Issues installing PILLOW
Chameleon
Post by Chameleon »
A couple of users have had issues installing PILLOW on their MACs. The world is a lot easier under WINDOWS :roll:
Anyway... if you're having problems there are a couple of steps you can take:
Two ideas to start with....
1. Upgrade pip2.6
This is a common error if pip is out of date...
Did you install pip2.6 or was it already on your system?
If it wasn't you may need to upgrade it first:
  • sudo easy_install2.6 --upgrade pip2.6
2. Just use pip on it's own
Or just let your system sort it out... I've updated the software to be more flexible on which version of PILLOW it uses so this should also work fine...
  • sudo pip install PILLOW
  • Upgrade your plugin to the latest version 0.3.06 (at least) - see forum for link and details
Hopefully, 1 or 2 should work fine. If not let me know and we'll investigate further
Regards
Mike
durosity
Re: Issues installing PILLOW
Post by durosity »
I'll try this when I get home. I fell behind at the weekend when I had to rush up to Glasgow.. tried to keep up with it remotely but became a right pain ;)
MartinG
Post by MartinG »
I'm still stuck at the "can't install PILLOW" place:
Command "/System/Library/Frameworks/Python.framework/Versions/2.6/Resources/Python.app/Contents/MacOS/Python -u -c "import setuptools, tokenize;__file__='/private/tmp/pip-build-sXbSVH/PILLOW/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-pAK1v1-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /private/tmp/pip-build-sXbSVH/PILLOW/
/Library/Python/2.6/site-packages/pip-8.1.2-py2.6.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning.
None of the PILLOW installation variants on this forum seem to be working sadly.
Any further ideas?
Chameleon
Post by Chameleon »
Martin
Looks as if you're requests module isn't set up for ssl.
This forum explains the options you have:
http://stackoverflow.com/questions/2913 ... is-prevent
The first one should work fine. You may have to use sudo pip2.6 install requests[security] --upgrade the --upgrade may be important because it might see your current installation and do nothing as 'the requirement is met'. Please try this solution in Terminal. If you still get the problem let me know.
I can also code around the error which I will do in the next release later this week. It looks as if you've got PILLOW in place I can tell the package to ignore the warning and allow the system to continue.
It's so much fun trying to find all of the possible combinations that MACs have to make a simple programme run properly.
Regards
Mike
DaveL17
Post by DaveL17 »
Chameleon wrote:It's so much fun trying to find all of the possible combinations that MACs have to make a simple programme run properly.
Regards
Mike
Hi Mike -
You forgot to use the proper tags, so I thought I'd help you out.
[biting_sarcasm]It's so much fun trying to find all of the possible combinations that MACs have to make a simple programme run properly.[/biting_sarcasm]
Dave
My Plugins and Scripts
Chameleon
Post by Chameleon »
Regards
Mike
Hi Mike -
Dave
Fair point - I should chill out more - oops...
or maybe use [windowsiseasier]It's so much fun trying to find all of the possible combinations that MACs have to make a simple programme run properly.[/windowsiseasier] - and that's something I never thought I'd say :)
DaveL17
Post by DaveL17 »
Chameleon wrote:[windowsiseasier]
Ack!
*dislike*
siclark
Post by siclark »
I am trying to get this setup on my mac mini running 10.7.5 and after many hours on google and trying many different things, I cannot get PILLOW to install. Seems to need joeg dependency and have tried installing that library through several ways, but still doesn't work.
I am now getting told that there is no pkg_resources, but I can't seem to install that now .
I am new to mac and indigo and completely stumped now. At least I understand what I am doing with windows, rather than blindly typing commands.
Any ideas on how to progress? As another south west trains sufferer, I want to get this working before all the fun this August!!
Not because it easy but because it's hard ...
siclark
Post by siclark »
Ok.. I'm making some progress, I think.
I have given up on the Apple python install (I think I am making progress in even understanding this comment), and have installed macports and now have both python2.6 and 2.7 setup as macports installs. I have installed pip, pillow and suds on both, and going into python2.6 I can run successfully the test commands.
All looks ok, except when I try to install the iTravel plugin it stops with SystemExit: 4 from line 91. "Couldnt find suds module".
Its definitely installed in both python 2.6 and 2.7 and running manually it works.
So why is the module not finding it?
I am guessing its to do with the path commands that the module is using which ends up at the apple python install?
Any ideas on how to change that? I have I thought put the right PATH statements in my .bash profile.
So close.....
jay (support)
Post by jay (support) »
Indigo plugins use the Apple-installed Python, so if it's the plugin that's having the issue that's likely the problem.
Also note that there are a wide variety of problems that can be experienced with Indigo when you have alternate pythons installed. You may be OK, just an FYI...
siclark
Post by siclark »
Cheers... I guessed that was it. Any way to make it use a different python? My Apple installed Python's are really messed up. I cant get pkg_resources installed in 2.6 so cant use Pip
jay (support)
No - we have to link against the built-in Python shared libraries in order to make our integration work. If we attempted to support random python installations we would never get anything else done.
Indigo 7 uses Python 2.7 btw...
siclark
Post by siclark »
Thanks… makes sense
I uninstalled macports, homebrew and python.org as everything was a mess and used time machine to restore the python frameworks folders and got it working. Installed PIP and then PILLOW and SUDS into 2.7 so all good.
jay (support)
Glad it's working for you now.
Return to “iTravel”
