Anyway... if you're having problems there are a couple of steps you can take:
Two ideas to start with....
1. Upgrade pip2.6
This is a common error if pip is out of date...
Did you install pip2.6 or was it already on your system?
If it wasn't you may need to upgrade it first:
- sudo easy_install2.6 --upgrade pip2.6
2. Just use pip on it's own
Or just let your system sort it out... I've updated the software to be more flexible on which version of PILLOW it uses so this should also work fine...
- sudo pip install PILLOW
- Upgrade your plugin to the latest version 0.3.06 (at least) - see forum for link and details
Regards
Mike
