG       	Plugin.update_device_status_info Received device info query response
2025-11-17 00:00:08.909	THREADDEBUG 	Plugin.threaddebug               Queuing TV query commands
2025-11-17 00:00:08.909	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:08.909	THREADDEBUG 	Plugin.threaddebug               Command queue has 2 command(s) waiting
2025-11-17 00:00:08.909	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/active-app
2025-11-17 00:00:08.909	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.241:8060/query/active-app
2025-11-17 00:00:08.923	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<active-app>
	<app id="562859" type="home" version="14.10.5" ui-location="home">Roku Dynamic Menu</app>
</active-app>
2025-11-17 00:00:08.923	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:08.923	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:08.923	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:08.923	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:08.923	DEBUG       	Plugin.update_device_status_info Received active app query response
2025-11-17 00:00:08.923	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:08.923	THREADDEBUG 	Plugin.threaddebug               Command queue has 1 command(s) waiting
2025-11-17 00:00:08.923	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/tv-active-channel
2025-11-17 00:00:08.923	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.241:8060/query/tv-active-channel
2025-11-17 00:00:08.938	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<tv-channel>
	<channel />
</tv-channel>
2025-11-17 00:00:08.938	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:08.938	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:08.938	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:08.938	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:08.938	DEBUG       	Plugin.update_device_status_info Received active channel query response
2025-11-17 00:00:08.938	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:13.525	THREADDEBUG 	Plugin.threaddebug               Command queue has 1 command(s) waiting
2025-11-17 00:00:13.526	DEBUG       	Plugin.concurrent_command_processing_thread Executing full status update request...
2025-11-17 00:00:13.527	THREADDEBUG 	Plugin.threaddebug               Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:13.528	THREADDEBUG 	Plugin.threaddebug               Command queue has 2 command(s) waiting
2025-11-17 00:00:13.528	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/device-info
2025-11-17 00:00:13.528	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.90:8060/query/device-info
2025-11-17 00:00:13.545	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<device-info>
	<is-tv>true</is-tv>
	<uptime>261953</uptime>
</device-info>
2025-11-17 00:00:13.545	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:13.545	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:13.545	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:13.545	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:13.546	DEBUG       	Plugin.update_device_status_info Received device info query response
2025-11-17 00:00:13.546	THREADDEBUG 	Plugin.threaddebug               Queuing TV query commands
2025-11-17 00:00:13.546	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:13.546	THREADDEBUG 	Plugin.threaddebug               Command queue has 2 command(s) waiting
2025-11-17 00:00:13.547	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/active-app
2025-11-17 00:00:13.547	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.90:8060/query/active-app
2025-11-17 00:00:13.556	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<active-app>
</active-app>
2025-11-17 00:00:13.556	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:13.556	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:13.556	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:13.556	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:13.556	DEBUG       	Plugin.update_device_status_info Received active app query response
2025-11-17 00:00:13.557	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:13.557	THREADDEBUG 	Plugin.threaddebug               Command queue has 1 command(s) waiting
2025-11-17 00:00:13.557	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/tv-active-channel
2025-11-17 00:00:13.557	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.90:8060/query/tv-active-channel
2025-11-17 00:00:13.566	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<tv-channel>
	<channel />
</tv-channel>
2025-11-17 00:00:13.567	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:13.567	THREADDEBUG 	Plugin.threaddebug               Checking Action updateRokuStatus  response against updateRokuStatus
2025-11-17 00:00:13.567	THREADDEBUG 	Plugin.threaddebug               Found response match: updateRokuStatus
2025-11-17 00:00:13.567	DEBUG       	Plugin.execute_effects           Effect execution: Calling function update_device_status_info
2025-11-17 00:00:13.567	DEBUG       	Plugin.update_device_status_info Received active channel query response
2025-11-17 00:00:13.567	THREADDEBUG 	Plugin.threaddebug               RESTFUL_GET command response processing completed
2025-11-17 00:00:18.956	THREADDEBUG 	Plugin.threaddebug               Command queue has 1 command(s) waiting
2025-11-17 00:00:18.957	DEBUG       	Plugin.concurrent_command_processing_thread Executing full status update request...
2025-11-17 00:00:18.957	THREADDEBUG 	Plugin.threaddebug               Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:18.957	THREADDEBUG 	Plugin.threaddebug               Command queue has 2 command(s) waiting
2025-11-17 00:00:18.957	DEBUG       	Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/device-info
2025-11-17 00:00:18.957	THREADDEBUG 	Plugin.threaddebug               Full URL for GET: http://192.168.0.241:8060/query/device-info
2025-11-17 00:00:18.983	THREADDEBUG 	Plugin.threaddebug               Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<device-info>
and so on for 115+ Mb. per day.
RogueProeliator
Re: Logs are gigantic
Post by RogueProeliator »
What version are you using, I do not think that is the latest... I just checked mine and with 3 Roku devices defined I am at 20% of that size on the latest plugin. And that will probably get some refinement from there too.
How many Roku devices do you have?
Different Computers
Two TVs.
I was a version behind but I updated last night as I noticed the problem.
Return to “Roku Network Remote”
