Adapting Caddx Panel to work with HomeKitLink Siri
donhoffman
Post by donhoffman »
So am actively working on the Caddx security panel plugin (...just finished the SDK v3 / Python 3 work). Now that the hood is up and all the tool laid out, would now like it to show up as a HomeKit Security Systems. Not sure what that entails. Could someone give me some hints as to where to start my understanding of what I need to do? Pointing me at some relevant source code would probably do it.
Thx,
Don
GlennNZ
Re: Adapting Caddx Panel to work with HomeKitLink Siri
Post by GlennNZ »
Hi
Ideally:
2 Plugin -> HomeKitLink issues:
1.
Ideally your plugin will need to report the state of the alarm, or alarm partition in homekit security format - and as a device state within your plugin.
Eg.
Joe had started with Simplisafe plugin - although we haven’t finished integration as yet.
https://github.com/FlyingDiver/Indigo-S ... evices.xml
& state conversion here:
HK_ALARM_STAY_ARMED = 0
HK_ALARM_AWAY_ARMED = 1
HK_ALARM_NIGHT_ARMED = 2
HK_ALARM_DISARMED = 3
HK_ALARM_TRIGGERED = 4
HOMEKIT_STATE = {
    simplipy.system.SystemStates.ALARM:         HK_ALARM_TRIGGERED,
    simplipy.system.SystemStates.ALARM_COUNT:   HK_ALARM_TRIGGERED,
    simplipy.system.SystemStates.AWAY:          HK_ALARM_AWAY_ARMED,
    simplipy.system.SystemStates.AWAY_COUNT:    HK_ALARM_AWAY_ARMED,
    simplipy.system.SystemStates.ENTRY_DELAY:   HK_ALARM_AWAY_ARMED,
    simplipy.system.SystemStates.ERROR:         HK_ALARM_DISARMED,
    simplipy.system.SystemStates.HOME:          HK_ALARM_STAY_ARMED,
    simplipy.system.SystemStates.HOME_COUNT:    HK_ALARM_STAY_ARMED,
    simplipy.system.SystemStates.OFF:           HK_ALARM_DISARMED,
    simplipy.system.SystemStates.TEST:          HK_ALARM_DISARMED,
    simplipy.system.SystemStates.UNKNOWN:       HK_ALARM_DISARMED,
<State id="homekit_state" defaultValue="">
                <ValueType>Number</ValueType>
                <TriggerLabel>HomeKit State</TriggerLabel>
                <ControlPageLabel>HomeKit State</ControlPageLabel>
            </State>
2.
You will within your plugin a ActionGroup that ideally responses to homekit states for HK plugin to change states.
https://github.com/FlyingDiver/Indigo-S ... ctions.xml
    <Action id="homekit_set_mode" uiPath="hidden">
        <CallbackMethod>homekit_set_mode</CallbackMethod>
    </Action>
    <Action id="set_mode" deviceFilter="self.system">
        <Name>Set Mode</Name>
        <CallbackMethod>action_set_mode</CallbackMethod>
        <ConfigUI>
            <Field id="mode" type="menu" defaultValue="away">
                <Label>Mode:</Label>
                <List>
                    <Option value="home">Home</Option>
                    <Option value="away">Away</Option>
                </List>
            </Field>
        </ConfigUI>
    </Action>
3/
I’ll need to add support to HomeKitLink to recognise and support your security device type, running the above action when off, home or away selected.
Hopefully makes sense.
Glenn
donhoffman
Thanks. Extremely helpful. Will be starting on it next week when I am at location with panel.
Return to “HomeKitLink Siri”
