I am getting a daily Roku log of approximately 120Mb!
Here's a sample, which seems to repeat over and over with slight variation.
2025-11-17 00:00:03.458 THREADDEBUG Plugin.threaddebug Command queue has 1 command(s) waiting
2025-11-17 00:00:03.470 DEBUG Plugin.concurrent_command_processing_thread Executing full status update request...
2025-11-17 00:00:03.470 THREADDEBUG Plugin.threaddebug Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:03.471 THREADDEBUG Plugin.threaddebug Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:03.471 THREADDEBUG Plugin.threaddebug Command queue has 2 command(s) waiting
2025-11-17 00:00:03.471 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/device-info
2025-11-17 00:00:03.471 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.90:8060/query/device-info
2025-11-17 00:00:03.488 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<device-info>
<udn>280000c0-0000-1000-8000-38c804a39de1</udn>
<serial-number>X00300K4EGHL</serial-number>
<device-id>S05PY214EGHL</device-id>
<advertising-id>8feecc9b-2b06-5627-b363-4b7072d98e76</advertising-id>
<user-profile-type>none</user-profile-type>
<vendor-name>TCL</vendor-name>
<model-name>75S535</model-name>
<model-number>A120X</model-number>
<model-region>US</model-region>
<is-tv>true</is-tv>
<is-stick>false</is-stick>
<screen-size>75</screen-size>
<panel-id>32</panel-id>
<mobile-has-live-tv>true</mobile-has-live-tv>
<ui-resolution>1080p</ui-resolution>
<tuner-type>ATSC</tuner-type>
<supports-ethernet>true</supports-ethernet>
<wifi-mac>38:c8:04:a3:9d:e1</wifi-mac>
<wifi-driver>realtek</wifi-driver>
<has-wifi-5G-support>true</has-wifi-5G-support>
<ethernet-mac>c0:79:82:04:65:3a</ethernet-mac>
<network-type>ethernet</network-type>
<friendly-device-name>Bar TV</friendly-device-name>
<friendly-model-name>TCL•Roku TV</friendly-model-name>
<default-device-name>TCL•Roku TV - X00300K4EGHL</default-device-name>
<user-device-name>Bar TV</user-device-name>
<user-device-location>Bar</user-device-location>
<build-number>88G.04E05537A</build-number>
<software-version>15.0.4</software-version>
<software-build>5537</software-build>
<lightning-base-build-number />
<ui-build-number>88G.04E05537A</ui-build-number>
<ui-software-version>15.0.4</ui-software-version>
<ui-software-build>5537</ui-software-build>
<secure-device>true</secure-device>
<ecp-setting-mode>permissive</ecp-setting-mode>
<language>en</language>
<country>US</country>
<locale>en_US</locale>
<closed-caption-mode>On</closed-caption-mode>
<time-zone-auto>true</time-zone-auto>
<time-zone>US/Eastern</time-zone>
<time-zone-name>United States/Eastern</time-zone-name>
<time-zone-tz>America/New_York</time-zone-tz>
<time-zone-offset>-300</time-zone-offset>
<clock-format>12-hour</clock-format>
<uptime>261943</uptime>
<power-mode>Ready</power-mode>
<supports-suspend>true</supports-suspend>
<supports-find-remote>false</supports-find-remote>
<supports-audio-guide>true</supports-audio-guide>
<supports-rva>true</supports-rva>
<has-hands-free-voice-remote>false</has-hands-free-voice-remote>
<developer-enabled>false</developer-enabled>
<keyed-developer-id />
<device-automation-bridge-enabled>false</device-automation-bridge-enabled>
<search-enabled>true</search-enabled>
<search-channels-enabled>true</search-channels-enabled>
<voice-search-enabled>true</voice-search-enabled>
<supports-private-listening>true</supports-private-listening>
<private-listening-blocked>false</private-listening-blocked>
<supports-private-listening-dtv>true</supports-private-listening-dtv>
<supports-warm-standby>true</supports-warm-standby>
<headphones-connected>false</headphones-connected>
<supports-audio-settings>false</supports-audio-settings>
<expert-pq-enabled>1.0</expert-pq-enabled>
<supports-ecs-textedit>true</supports-ecs-textedit>
<supports-ecs-microphone>true</supports-ecs-microphone>
<supports-wake-on-wlan>true</supports-wake-on-wlan>
<supports-airplay>true</supports-airplay>
<has-play-on-roku>true</has-play-on-roku>
<has-mobile-screensaver>false</has-mobile-screensaver>
<support-url>support.tcl.com/us</support-url>
<grandcentral-version>14.15.15</grandcentral-version>
<supports-trc>true</supports-trc>
<trc-version>3.0</trc-version>
<trc-channel-version>13.10.5</trc-channel-version>
<av-sync-calibration-enabled>3.0</av-sync-calibration-enabled>
</device-info>
2025-11-17 00:00:03.488 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:03.488 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:03.489 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:03.489 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:03.489 DEBUG Plugin.update_device_status_info Received device info query response
2025-11-17 00:00:03.489 THREADDEBUG Plugin.threaddebug Queuing TV query commands
2025-11-17 00:00:03.489 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:03.489 THREADDEBUG Plugin.threaddebug Command queue has 2 command(s) waiting
2025-11-17 00:00:03.489 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/active-app
2025-11-17 00:00:03.489 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.90:8060/query/active-app
2025-11-17 00:00:03.499 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<active-app>
<app id="562859" type="home" version="14.10.5" ui-location="home">Home</app>
</active-app>
