So am actively working on the Caddx security panel plugin (...just finished the SDK v3 / Python 3 work). Now that the hood is up and all the tool laid out, would now like it to show up as a HomeKit Security Systems. Not sure what that entails. Could someone give me some hints as to where to start my understanding of what I need to do? Pointing me at some relevant source code would probably do it.
Thx,
Don
Adapting Caddx Panel to work with HomeKitLink Siri
donhoffman
Re: Adapting Caddx Panel to work with HomeKitLink Siri
Hi
Ideally:
2 Plugin -> HomeKitLink issues:
1.
Ideally your plugin will need to report the state of the alarm, or alarm partition in homekit security format - and as a device state within your plugin.
Eg.
Joe had started with Simplisafe plugin - although we haven’t finished integration as yet.
https://github.com/FlyingDiver/Indigo-S ... evices.xml
& state conversion here:
2.
You will within your plugin a ActionGroup that ideally responses to homekit states for HK plugin to change states.
https://github.com/FlyingDiver/Indigo-S ... ctions.xml
3/
I’ll need to add support to HomeKitLink to recognise and support your security device type, running the above action when off, home or away selected.
Hopefully makes sense.
Glenn
Ideally:
1.
Eg.
HK_ALARM_STAY_ARMED = 0
HK_ALARM_AWAY_ARMED = 1
HK_ALARM_NIGHT_ARMED = 2
HK_ALARM_DISARMED = 3
HK_ALARM_TRIGGERED = 4
HOMEKIT_STATE = {
simplipy.system.SystemStates.ALARM: HK_ALARM_TRIGGERED,
simplipy.system.SystemStates.ALARM_COUNT: HK_ALARM_TRIGGERED,
simplipy.system.SystemStates.AWAY: HK_ALARM_AWAY_ARMED,
simplipy.system.SystemStates.AWAY_COUNT: HK_ALARM_AWAY_ARMED,
simplipy.system.SystemStates.ENTRY_DELAY: HK_ALARM_AWAY_ARMED,
simplipy.system.SystemStates.ERROR: HK_ALARM_DISARMED,
simplipy.system.SystemStates.HOME: HK_ALARM_STAY_ARMED,
simplipy.system.SystemStates.HOME_COUNT: HK_ALARM_STAY_ARMED,
simplipy.system.SystemStates.OFF: HK_ALARM_DISARMED,
simplipy.system.SystemStates.TEST: HK_ALARM_DISARMED,
simplipy.system.SystemStates.UNKNOWN: HK_ALARM_DISARMED,
}Code: Select all
<State id="homekit_state" defaultValue="">
<ValueType>Number</ValueType>
<TriggerLabel>HomeKit State</TriggerLabel>
<ControlPageLabel>HomeKit State</ControlPageLabel>
</State>
2.
<Action id="homekit_set_mode" uiPath="hidden">
<CallbackMethod>homekit_set_mode</CallbackMethod>
</Action>
<Action id="set_mode" deviceFilter="self.system">
<Name>Set Mode</Name>
<CallbackMethod>action_set_mode</CallbackMethod>
<ConfigUI>
<Field id="mode" type="menu" defaultValue="away">
<Label>Mode:</Label>
<List>
<Option value="home">Home</Option>
<Option value="away">Away</Option>
</List>
</Field>
</ConfigUI>
</Action>3/
Glenn
donhoffman
Thanks. Extremely helpful. Will be starting on it next week when I am at location with panel.
