In addition to the major 6.0 improvements this update includes:
- Added support for EasyDAQ DO24PRMx stacks for support up to 96 relays on a single USB port.
- Added support for INSTEON PAR 38 LED Bulb (2674-222).
- Added support for additional variant of INSTEON SwitchLinc 220V Relay (2477SA1).
- Added Z-Wave support for Duwi / Z-Wave.Me Remote Double Switch (ZME-WCD2).
- Added Z-Wave support for Fibaro Shutter Controller (FGRM222).
- Added Z-Wave support for Zipato RGBW LED Bulb.
- Increased Z-Wave node neighbor finding timeout to improve stability of syncing devices in large networks.
- Improved Z-Wave energy reporting to update more frequently with some module types.
- Improved error reporting of plugin configuration UI fields that do not use unique IDs.
- Modified logging to not report cleanup NAKs as errors (some newer KeypadLincs do not acknowledge cleanup commands).
- WeatherSnoop Plugin: fixed bug caused by a WeatherSnoop API change to represent fractional millimeters in rain measurements. This change happened in WeatherSnoop 2, specifically v2.2.6. WeatherSnoop 3 is not effected.
- Plugin API version number has been incremented to v1.16.
- Plugin API addition: Added attributes pausedScheduleZone and pausedScheduleRemainingZoneDuration to sprinkler device instances.
- Plugin API addition: New method indigo.device.ping(dev, suppressLogging) for measuring INSTEON and Z-Wave network performance.
- Plugin API bug fix: device updateStateOnServer() now correctly handles argument decimalPlaces value of 0.
