(see also special pages for voice recognition and other sensors in this thread:viewforum.php?f=187 )
- Wire18B20-Temp DS18b20
- Temp+Hum-DHT22 Temperature & Humidity. ** Use V3.3,GND,GPIO1; Most need a 4.7kOhm resistor V3.3-Pin1
- Temp+Hum-DHT11 Temperature & Humidity. less accurate; ** Use V3.3,GND,GPIO17; Most need a 4.7kOhm resistor V3.3-Pin1
- Temp-i2cTMP102 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Temp-i2cMCP9808 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Temp+Press-i2cT5403 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Temp+Press-i2cBMPxx ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Temp-Ambient+Infrared-mlx90614 Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Temp+Press+Hum-i2cBMExx ** best sensor temp/press/humidity ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Temp+Hum-i2cSHT21 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Temp+Hum-i2cAM2320 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Temp-i2cLM75A-35 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Lux+RGB-i2cTCS34725 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- IR-Visible-UV -1145 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- visible Light -OPT3001 - not ready
- Ambient-White-i2cVEML6030 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- RGB-White-i2cVEML6040 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- UV-i2cVEML6070 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- UVA-UVB-i2cVEML6075 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Lux-i2cTSL2561 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- current and voltage i2c INA 209 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- XYZ-gyroscope l3g4000/l3gd20h ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- 3 degree sensor mag3110 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- 3 degree sensor hmc5883L ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- 9 degree sensor BNO055 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- 9 degree sensor mpu9255 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- 6 degree sensor mpu6050 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- 6 degree sensor lsm303 - not ready
- Analog-1x16bit-i2cADS1x15 - one channel ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Analog-4x16bit-i2cADS1x15 - 4 channels ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Analog-4x8bit-one-channel-i2cPCF8591 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Analog-4x8bit-i2cPCF8591 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- Analog-8x10bit-spiMCP3008 - 8 channels 10 bit 0-3.3 analog input channels ** use SPI connection
- Analog-8x10bit-one-channel-spiMCP3008 1 channels 10 bit 0-3.3 analog input channels
- pulse- sensor ** use any valid GPIO pin can detect > 50Hz frequency, pulse needs to be > 50uSecs , sets count and frequency state in indigo,. A microwave movement sensor (red - +5V, black -GND, green through diode[cathode to sensor, anode to RPI] to any GPIO pin): ~ $11
- TOUCH- 1 touchPad active ** supports 3 different sensors 2 with i2c and one with 2 general GPIO pins. (TTP226-xxx 16 Serial/8direct, TTP 226LSF 16 i2c channels; MPR121 i2c 12 channel)
- TOUCH- 4 touchPads active ** supports 3 different sensors 2 with i2c and one with 2 general GPIO pins. (TTP226-xxx 16 Serial/8direct, TTP 226LSF 16 i2c channels; MPR121 i2c 12 channel)
- TOUCH- 12 touchPads active ** supports 3 different sensors 2 with i2c and one with 2 general GPIO pins. (TTP226-xxx 16 Serial/8direct, TTP 226LSF 16 i2c channels; MPR121 i2c 12 channel)
- TOUCH- 16 touchPads active ** supports 3 different sensors 2 with i2c and one with 2 general GPIO pins. (TTP226-xxx 16 Serial/8direct, TTP 226LSF 16 i2c channels; MPR121 i2c 12 channel) note the jumpers on the TTP226-LSF-i2c 8pads +slider board ( KEYSEL) and the 16 pad TTP (P1-3)
- GPIO-max-1-PINs ** digital GPIO pin input
- GPIO-max-4-PINs ** digital GPIO pin input
- GPIO-max-10-PINs ** digital GPIO pin input
- GPIO-max-26-PINs ** digital GPIO pin input
- distance-ultrasound ** use 2 general GPIO pins for echo and trigger
- distance-TOF-vl503l0x ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- distance-TOF+Lux-vcnl4010 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- distance-TOF+Lux-vl6180 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- proximity-apds9960 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- my sensors.py ** program you can define your own sensor or any other function with this on the RPI
- myprogram.py ** program you can define your own sensor or any other function with this on the RPI, differnet version
- - out - GPIO-1-ON/off ** use any general GPIO pin to create a digital output device
- - out - GPIO-1-Dimmer ** use any general GPIO pin to create a digital output device with PWM (pulse width modulation), its a dimmer device in indigo, you can drive LEDs with this
- - out - GPIO-max-4-PINs ** use up to 4 general GPIO pin to create a digital output device with 4 output channels
- - out - GPIO-max-10-PINs ** use up to 10 general GPIO pin to create a digital output device with 10 output channels
- - out - GPIO-max-26-PINs ** use up to 26 general GPIO pin to create a digital output device with 26 output channels
- - out - FM-radio-setTEA5767 -- a neat little digital FM tuner ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- - out - Analog-1x12bit-i2cMCP4725 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- - out - Analog-1x8bit-i2cPCF8591 ** Use V3.3,GND,SLA(GPIO3),SLC(GPIO3) pins
- - out - Display avriaous display modules supported, see device defs
- - out - Neopixel device output for RGB LED chains ** Use V5,GND,GPIO18 pins and a level shifter
- - out - Neopixel-Dimmer device output for RGB LED chains ** Use V5,GND,GPIO18 pins and a level shifter, it is a indigo dimmer device
- - out - myoutput.py program on rPi. You can supply your own program to receive text commands from the plugin to do any action on the rPi you like to do.
This image shows how to connect a simple 1 wire DS18b20 (not the P version!!) to the rPi.:I use pins pins 1,7,9
The plugin does all the software configuration on the rPi
To create a SENSOR deviceFIRST connect the device to the rPi. Then in Indigo add device: select piBeacon/ sensor model. Then select the rPi the sensor is connected to, select the State column display and save.
After correct setup you should set in 1-2 minutes the sates being populated
Temperature/Pressure can be changed in config menu/configuration (celsius, fahrenheit, kelvin / ...)
Sensor Connection pins:
OneWire D18B20 sensor will be connected:
- Pin1=3.3V --> VCC,
- Pin7=GPIO4-->Signal
- Pin9=Ground--> ground
DHT sensor will be connected:
- Pin11=GPIO17-->Signal or Pin 7=GPIO4 (selectable in device edit), both together should work, but then no ONEwire device on pin 7
- Pin1=3.3V --> VCC
- Pin3=GPIO2-->SDA
- Pin5=GPIO3-->SDC
there are 127 possibilities. if you connect 2 they must have a different address. you can see the address of a connected i2c device with:
sudo i2cdetect -y 1
it will show you a matrix of HEX numbers and the one number of the connected device
SPI sensors will be connected to pins
- Pin1 =3.3V --> VCC
- Pin19=GPIO10-->MOSI
- Pin21=GPIO9--> MISO
- Pin23=GPIO11-> SCKL
- Pin24=GPIO8 =CE-0 either for channel selector
- Pin26=GPIO7 =CE-1 or for channel selector
- Pin25=Ground--> ground
INPUT GPIO PINS
any PIN that is not used for i2c pins and -- not Onewire or DHT if active - can be used as input pin
OUTPUT GPIO PINS are
(use PIN and ground to drive an external device, max current= 33mA):
any PIN that is not used for i2c pins and -- not Onewire or DHT if active - can be used as output pin
and below the complete pin layout