2025-11-17 00:00:03.499 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:03.499 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:03.499 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:03.499 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:03.500 DEBUG Plugin.update_device_status_info Received active app query response
2025-11-17 00:00:03.500 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:03.500 THREADDEBUG Plugin.threaddebug Command queue has 1 command(s) waiting
2025-11-17 00:00:03.500 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/tv-active-channel
2025-11-17 00:00:03.500 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.90:8060/query/tv-active-channel
2025-11-17 00:00:03.509 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<tv-channel>
<channel />
</tv-channel>
2025-11-17 00:00:03.509 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:03.509 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:03.509 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:03.509 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:03.510 DEBUG Plugin.update_device_status_info Received active channel query response
2025-11-17 00:00:03.510 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:08.885 THREADDEBUG Plugin.threaddebug Command queue has 1 command(s) waiting
2025-11-17 00:00:08.886 DEBUG Plugin.concurrent_command_processing_thread Executing full status update request...
2025-11-17 00:00:08.886 THREADDEBUG Plugin.threaddebug Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:08.886 THREADDEBUG Plugin.threaddebug Command queue has 2 command(s) waiting
2025-11-17 00:00:08.886 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/device-info
2025-11-17 00:00:08.886 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.241:8060/query/device-info
2025-11-17 00:00:08.909 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<device-info>
<udn>296c0029-8809-1063-80fc-1c30080182aa</udn>
<serial-number>YK00YR615420</serial-number>
<device-id>JDA09Y615420</device-id>
<advertising-id>3daba213-adee-5b01-9acf-0b5620d6b674</advertising-id>
<model-name>32S327</model-name>
<model-number>8116X</model-number>
<is-tv>true</is-tv>
<screen-size>32</screen-size>
<panel-id>19</panel-id>
<ui-resolution>720p</ui-resolution>
<supports-ethernet>false</supports-ethernet>
<wifi-mac>1c:30:08:01:82:aa</wifi-mac>
<network-type>wifi</network-type>
<network-name>Not Found</network-name>
<friendly-device-name>TCL•Roku TV - YK00YR615420</friendly-device-name>
<default-device-name>TCL•Roku TV - YK00YR615420</default-device-name>
<user-device-name />
<user-device-location />
<build-number>48G.04E05534A</build-number>
<software-build>5534</software-build>
<ui-build-number>48G.04E05534A</ui-build-number>
<ui-software-build>5534</ui-software-build>
<ecp-setting-mode>enabled</ecp-setting-mode>
<closed-caption-mode>Instant replay</closed-caption-mode>
<uptime>117033</uptime>
<grandcentral-version>14.14.16</grandcentral-version>
</device-info>
2025-11-17 00:00:08.909 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:08.909 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:08.909 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:08.909 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:08.909 DEBUG Plugin.update_device_status_info Received device info query response
2025-11-17 00:00:08.909 THREADDEBUG Plugin.threaddebug Queuing TV query commands
2025-11-17 00:00:08.909 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:08.909 THREADDEBUG Plugin.threaddebug Command queue has 2 command(s) waiting
2025-11-17 00:00:08.909 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/active-app
2025-11-17 00:00:08.909 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.241:8060/query/active-app
2025-11-17 00:00:08.923 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<active-app>
<app id="562859" type="home" version="14.10.5" ui-location="home">Roku Dynamic Menu</app>
</active-app>
2025-11-17 00:00:08.923 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:08.923 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:08.923 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:08.923 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:08.923 DEBUG Plugin.update_device_status_info Received active app query response
2025-11-17 00:00:08.923 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:08.923 THREADDEBUG Plugin.threaddebug Command queue has 1 command(s) waiting
2025-11-17 00:00:08.923 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/tv-active-channel
2025-11-17 00:00:08.923 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.241:8060/query/tv-active-channel
2025-11-17 00:00:08.938 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<tv-channel>
<channel />
</tv-channel>
2025-11-17 00:00:08.938 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:08.938 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:08.938 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:08.938 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:08.938 DEBUG Plugin.update_device_status_info Received active channel query response
2025-11-17 00:00:08.938 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:13.525 THREADDEBUG Plugin.threaddebug Command queue has 1 command(s) waiting
2025-11-17 00:00:13.526 DEBUG Plugin.concurrent_command_processing_thread Executing full status update request...
