Error: Invalid literal for int() with base 10:
roquej
Post by roquej »
I am getting this error:
Variable Devices Error exception in deviceStartComm(Temperature (Master-AWAir)): invalid literal for int() with base 10: ''
Variable Devices Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 150, in variableUpdated
ValueError: invalid literal for int() with base 10: ''
The variable is a temperature reading (example 75.6). The variable name is "awair_Master_0_temp"
Ideas?
Thank you!
JP
Re: Error: Invalid literal for int() with base 10:
Something is trying to convert an empty string to an integer. Which doesn't work. Are you sure that variable has an appropriate value in it?
roquej
Post by roquej »
I think so. See image.
Screen Shot 2020-11-12 at 11.02.18 AM.png (185.04 KiB) Viewed 5084 times
How is that variable getting set? Is there a script that's possibly clearing it first, then setting the new value?
roquej
Post by roquej »
Yes, I am using a script. This is the code I am suing to set the value:
varValue = round( float(indigo.devices[awairDevice].states["data_0_sensors_0_value"]) ,1)
indigo.variable.updateValue(awairVarID, value= str(varValue))
awairDevice is a GhostXML feed.
awairVarID is the variable I set and trying to use with Variable Device
Makes sense?
JP
Yeah, that should work. Any particular reason you're doing a two step device -> variable -> device? I think you could probably use the Masquerade plugin to do it in one step. And maybe avoid this error.
roquej
Post by roquej »
Because the "interesting folks" at AWAir have an API that changes its orders list as you check for changes in data. That means I must search the values provided for "temp", in the index, then use that value.
This is the full code:
#type of value
lookValue = "temp"
# define variable ID
awairVarID = "awair_Master_0_temp"
	index0 = str( indigo.devices[awairDevice].states["data_0_sensors_0_comp"] )
	index1 = str( indigo.devices[awairDevice].states["data_0_sensors_1_comp"] )
	index2 = str( indigo.devices[awairDevice].states["data_0_sensors_2_comp"] )
	index3 = str( indigo.devices[awairDevice].states["data_0_sensors_3_comp"] )
	index4 = str( indigo.devices[awairDevice].states["data_0_sensors_4_comp"] )
except:
	indigo.variable.updateValue("awair_Master_status", value="Could not retreive Master temperature data")
	indigo.server.log ("awair_Master_status = " + "Could not retrive Master temperature data")
	exit(0)
if (index0 == lookValue):
elif (index1 == lookValue):
	varValue = round( float(indigo.devices[awairDevice].states["data_0_sensors_1_value"]) ,1)
elif (index2 == lookValue):
	varValue = round( float(indigo.devices[awairDevice].states["data_0_sensors_2_value"]) ,1)
elif (index3 == lookValue):
	varValue = round( float(indigo.devices[awairDevice].states["data_0_sensors_3_value"]) ,1)
	varValue = round(float(indigo.devices[awairDevice].states["data_0_sensors_4_value"]) ,1)
I am not a programmer, so I am sure this code could be much more efficient (if you have any suggestions, it would be appreciated!), but it seems to work. Not sure how to make this work with the Masquerade plugin in this use case.
Any idea what could be causing the problem?
JP
Depending on the input conditions, that script could fail silently. Try this:
#type of value
lookValue = "temp"
except:
    indigo.variable.updateValue("awair_Master_status", value="Could not retrieve Master temperature data")
    indigo.variable.updateValue(awairVarID, value="0.0")
    indigo.server.log ("awair_Master_status = " + "Could not retrieve Master temperature data")
exit(0)
elif (index4 == lookValue):
    varValue = round( float(indigo.devices[awairDevice].states["data_0_sensors_4_value"]) ,1)
    indigo.variable.updateValue("awair_Master_status", value="lookValue not found")
    indigo.server.log ("awair_Master_status = " + "lookValue not found")
    varValue = 0.0
That's still not how I would write it if I were starting from scratch, but it's better. Honestly, given that the data returned doesn't work well with GhostXML, you're probably better off just doing the whole thing in a single Python script and not using the plugin at all.
roquej
Post by roquej »
Thank you for the code suggestion!
Let me try, as that was the first way I tried to address the problem. However, I stopped because had not realized the ordered list kept changing and I thought the incorrect values were my code.
Will report if that takes care of the Variable Device issues.
Again, thank you for all the help and plugins.
JP
howartp
Post by howartp »
roquej wrote:I am getting this error:
Actually, that error is nothing to do with your script (although everything Joe has said is correct).
In your "Variable Device" device, you need to select a valid variable in the "State to display: " box. I suspect it's either blank or an old variable, as my code is returning '' which is the (bad choice of) default value.
I'll fix the plugin to default to 0 instead of '' so that line of code doesn't fail.
Peter
howartp
Post by howartp »
roquej
Post by roquej »
First, I converted everything to using a script and that works great.
Second, I installed 1.05 and the problem solved
Thank all!
JP
Return to “Variable Devices”
