autolog
Post by autolog »
siclark wrote:Cheers... no rush at all. Just looking to see how I could use these. They seem to report temperature changes very fast and frequently, so interested on how the battery lasts.
OK - I have uploaded Version 1.4.2 as a pre-release on Github: TRV Controller - Add Support For Remote Thermostats With 'sensorValue' State
This version is pre-release and contains a few other bug fixes as well as (hopefully) support for the new Remote Thermostat. :)
shapa
Post by shapa »
Testing a new version
Creating a device.
Validation could not be passed - requiring "off" time for setpoint devices :)
Screenshot 2020-02-17 at 10.46.13.png (193.69 KiB) Viewed 6346 times
autolog
Post by autolog »
shapa wrote:Testing a new version
Creating a device.
Yes - I haven't finished coding the 'By Setpoint Only' option. Even though you can select it, the plugin will only process ON/OFF at the moment.
I should have made that clear when I uploaded this pre-release version which was mainly just to support the MQTT Shim devices. :)
shapa
Post by shapa »
OK! :)
So the new error for TF21 :
" TRV Error StandardError detected in TRV Plugin [deviceStartComm of device 'Conservatory TRV']. Line '3092' has error='list index out of range'"
autolog
Post by autolog »
shapa wrote:... So the new error for TF21 ....
What is a TF21 or should I know?
Can you do a device print and post the results here - thanks. :)
autolog
Post by autolog »
Memory isn't what it used to be. :wink:
I see you have already posted info about the TF21 earlier in this long thread - I will take a look at the issue. :)
autolog
Post by autolog »
Hi @shapa,
I can see what the issue is but need to think how to resolve it in the context of the new Pre-Release. :?
Can you roll-back to the previous release you were on? Also, what was the release you were on that worked OK?
shapa
Post by shapa »
Sure, will roll back
The latest one was 1.3.7 (with manually added TF21 and Generic v2 thermostats )
Thanks a lot for the support and development!
shapa
Post by shapa »
On more idea (pushed by my wife :)) )
Hardcoded "upper limit" is not always the best option.
For example, 28C for radiators - they are literally burning oxygen. Some rooms - not an issue, child room for example - then the air is very dry (~25%).
So, it would be nice to make the "max heat" setting as well. Sure, I can edit it in the .xml, but would be nice to be able to set per virtual TRV
siclark
Post by siclark »
autolog wrote:
siclark wrote:Hi Jon. No pressure but just wondering if you saw this?
I missed it. :oops:
Good idea; the thought had crossed my mind. :)
What I would actually like is for Indigo to have a priority queuing mechanism for Z-Wave - The status requests could then go on the low priority queue,
I am not sure how easy it will be to implement it but I will see what I can do.
I have a few other things getting in the way at the moment, so it will be a little while before I can do anything on it. :)
Hi Jon. Wondered with lack of current social life due to enforced lock down whether this has resurfaced to the top of your mind?
Just thought I’d ask... hehe. Hope all well with you.
autolog
Post by autolog »
siclark wrote:... Hi Jon. Wondered with lack of current social life due to enforced lock down whether this has resurfaced to the top of your mind?
I have been self-isolating for a couple of weeks due to my age and a few other things and am now "locked down" as is everybody else.
I made the mistake of suggesting Zoom Video Conferencing to a club I belong to and have spent the last two weeks talking members through how to connect (via landline) and running impromptu video sessions. Zoom seems to be an excellent and easy to use system. :)
It should quieten down before too long and I will see what I can do.
I have also been doing some Indigo usage work by reconfiguring existing and adding new motion sensors which has taken up a bit of time.
I am also experimenting with using Zigbee Aqara temperature monitors on the inlet pipe to the radiator to see if I can pick up whether the Spirit is mis-behaving.
@Shapa re: So, it would be nice to make the "max heat" setting as well - I will take a look at that as well. :)
autolog
Post by autolog »
shapa wrote:On more idea (pushed by my wife :)) )
I have loaded a new pre-release to Github: Add Support for limiting Heat Setpoint Maximum on TRV
This is done per TRV rather than globally. You will need to Edit Device Settings for the TRV you wish to apply this to and you can then enable the option to override the TRV Maximum Settable Temperature [FULLY ON] value by entering a value in field that is > 21 and less than the device maximum - hope that makes sense. These fields are in the TRV CONTROLLER DETAILS section
I have done limited testing on this so far. Interested to have feedback on the implementation i.e. is that what you wanted and if it works for you?
Also fixed a bug where previously you could use the Indigo UI to up the Heat Setpoint beyond the maximum or reduce it below the minimum - this is now prevented.
Simon: I will take a look at the offsetting of the status requests next. :)
autolog
Post by autolog »
autolog wrote:... Simon: I will take a look at the offsetting of the status requests next. :)
I have just completed the implementation of this feature and will test it over the next day or so before releasing it to Github as pre-release Version 1.5.0:
Here is sight of the new plugin config dialogue:
TRV Controller Configuration Dialogue
The Queue Delay can be specified as: No Delay, 10 Seconds, 15 Seconds, 20 Seconds, 30 Seconds, 40 Seconds, 50 Seconds or 60 Seconds.
The Queue Delay [Spirit Valve] can be specified as: As Queue Delay Value, 5 Seconds, 10 Seconds, 15 Seconds or 20 Seconds
The Queue Delay [Spirit Valve] is only taken account of if a delay is specified for Queue Delay i.e. it will be ignored if Queue Delay is specified as No Delay.
This should cover the majority of the situations but not a plugin startup / reload but then this shouldn't happen too often (hopefully). :)
autolog
Post by autolog »
I have now posted Version 1.5.0 to Github as a pre-release: TRV Controller V 1.5.0 - Add User Specified Z-Wave Delay Between Status Requests
It actually does work on plugin start / reload. :)
All seems to work OK as far as my system is concerned.
If you have the delay set to 15 seconds and valve delay set to 5 seconds then to start each TRV will take 20 seconds. If you have 12 TRVs, it is going to take 12 x 20 seconds = ~ 4 minutes to complete and any new changes (e.g. turn on a TRV) will be queued up behind the initial start.
I will do a more general announcement once I am happy it appears to be working OK. :)
shapa
Post by shapa »
Works mostly fine :) WAF is nearly 100% :)
Some "old" issue
" TRV Error StandardError detected in TRV Plugin [zwaveCommandReceived]. Line '524' has error=''zwaveWakeupIntervalRemote''
TRV Error StandardError detected in TRV Plugin [deviceUpdated] for device 'Conservatory Temperature 2']. Line '1145' has error=''remoteTempOffset''
Z-Wave received "Conservatory Humidity 2" sensor update to 24%
Z-Wave received "Conservatory Luminance 2" sensor update to 107 lux
Z-Wave received "Conservatory Ultraviolet" sensor update to 0
TRV Error StandardError detected in TRV Plugin [zwaveCommandReceived]. Line '524' has error=''zwaveWakeupIntervalRemote''"
Looks like related to the external temp sensor used as a temp reading source
Return to “TRV Controller”
