Remote sensor not available in Indigo
I have a new Ecobee thermostat (SmartThermostat with voice control), firmware ver 4.16.15.142, and one remote sensor. I have reloaded the plug-in, but am unable to see the remote sensor.
Have you a suggestion?
Bob
Bob
- FlyingDiver
Re: Remote sensor not available in Indigo
Was the remote sensor added to your system after you created the Indigo device for the thermostat? Have you tried deleting the thermostat and recreating it (making sure the remote sensor checkbox is checked)?
If it's still not working, use the "Write Thermostat Data to Log" menu option (in Plugins->Ecobee 2) and post that output here.
I don't remember when I added the remote sensor.
Deleting the thermostat will delete all my work on schedules, triggers and actions. I'll need a moment to do that. I'll let you know if I can solve the problem by this step.
- FlyingDiver
Wait. I thought you mean that the plugin didn't see the remote sensor, so you couldn't create an Indigo device for it. But you said you did create the device.
Please explain exactly what you have and what you mean by enable to see the sensor.
Post the data from the menu command so I can see what data the plugin is working with.
In the house, I have 1 thermostat and 1 remote device.
Ecobee knows about both the thermostat and the remote device.
When setting up the thermostat, I do not recall whether or not I had the remote device configured with Ecobee when I created the Ecobee connection with Indigo.
Indigo knows about the thermostat, but I am unable to create a device in indigo for the remote sensor.
I hope this clarifies my situation.
- Screen Shot 2020-09-14 at 11.50.57.png (247.51 KiB) Viewed 3676 times
- FlyingDiver
I still need to see the data dump.
Then, set the plugin logging to "Debugging Messages", and go through the steps you're doing now to create the remote sensor device.
Then post the log info as well.
Sep 14, 2020 at 12:03:38 PM
Ecobee 2 Debug logLevel = 10
Ecobee 2 Debug updateFrequency = 900.0
Ecobee 2 Debug setting temperature scale to C
Ecobee 2 Debug Ecobee Account (1428206274): Ecobee Account Update OK, got info on 2 thermostats
Ecobee 2 Debug Ecobee Account (1428206274): getting data for 'Front Hall', 521703550260
Ecobee 2 Debug Ecobee Account (1428206274): getting data for remote sensor 'North Office', C5SW
Ecobee 2 Debug Ecobee Account (1428206274): getting data for 'Stairs', 521781046633
Ecobee 2 Debug Ecobee Front Hall: Updating device
Ecobee 2 Debug Ecobee Front Hall Remote - North Office: Updating device
Ecobee 2 Debug getDeviceFactoryUiValues: devIdList = UiElemIdList : (list)
Ecobee 2 Debug get_device_list: active_stats = [u'521703550260']
Ecobee 2 Debug get_device_list: available_devices for EcobeeThermostat = [(u'521781046633', u'Stairs')]
Ecobee 2 Debug get_account_list: accounts = [(1428206274, u'Ecobee Account (1428206274)')]
Ecobee 2 Debug get_device_list: active_sensors = [u'C5SW']
Ecobee 2 Debug get_device_list: available_devices for RemoteSensor = []
Ecobee 2 Debug closedDeviceFactoryUi: user cancelled
- FlyingDiver
That says you already have an Indigo device for the remote sensor, named 'Ecobee Front Hall Remote - North Office'.
But why can't a create a device in Indigo?
What I am trying to do is use the occupied state as a trigger to monitor inside activity in our home when we are away.
I just discovered that I can do that - the device is available for a trigger and listed as a device when I search for ecobee. What confused me is that the remote sensor wasn't mentioned in the dialogue for creating a new device, while the thermostat was mentioned.
Glad I didn't delete my thermostat.
Thank you for your patience.
- FlyingDiver
You can't create it because it already exists.SMUSEBY wrote:But why can't a create a device in Indigo?
What's probably confusing you is that the occupancy sensor is not created as a separate device. It's the on/off part of the temperature sensor device.SMUSEBY wrote: What I am trying to do is use the occupied state as a trigger to monitor inside activity in our home when we are away.
Correct.
Thanks again.
Thanks again.
