Indigo 6 v6.0.13 Released
Official announcements on new releases or other important events.
matt (support)
Post by matt (support) »
6.0.13 is now available for download.
In addition to the major 6.0 improvements this update includes:
  • Added support for EasyDAQ DO24PRMx stacks for support up to 96 relays on a single USB port.
  • Added support for INSTEON PAR 38 LED Bulb (2674-222).
  • Added support for additional variant of INSTEON SwitchLinc 220V Relay (2477SA1).
  • Added Z-Wave support for Duwi / Z-Wave.Me Remote Double Switch (ZME-WCD2).
  • Added Z-Wave support for Fibaro Shutter Controller (FGRM222).
  • Added Z-Wave support for Zipato RGBW LED Bulb.
  • Increased Z-Wave node neighbor finding timeout to improve stability of syncing devices in large networks.
  • Improved Z-Wave energy reporting to update more frequently with some module types.
  • Improved error reporting of plugin configuration UI fields that do not use unique IDs.
  • Modified logging to not report cleanup NAKs as errors (some newer KeypadLincs do not acknowledge cleanup commands).
  • WeatherSnoop Plugin: fixed bug caused by a WeatherSnoop API change to represent fractional millimeters in rain measurements. This change happened in WeatherSnoop 2, specifically v2.2.6. WeatherSnoop 3 is not effected.
Developer API Changes:
  • Plugin API version number has been incremented to v1.16.
  • Plugin API addition: Added attributes pausedScheduleZone and pausedScheduleRemainingZoneDuration to sprinkler device instances.
  • Plugin API addition: New method indigo.device.ping(dev, suppressLogging) for measuring INSTEON and Z-Wave network performance.
  • Plugin API bug fix: device updateStateOnServer() now correctly handles argument decimalPlaces value of 0.
Return to “Announcements”
