[ANSWERED]Where to find WeatherSnoop "states" for scripts?
gregjsmith
- Contact:
Where do I find these?
- jay (support)
- Site Admin
- Contact:
Re: Where to find WeatherSnoop "states" for scripts?
In the Custom States tile in the control area. It'll be below the Device Details tile when you select your WeatherSnoop device so you'll either need to scroll the area or make it taller using the split view control between the list and control area.
gregjsmith
- Contact:
Ah OK I found it. The device details window has some issue. It auto resizes itself which is annoying. Also I don't think the text is small enough.
Any chance of being able to break that out into a bigger window and the ability to copy and paste from it?
- jay (support)
- Site Admin
- Contact:
I'm not following - what auto resizes?
We've got a list of things to look at for the control area in a future release.
gregjsmith
- Contact:
It start off like this when I select Weather Station in the device list.jay (support) wrote:I'm not following - what auto resizes?
Then spontaneously shrink like this
Played and found that if you resize window again it pops back full height again, It seems to revert to small window every 30 seconds.
Computer Keith
Mt Pleasant SC - Charleston
Indi-Go -Go-Go
Indi-Go -Go-Go
- jay (support)
- Site Admin
- Contact:
What OS versions are you guys seeing this on?
gregjsmith
- Contact:
- jay (support)
- Site Admin
- Contact:
I've found the bug - should get it fixed in the next release.
Did this get into 6.0.6? I didn't see it noted in the announcement.
- jay (support)
- Site Admin
- Contact:
It should be - I believe we just forgot to get it into the change notes.
It is. Thanks.jay (support) wrote:It should be - ...
