Onkyo Network Remote Feedback and Discussion
Re: Onkyo Network Remote Feedback and Discussion
Thanks Adam!
By the way, the TX-NR535 works great with the plugin.
Jeff
Jeff
- RogueProeliator
Jeff, I posted the new version to the same download link available in the original thread; this includes the ability to send an arbitrary command string to the Onkyo receiver -- just go to the Plugins -> Onkyo Network Remote Plugin -> Send Arbitrary Command option. You will want to toggle on full debugging if you want to see the returned values.
For the tuner preset, my guess is that you are correct on your command guess... try:
PRS01 (Note that 01 can be changed, but will be in hexadecimal format)
Honestly, for the Pandora control, I have no idea whatsoever... the NTC command says "Network/USB Operation Command (Network Model Only after TX-NR905)", but I've never tried any of the network or USB features. NTCCHUP may work as you suggest. Will just have to try and see...
For pulling artist/album, you can try these but I've never tried these before so no idea what you will get back...
NATQSTN
NALQSTN
NTIQSTN
NTRQSTN
Let me know what works/doesn't and I can see about getting new actions and commands into the plugin. You'll need to post the returned values from the Indigo Log for me to be able to setup the response parsing.
Adam
NATQSTN
NALQSTN
NTIQSTN
NTRQSTN
Adam
I have a TXNR515 and the plugin had been working fine. Since I upgraded to the more recent versions it is not working.
I am getting the following error messages.. Andy ideas ?
Thanks !!
Onkyo Network Remote Plugin Initializing RPFrameworkPlugin
Onkyo Network Remote Plugin RPFrameworkConfig.xml not found at /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFrameworkConfig.xml, skipping processing
Onkyo Network Remote Plugin Customizing MenuItems.xml
Started plugin "Onkyo Network Remote Plugin 1.5.15"
Onkyo Network Remote Plugin Debug Database access has been disabled, skipping connection
Onkyo Network Remote Plugin Debug Entering deviceStartComm for Onkyo Cable; ID=136654138
Onkyo Network Remote Plugin Error exception in deviceStartComm(Onkyo Cable): exceptions must be old-style classes or derived from BaseException, not str
Onkyo Network Remote Plugin Debug Version check initiated
Onkyo Network Remote Plugin Your plugin version, v1.5.15, is current.
Thanks !!
- RogueProeliator
Did you by chance rename the plugin and/or downloaded file prior to installing the update? The issue is that it is looking for this file and it can't be found (without it the plugin won't be able to configure itself for the Onkyo device):
Adam
/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFrameworkConfig.xmlRe: Onkyo Network Remote Feedback and Discussion
I have not renamed the plugin. I have tried to delete the plugin and start over but still getting error message that xml file cannot be found.
Any ideas on how to start over and get around this error?
Happy to send logs if that helps.
Randy
Randy
- RogueProeliator
Can you see if that exact file exists? Easiest way may be in terminal, just do:Any ideas on how to start over and get around this error?
more /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFrameworkConfig.xmlAdam
Adam,
The file is not there.
Result
/Library/Application: No such file or directory
Support/Perceptive: No such file or directory
Automation/Indigo: No such file or directory
6/Plugins/Onkyo: No such file or directory
Network: No such file or directory
Remote.indigoPlugin/Contents/Server: No such file or directory
Plugin/RPFrameworkConfig.xml: No such file or directory
Result
I think I might have found the issue.
Onkyo Network Remote-2.indigoPlugin
This is the name for the plugin with a -2.
I think the issue is that when I downloaded the plugin there was an old one in my downloads folder.
This caused the -2.
This caused the -2.
How do I remove any trace of the plugin and start over?
I have deleted it out of the plugins directory and the prefs/ plugin.
Thanks for your help!
Randy
Randy
- RogueProeliator
Yup, that would be an issue... Delete from the plugins and disabled plugins, as I believe you said you had done, to be 100% sure I would stop/restart the Indigo server so that it doesn't have any cached knowledge of the plugin. Then be sure the filename is named normally (sans the -2) and double click it.This is the name for the plugin with a -2
I have on my list to allow the filename to be based on the plugin's directory in some way, but for now it just uses the plugin name, hence the issue with the -2 in the name.
Adam
I have had no luck in removing the plugin completely.
Deleted in the following:
pluugins
plugins disabled
Preferences/plugins.
Then closed Indigo and restarted.
Plugin still shows up in list
If I now try to add plugin back I get the following error:
v1.5.15 of plugin "Onkyo Network Remote Plugin" is already installed and enabled
Error (client) getXmlFromPlugin() caught exception: empty XML string returned
Error (client) runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Onkyo Network Remote Plugin Error Error in plugin execution CallPluginFunc:
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 603, in getPrefsConfigUiXml
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/dom/minidom.py", line 1928, in parseString
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/dom/expatbuilder.py", line 940, in parseString
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/dom/expatbuilder.py", line 223, in parseString
<class 'xml.parsers.expat.ExpatError'>: no element found: line 1, column 0
pluugins
plugins disabled
Got it working!
I had to copy the new plugin into the plugin directory, the stop and start the server.
Just restarting the program did not seem to work.
I am now able to create devices and volume control.
Well I thought I had it working,
The volume control works fine, but when I send an action or a trigger I get the following error.
Onkyo Network Remote Plugin Error Error in plugin execution ExecuteAction:
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkPlugin.py", line 1117, in executeAction
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkIndigoAction.py", line 118, in generateActionCommands
<type 'exceptions.AttributeError'>: 'RPFrameworkIndigoActionDfn' object has no attribute 'indigoId'
- RogueProeliator
That error appears to be within my debugging code that executes whenever you send invalid parameters to an action -- I'll correct up the debug code, but how are you attempting to execute the action? From a script?
This error is likely either a missing required parameter or an invalid value for a parameter (such as a negative number for a volume, a non-integer where an integer is expected, etc.) In theory, had the debug code been working, the actual message would have been printed to the log. Simply typo on my part, so I can get that correctly soon... but in the meantime we can probably figure out what is missing or wrong in your case.
You may be able to get more information before it gets to that point by turning on the debugging to at least Medium, executing the action, and then turning off debug.
Adam
Adam
Thanks for the plug-in Adam!
I can't seem to get Zone 2 control to work. Here's what I get when I try a volume change through the virtual volume control:
Onkyo Network Remote Plugin Debug Dimmer Command: ActionId=SetBrightness; Device=170023562; actionValue=58
Onkyo Network Remote Plugin Debug Execute condition failed, skipping execution for command: sendEISCPCommand
On/Off toggling through indigo touch results in this :
Onkyo Network Remote Plugin Error Execute action called for non-managed action id: Toggle
Power toggle on the main zone VVC through touch has the same bad result, but volume works there, and both volume and power on the main zone work through the indigo interface.
Any thoughts? Need more info? it's an NR616
thanks!
Rocco
thanks!
Rocco
