Hello, As per the log, it's asking me to post this message...
Mar 4, 2020 at 9:24:22 PM
LIFX LIFX device discovery starting (this can take up to 60 seconds) . . .
LIFX Error LIFXLAN [discover_devices] discovered an unknown LIFX device with product code: '38'. Device's MAC is 'd0:73:d5:29:45:5c' and IP Address is '192.168.1.76'. Plugin is unable to manage this device. Please report this on the support forum.
LIFX Error Discovery failed to complete for known LIFX Device 'Family Room Left Lamp' [d0:73:d5:2c:55:f9]
LIFX Error Discovery failed to complete for LIFX Device 'Unknown Name' [d0:73:d5:14:84:20]
LIFX
d0:73:d5:29:45:5c = Lifx Beam (61 zones); works with App and Alexa
d0:73:d5:2c:55:f9 Lifx A19, works with App and Alexa
d0:73:d5:14:84:20 = Lifx Z (40 zones); Works Via the Lifx App and Alexa
LIFX device discovery has completed and 7 LIFX device(s) have been successfully discovered.
The number of LIFX devices that failed to complete discovery is 1.
The number of previously known LIFX devices awaiting discovery is 1.
LIFX Device 1: 'Family Room Left Lamp' [d0:73:d5:2c:55:f9] at address 192.168.1.190 on port 56700 - DISCOVERY DID NOT COMPLETE.
LIFX Device 2: 'Right Bedroom Lamp' [d0:73:d5:25:97:4f] discovered at address 192.168.1.201 on port 56700.
LIFX Device 3: 'Bar Spot 1' [d0:73:d5:2c:31:3c] discovered at address 192.168.1.185 on port 56700.
LIFX Device 4: 'Wine Rack' [d0:73:d5:14:9b:8c] discovered at address 192.168.1.14 on port 56700.
LIFX Device 5: 'Right Table Lamp (LIFX)' [d0:73:d5:24:00:d1] discovered at address 192.168.1.152 on port 56700.
LIFX Device 6: 'Left Bedroom Lamp' [d0:73:d5:24:24:d3] discovered at address 192.168.1.242 on port 56700.
LIFX Device 7: 'Bar Spot 2' [d0:73:d5:2c:65:65] discovered at address 192.168.1.186 on port 56700.
LIFX Device 9: 'Guest Room Lamp' [d0:73:d5:2c:35:8b] discovered at address 192.168.1.61 on port 56700.
LIFX Device 10: 'Bar' [d0:73:d5:29:45:5c] is not yet visible on the network and therefore a further discovery is required.
As one or more LIFX devices are still awaiting discovery, another discovery has been scheduled for 1440 minutes time.
Disable undiscovered device(s) if further discoveries are not required.
Running Indigo server 7.4.1 and client 7.4.0
Please advise what else you would know to know.
Chris
Re: LIFXLAN [discover_devices] discovered an unknown LIFX de
Hi Chris,
Thanks for the report.
I have released an update to the Plugin Store which corrects a bug with the LIFX Beam definition which should hopefully now work. I haven't got a LIFX Beam to test with.
Your other discovery problems are probably network issues - possibly with QOS?
See this post: No Ack
If a known device (to Indigo) isn't discovered, the plugin will keep trying discovery. You appear to have set the time between discovery attempts to 1440 minutes = once a day. I recommend that this is set to say 5 minutes. Once all devices are discovered then repeated discoveries will stop. You can then initiate another discovery either by using the action Device Actions > LIFX Controls > Discover LIFX Devices. Alternatively, you could just reload the plugin. If a LIFX device won't be discovered because you have temporarily physically removed it then if you disable communications for the LIFX device (untick Comm Enabled in the main Indigo Device list UI) then the plugin will ignore that device for discovery purposes.
The unknown device name message is because the plugin has received some info about the LIFX device but the data received is incomplete; again this might suggest a (temporary) network issue?
Hope this helps - let me know how you get on with the new version.
Thank you sir! The Beam has been discovered! I'll address the other issues when I get home tonight. Thank you again for the quick response!
Let there be light!
Let there be light!
