Ungroup Zones?
racarter
Ungroup Zones?
Post by racarter »
Just installed this and it's working perfectly. One question I have; is there a way of 'ungrouping' zones after you've grouped them? Am I missing something obvious? Apologies if so!
Example: If I'm listening to something in the living room but I need to go to the kitchen for a while I can create a group of living room and kitchen, which works fine. But when I'm finished in the kitchen I want to stop playback in the kitchen when I return to the living room.
autolog
Re: Ungroup Zones?
Post by autolog »
No, you aren't missing anything, apart from the ungroup functionality that is!
The 'ungroup' isn't defined as an Action in the plugin at the moment.
I have just taken a quick look; just need to work out the best way of doing it and then I can add it in.
Give me a week or so and I will get round to adding the Ungroup in for you. :)
racarter
Re: Ungroup Zones?
Post by racarter »
Sterling service! Thank you :D
autolog
Re: Ungroup Zones?
Post by autolog »
As requested, I have added in the Ungroup Zone Action.
Pre-release version is available here: Roon Controller Version 2025.1.1
Try it out and let me know how you get on. :)
racarter
Re: Ungroup Zones?
Post by racarter »
Hi Jon
Works perfectly! Many thanks. :D
Alan
racarter
Re: Ungroup Zones?
Post by racarter »
Slight snag. Every time a new track starts, I get the following:
11 Oct 2025 at 16:39:17
Roon Error '[Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/Roon.indigoPlugin/Contents/Resources/Artist_Image.png'' in module 'shutil.py', method 'copyfile'
Failing statement [line 256]: 'with open(src, 'rb') as fsrc:'
autolog
Re: Ungroup Zones?
Post by autolog »
Just catching up with your post.
That seems odd as the missing file should be part of the plugin? :?
Can you do a "Show Package Contents" on the plugin and check if the file is present?
racarter
Re: Ungroup Zones?
Post by racarter »
Well that was weird! When I looked in the plugins folder Roon wasn't there, even though the plugin was working (apart from the error messages). When I tried to reinstall it I got a message saying the plugin was faulty and couldn't be installed. I then tried to disable it and got another error message, so I restarted the Indigo server and the plugin had disappeared. I reinstalled it and the folders and files are all present and correct, so I'm expecting no further issues.
Never encountered that one before!
autolog
Re: Ungroup Zones?
Post by autolog »
That's a bit of a mystery - I haven't seen that happen before? :?
Well at least it is back working again for you. :)
Return to “Roon Controller”
