Roku Network Remote Error An error occurred executing the GET/PUT request (Device: 1351401255): 403
NoneType: None
which is no surprise because when I drilled down into the settings for the two TVs I have, both of them had nonsense addresses. They were neither MAC addresses nor IP addresses.
Also, when the plugin tried to discover devices, all it found was about seven different versions of... my Hue Hub!
I've tried restarting the plugin, and redefined the correct IP addresses for the existing devices, but I'm still seeing the error above.
Roku Network Remote Debug ECP command not allowed in Limited mode.
Roku Network Remote Debug Executing full status update request...
Roku Network Remote Debug Processing GET operation: http|*|/query/device-info
Roku Network Remote Debug Effect execution: Calling function update_device_status_info
Roku Network Remote Debug Received device info query response
Roku Network Remote Debug Processing GET operation: http|*|/query/active-app
Roku Network Remote Debug Received active app query response
Roku Network Remote Debug Processing GET operation: http|*|/query/tv-active-channel
Roku Network Remote Debug Received active channel query response
Roku Network Remote Error An error occurred executing the GET/PUT request (Device: 1351231255): 403
NoneType: None
Suggestions on how to resolve this? I've restarted the plugin to no effect.
My other TV is working properly.
Looks like this was fundamentally a problem with the TV. The "network remotes" setting spontaneously changed to OFF instead of ENABLED. When I dug down and found then changed this, the Indigo plugin started communicating with it again.
Very odd, as this TV hadn't even had batteries in the remote for the past 3 months, so no way this setting could have been changed by fumble fingers. Had to have either been the TV's software glitching, or a TV software update reverting it.
I'm still wondering why the Roku plugin detects my Hue Hub as a Roku device, but that's much more a matter of surprise and curiosity than a need or a problem.
Same thing in my house with all my Roku TVs. I’m glad you figured it out. After going around the house changing all the settings to “Enabled”, I had to restart the plugin…. everything seems to be communicating fine again.