2025-11-17 00:00:13.527 THREADDEBUG Plugin.threaddebug Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:13.528 THREADDEBUG Plugin.threaddebug Command queue has 2 command(s) waiting
2025-11-17 00:00:13.528 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/device-info
2025-11-17 00:00:13.528 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.90:8060/query/device-info
2025-11-17 00:00:13.545 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<device-info>
<is-tv>true</is-tv>
<uptime>261953</uptime>
</device-info>
2025-11-17 00:00:13.545 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:13.545 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:13.545 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:13.545 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:13.546 DEBUG Plugin.update_device_status_info Received device info query response
2025-11-17 00:00:13.546 THREADDEBUG Plugin.threaddebug Queuing TV query commands
2025-11-17 00:00:13.546 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:13.546 THREADDEBUG Plugin.threaddebug Command queue has 2 command(s) waiting
2025-11-17 00:00:13.547 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/active-app
2025-11-17 00:00:13.547 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.90:8060/query/active-app
2025-11-17 00:00:13.556 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<active-app>
</active-app>
2025-11-17 00:00:13.556 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:13.556 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:13.556 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:13.556 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:13.556 DEBUG Plugin.update_device_status_info Received active app query response
2025-11-17 00:00:13.557 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:13.557 THREADDEBUG Plugin.threaddebug Command queue has 1 command(s) waiting
2025-11-17 00:00:13.557 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/tv-active-channel
2025-11-17 00:00:13.557 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.90:8060/query/tv-active-channel
2025-11-17 00:00:13.566 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<tv-channel>
<channel />
</tv-channel>
2025-11-17 00:00:13.567 THREADDEBUG Plugin.threaddebug RESTFUL_GET command completed; beginning response processing
2025-11-17 00:00:13.567 THREADDEBUG Plugin.threaddebug Checking Action updateRokuStatus response against updateRokuStatus
2025-11-17 00:00:13.567 THREADDEBUG Plugin.threaddebug Found response match: updateRokuStatus
2025-11-17 00:00:13.567 DEBUG Plugin.execute_effects Effect execution: Calling function update_device_status_info
2025-11-17 00:00:13.567 DEBUG Plugin.update_device_status_info Received active channel query response
2025-11-17 00:00:13.567 THREADDEBUG Plugin.threaddebug RESTFUL_GET command response processing completed
2025-11-17 00:00:18.956 THREADDEBUG Plugin.threaddebug Command queue has 1 command(s) waiting
2025-11-17 00:00:18.957 DEBUG Plugin.concurrent_command_processing_thread Executing full status update request...
2025-11-17 00:00:18.957 THREADDEBUG Plugin.threaddebug Returning default GUIConfigValue for rokuRemoteDevice: deviceIsChildDevice
2025-11-17 00:00:18.957 THREADDEBUG Plugin.threaddebug Command queue has 2 command(s) waiting
2025-11-17 00:00:18.957 DEBUG Plugin.concurrent_command_processing_thread Processing GET operation: http|*|/query/device-info
2025-11-17 00:00:18.957 THREADDEBUG Plugin.threaddebug Full URL for GET: http://192.168.0.241:8060/query/device-info
2025-11-17 00:00:18.983 THREADDEBUG Plugin.threaddebug Command Response: [200] <?xml version="1.0" encoding="UTF-8" ?>
<device-info>
