Are we able to set PINs from a variable?
eric
Post by eric »
I can't see to find a way to set PINs from a variable. Am I missing something?
If not, I think this feature would be a great addition - it would allow a series of variables, one per user, containing PINs to be changed from Indigo Touch and automatically updated in the locks, using triggers.
howartp
Re: Are we able to set PINs from a variable?
Post by howartp »
Oooooh!
How long have you been able to modify variables in Touch?!?!?!
Sorry, back on topic.
I can’t remember whether I implemented this or not.
If I did, then you set the pin value in the action to be something like %v:123456% where 12346 is the variable ID in Indigo.
Lookup variable substitution in the Indigo docs if you’re at a pc; I’m on phone and not back till later.
Peter
durosity
Post by durosity »
howartp wrote:Oooooh!
At least a couple of years. Quite possibly longer than that!
I just looked at the code. String substitution has not been implemented.
howartp
Post by howartp »
howartp wrote:If I did, then you set the pin value in the action to be something like %v:123456% where 12346 is the variable ID in Indigo.
Right, grab 1.0.50 then enter the following in the Set Pin action:
%%v:123456%%
Where 123456 is the variable ID from Indigo.
The v is case-sensitive.
Peter
eric
Post by eric »
That was an amazingly quick response. Trying it now.
howartp
Post by howartp »
It only took 17 characters of coding! :-)
mat
Post by mat »
I only count 12 :twisted: :mrgreen:
Late 2018 mini 10.14
howartp
Post by howartp »
mat wrote:I only count 12 :twisted: :mrgreen:
Self.Substitute()
eric
Post by eric »
This all works very well - I have ten variables and each contains a PIN. If I change any one of them (either on the desktop or Touch) then the lock is instantly updated with the new PIN.
There's one thing that's stumping me: I would like to be able to make a variable blank (empty) and have indigo delete that PIN. Currently when you make a variable blank it simply leaves the same PIN functioning.
Any thought on how to program this in Indigo?
eric
Post by eric »
Figured it out - never mind.
When writing the new PIN using the trigger, I first delete the pin, then write it. So a blank variable will result in a deleted PIN.
howartp
Post by howartp »
Hehe, yep that will work.
I was also going to say yes it can be done easily - I’ll intercept a blank pin in the setPin() routine in code, and redirect to clearPin() instead when it sees blank.
chrisfromthelc
Post by chrisfromthelc »
I'm unable to set a PIN from a variable.
I can read the PIN just fine.
Action Group                    Get Pin
   Z-Wave Lock Manager             Requesting PIN for user 1
   Z-Wave                          sent "Front Door Deadbolt" raw command [63 02 01]
   Z-Wave Lock Manager             Status:  User code 1 is 9 5 9 9 [Node: 13]
I can also set the PIN by manually assigning it in the action.
Action Group                    Set Pin
   Z-Wave Lock Manager             Setting PIN for user 1 to: 7135
   Z-Wave                          sent "Front Door Deadbolt" raw command [63 01 01 01 37 31 33 35]
   Z-Wave Lock Manager             Status: User 1 updated [Node: 13]
   Z-Wave Lock Manager             Status:  User code 1 is 7 1 3 5 [Node: 13]
However, using the %%v:123456%% format (which I've doublechecked that I've used my own variable ID) doesn't seem to work.
Variable with ID
Screen Shot 2018-07-05 at 5.27.40 PM.png (7.05 KiB) Viewed 5391 times
Action setup
Screen Shot 2018-07-05 at 5.29.53 PM.png (76.4 KiB) Viewed 5391 times
The PIN is unchanged.
   Z-Wave Lock Manager             Setting PIN for user 1 to: %%v:710549162%%
   Z-Wave                          sent "Front Door Deadbolt" raw command [63 01 01 01]
(yes, the PIN in the variable is different; I made sure of that)
Any ideas? I have a Kwikset 910TRL. It seems to otherwise work fine...it's just the variable issue that's got me stumped.
chrisfromthelc
...and I feel like a dummy. I downloaded what I thought was the latest version from the pinned post in this subforum. I got the real latest version from the plugin store, and it works fine now.
howartp
Post by howartp »
Hehe, I love it when you solve things for me. :-)
I do need to check/remember to update the pinned post.
