piBeacon: 18 - RG11 rain sensor setup
The RG11 Rain sensor is an optical sensor with no moving parts. It can measure rain amounts from tiny to very heavy rain.http://hydreon.com/wp-content/uploads/s ... ctions.pdf
It has several modes that can be switched dynamically (through switches/ relays).
sensitivity mode are :
- first rain drop
-bucket sizes of 0.0001" , 0.001" 0.01"
the piBeacon plugin can switch modes dynamically = switch sensitivity with rain amount as well as static ie any rain... 0.01" per measurement (bucket)
In order to fully use the capabilities you need to switch the switches on the rain sensor with eg relays.
The attached drawing shows how to attach a RG11 rain sensor to the RPI through a relay board.
Screen Shot 2018-09-24 at 12.17.47.png (214.32 KiB) Viewed 13663 times
The states of the indigo sensor device look like:
Screen Shot 2018-09-24 at 12.27.10.png (34.73 KiB) Viewed 13663 times
(units in mm]
you can set the rain units and digits in config.
In device edit you can select various timing settings and modes as well as formatting of the status field
The rain amounts can be reset in pibeacon menus under "Reset or Request new data ... "
at each hour/ midnight/ week/ month/ year the amounts shift to lastHour/lastDay...
at midnight Max and Min rain rates are calculated and shifted to lastDay
RG11 next to a common bucket rain sensor
Screen Shot 2018-09-24 at 12.34.13.png (269.33 KiB) Viewed 13659 times
Asconasny
Re: piBeacon: 18 - RG11 rain sensor setup
Post by Asconasny »
This is just perfect! Bought one of these a couple of years ago.
haven´t looked at it since.
Guess this has to be my winter project :)
Appreciate your hard work on this plugin. Thank you
Wouter has it installed. And it seems to work.
Nice feature is you get very fast warning (seconds)when rain starts. Combined with regular rain count.
And here in TX we have 15” rain an hour rain rates ( though not lasting 1 hour) and it works.
Asconasny
Post by Asconasny »
nice :)
The fast warning was why i bought it. If i have something, or my wife is doing anything outside that dont like water we have a chance to save it before it gets soaked.
The rain count is a nice option, i didnt have plans for using this, but now when you have made the schematics and all i have to do the whole setup :D
WouterK
Post by WouterK »
Yes, It is a Nice sensor :D
Like Karl already said it reacts very fast, is accurate and makes a very good combination with the pibeacon plugin!
in Dallas: this morning the rain sensor choked (*)
at 254mm/h = 10inches/hour rain
Now back down to 2mm/hour
The rain total today is 10cm = 4 inches so far ( in about 4 hours)
(*) had to reset the sensor = power cycle
Asconasny
Post by Asconasny »
Still havent got around fiddeling with this, :oops: but i noticed the 52pi relay addon, would this setup work with a 52pi hat? That would be a nice setup.
not in the current form, but I can adopt that.
currently it sets the relays through GPIO on/off.
that board uses i2c to set them, not a big deal to add that.
I actually really like that board well done, good software support, good docu. only draw back is only 3Amps current.
For this app you only need mAmps.
so if you decide to try that version I can add it quickly
Asconasny
Post by Asconasny »
Ive placed a order for a couple of the relays when i saw they got supported i pibeacon, Figured it could be nice to have on a rainy day :)
If its not to much trouble to add the option it would be perfect to use one of them on the rain sensor instead of the relay board.
It is done ~ 1 hour, but not tested, if you could try, I hesitate to rip mine apart
52pi relay hard wired setup:
relay 4 = 12V
relay 3 = dip switch 5
relay 2 = dip switch 2
relay 1 = dip switch 1
will publish this week, need to test some other things
Asconasny
Post by Asconasny »
wow, that was fast, :shock:
I haven't received mine yet, ordered from China so i guess it will take a while.
will test when i get them
did a dry run and the relays click in the right way w artificially created rain (connecting the gpio-IN pin to ground / off frequently)
It goes through sensitivity cycle with relay clicks the proper way: check if rain / high/med/low sensitivity and back
and for your relay you just need to see if anything can still leave China .. :lol:
Return to “piBeacon”
