AMG8833 sensor i2c address
I've started having a look at the AMG8833 sensor, as a presence detector where a person is stationary - looks like this could work quite well.
A single sensor would work for most rooms, however for larger rooms 2 sensors may be required.
My understanding for these sensors (I'm trying out the Sparkfun Qwiic board) is that the alternative i2c address is 0x68 (the default being 0x69) - however the plugin has the options of 0x69 and 0x6B. Can this be amended to add 0x68?
- Screenshot 2019-06-30 at 13.38.22.png (389.7 KiB) Viewed 5342 times
Re: AMG8833 sensor i2c address
Sure .. later today
When you plugin the sensor do on the rpi
i2cdetect -y 1
It will show you the actual address the sensor uses.
i2cdetect -y 1
posted v .294 with added i2c address.
- Screen Shot 2019-06-30 at 09.23.51.png (51.87 KiB) Viewed 5314 times
Awesome - thanks!
Sensors up and running - now to find a suitable case or mounting...
Updating to v.294 I'm now getting an error in the event log every couple of minutes:
However, this also happens on downgrade to v.293 - but not on v.291
30 Jun 2019 at 20:51:02
piBeacon Warning RPI# 0 check , too many empty messages in a row: 2
piBeacon Warning sending reboot command to RPIRe: AMG8833 sensor i2c address
need a little more info:
could you ssh to the RPi and doalso in config set set debug beacon data ON
tail -f /var/log/piBeacon.logKarl
AND please set ETH and WLAN parameters in config (and in RPI edit). those are new in these versions
Hi - thanks for coming back on this
Beacon data debug set to on..
and it hangs here
ETH and WLAN parameters are as shown in attachment for both config and rPI edit
pi@raspberrypi:~ $ tail -f /var/log/piBeacon.log
UP RUNNING
RX bytes:1581 acl:0 sco:0 events:103 errors:0
TX bytes:5069 acl:0 sco:0 commands:103 errors:0
20190701-21:32:22 beaconloop L:-1= my BLE mac# is : B8:27:EB:B2:3E:A2
20190701-21:32:22 beaconloop L:-1= ble thread started
20190701-21:32:22 beaconloop L:-1= starting loop
20190701-21:32:23 master L:-1= IP find:: IPs#: Indigo>192.168.2.2<; wlan0>192.168.2.40<; eth0><; hostname>['192.168.2.40']<; AddressFile>192.168.2.40<; PKTS(eth0>0,0<; wlan0>73,55<, dTime:4.2)
20190701-21:32:23 master L:-1= Requested Config:{u'wlan0': {u'on': u'on', u'useIP': u'use'}, u'eth0': {u'on': u'off', u'useIP': u'doNotUse'}}
20190701-22:06:22 master L:-1= dosfsck has error (was fixed after boot): fsck.fat 4.1 (2017-01-24)/--/Checking we can access the last sector of the filesystem/--/0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt./--/ Automatically removing dirty bit./--/Boot sector contents:/--/System ID "mkfs.fat"/--/Media byte 0xf8 (hard disk)/--/ 512 bytes per logical sector/--/ 512 bytes per cluster/--/ 32 reserved sectors ETH and WLAN parameters are as shown in attachment for both config and rPI edit
- Screenshot 2019-07-01 at 22.07.39.png (69.44 KiB) Viewed 5185 times
this:
""dosfsck has error (was fixed after boot): fsck.fat 4.1 (2017-01-24)/--/Checking we can access the last sector of the filesystem/--/0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt./--/ Automatically removing dirty bit./--/Boot sector contents:/--/System ID "mkfs.fat"/--/Media byte 0xf8 (hard disk)/--/ 512 bytes per logical sector/--/ 512 bytes per cluster/--/ 32 reserved sectors""
means your ssd has a problem. it was fixed after reboot, but .. ==> so if you have time: make a new SSD
and
ssh to api
cd pibeacon
sudo python master.py
post what's happening
and
ssh to api
cd pibeacon
Thanks - just tried to format and create the SSD, still showing the error so will try a new SSD...
hangs at this point...
pi@raspberrypi:~ $ cd pibeacon
pi@raspberrypi:~/pibeacon $ sudo python master.py
Killed
pi@raspberrypi:~/pibeacon $ 20190701-21:32:42 master L:-1= writing new callbeacon.py file
20190701-21:32:44 master L:-1= START.. indigoServer IP:>>192.168.2.2<<
20190701-21:32:45 master L:-1= Master adhocWifi is:-1 ; G.wifiType is:normal
20190701-21:32:45 master L:-1= IP find:: IPs#: Indigo>192.168.2.2<; wlan0>192.168.2.40<; eth0><; hostname>['192.168.2.40']<; AddressFile>192.168.2.40<; PKTS(eth0>0,<; wlan0>206,<, dTime:99.9)
20190701-21:32:45 master L:-1= Requested Config:{u'wlan0': {u'on': u'on', u'useIP': u'use'}, u'eth0': {u'on': u'off', u'useIP': u'doNotUse'}}
20190701-21:32:46 master L:-1= can ping indigo server at ip:>>192.168.2.2<<
20190701-21:32:46 installLibs L:-1= ==== libraries install finished
20190701-21:32:47 receiveCommands L:-1= started, listening to port: 9999
20190701-21:32:48 master L:-1= IP find:: IPs#: Indigo>192.168.2.2<; wlan0>192.168.2.40<; eth0><; hostname>['192.168.2.40']<; AddressFile>192.168.2.40<; PKTS(eth0>0,0<; wlan0>228,206<, dTime:3.2)
20190701-21:32:48 master L:-1= Requested Config:{u'wlan0': {u'on': u'on', u'useIP': u'use'}, u'eth0': {u'on': u'off', u'useIP': u'doNotUse'}}
20190701-21:32:48 beaconloop L:-1= Beacon Use HCINo -1; useHCI:hci0; myBLEmac:B8:27:EB:B2:3E:A2; devId:0
20190701-21:32:48 beaconloop L:-1= hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 00 C5 00
20190701-21:32:48 beaconloop L:-1= hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20190701-21:32:48 beaconloop L:-1= hcitool -i hci0 cmd 0x08 0x000a 01
20190701-21:32:48 beaconloop L:-1= BLE start returned:
hci0: Type: Primary Bus: UART
BD Address: B8:27:EB:B2:3E:A2 ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING
RX bytes:115142 acl:0 sco:0 events:3523 errors:0
TX bytes:5920 acl:0 sco:0 commands:150 errors:0
20190701-21:32:48 beaconloop L:-1= starting loop
20190701-21:32:48 master L: 1= starting loopRe: AMG8833 sensor i2c address
this looks correct..
next step:
after 10 secs or more after sudo python master.py do :
show which python processes are running:
ps -ef | grep .py
show which messages are send to plugin .. let it run for 2 minutes
tail -F temp/messageSend
(with capital -F not -f)
next step:
ps -ef | grep .py
could we do a chat, instead of 30 min ping pong ..?
eg teamviewer ..?
eg teamviewer ..?
