MyQ is working.....but....
Send status request triggers this log message:
MyQ Warning getDevices failure, status_code = 400
The plug-in works fine but always shows the garage door as "Locked".
Seems to be functioning fine, but unable to update status.
Running
Catalina 10.15.7
Indigo 7.5.0
MyQ Plugin Ver. 7.5.3
Any thoughts?
Running
Catalina 10.15.7
Indigo 7.5.0
Any thoughts?
- FlyingDiver
Re: MyQ is working.....but....
Enable debug logging, restart the plugin, post the log.
And do you mean that you can send commands to open/close the door, but the status never updates?
Thanks for your reply Joe,
Yes, that is correct, functionality is there, but the status never changes and shows Locked status.
Here is the MyQ logging, I opened the door via Indigo at 06:06:25.
It appears that it is unable to get the status code for some odd reason.
It also appears that the last status update was back in December??
Apr 2, 2021 at 6:04:24 PM
Z-Wave received "Outdoor Motion Sensor" status update is on
Z-Wave received "HVAC Exit Air Temperature" temperature update to 76.6 °F
Apr 2, 2021 at 6:05:53 PM
MyQ Debug logLevel = 10
MyQ Debug myqLogin response = {"SecurityToken":"ac862af4-6fc1-4a63-8e0d-82804af18809"}
MyQ Debug myqLogin successful
MyQ Debug statusFrequency = 600.0
MyQ Debug myqLogin response = {"SecurityToken":"a80afef3-3959-4425-9644-c83d069b7046"}
Apr 2, 2021 at 6:06:25 PM
MyQ Debug actionControlDevice: Unlock Garage Door
MyQ Debug myqLogin response = {"SecurityToken":"35980adc-1267-4cfd-a663-ec0cb966d55f"}
MyQ Debug Garage Door: changeDevice: new state = open
MyQ Debug myqLogin response = {"SecurityToken":"f9636ad0-0a80-43c5-a733-a4ea89cc280e"}
- Screen Shot 2021-04-02 at 6.08.36 PM.png (55.04 KiB) Viewed 5313 times
- Screen Shot 2021-04-02 at 6.08.29 PM.png (49.79 KiB) Viewed 5313 times
- FlyingDiver
Try the 7.6.0 pre-release: https://github.com/FlyingDiver/Indigo-M ... /tag/7.6.0
Back up your Indigo database first, in case your devices get messed up.
Read the instructions on GitHub carefully, this is not a drag and drop replacement.
I was having a similar problem ... getting that "400" error. Installed MyQ v 7.60 pre-release and everything seems fine now!
johnofcamas
I updated the the 7.6 pre-release, and when I click 'send status request' I get this error
MyQ Error Error in plugin execution ExecuteAction:
File "plugin.py", line 389, in actionControlDevice
File "plugin.py", line 153, in requestUpdate
File "plugin.py", line 97, in pymyq_write
IOError: (32, 'Broken pipe')
- FlyingDiver
That's the error you get when the Python3 task stops running. The only way to get debug info from that is to restart the plugin in the interactive shell.johnofcamas wrote:I updated the the 7.6 pre-release, and when I click 'send status request' I get this error
MyQ Error Error in plugin execution ExecuteAction: Traceback (most recent call last): File "plugin.py", line 389, in actionControlDevice File "plugin.py", line 153, in requestUpdate File "plugin.py", line 97, in pymyq_write IOError: (32, 'Broken pipe')
johnofcamas
Quit, relaunched Indigo, it's working now
- FlyingDiver
Just restarting the plugin should have been sufficient.johnofcamas wrote:Quit, relaunched Indigo, it's working now
johnofcamas
Kind of.. still showing locked even after it opens: Here's another error:
MyQ Error actionControlDevice: Unsupported action requested: actionValue : ActionProps : (dict)
configured : True
delayAmount : 900
description : unlock device
deviceAction : Unlock
deviceId : 706919280
replaceExisting : True
textToSpeak : for Garage Door
johnofcamas
One more error
MyQ Error Error when trying to close Garage Door Opener: Error requesting data from https://account-devices-gdo.myq-cloud.com/api/v5.2/Accounts/6cc55127-e1d2-4fd8-b3e0-795ea1a15d4c/door_openers/CG086F0978BC/close: 401 - Unauthorized
johnofcamas
And definitely still getting this error:
File "plugin.py", line 375, in actionControlDevice
- FlyingDiver
Honestly, I'm about to deprecate this plugin. It's a reverse engineered API with a lot of issues, and the only existing library for that is Python3, which adds more problems. It's just not worth my time to try to keep this working.
johnofcamas
Understood. Thank you far doing this much
