[ANSWERED]Where to find WeatherSnoop "states" for scripts?
gregjsmith
Post by gregjsmith »
Where do I find these?
jay (support)
Re: Where to find WeatherSnoop "states" for scripts?
Post by jay (support) »
In the Custom States tile in the control area. It'll be below the Device Details tile when you select your WeatherSnoop device so you'll either need to scroll the area or make it taller using the split view control between the list and control area.
gregjsmith
Ah OK I found it. The device details window has some issue. It auto resizes itself which is annoying. Also I don't think the text is small enough.
Any chance of being able to break that out into a bigger window and the ability to copy and paste from it?
jay (support)
I'm not following - what auto resizes?
We've got a list of things to look at for the control area in a future release.
gregjsmith
jay (support) wrote:I'm not following - what auto resizes?
It start off like this when I select Weather Station in the device list.
Then spontaneously shrink like this
Untitled 2.png (35.6 KiB) Viewed 7207 times
keifer1
Post by keifer1 »
Played and found that if you resize window again it pops back full height again, It seems to revert to small window every 30 seconds.
Computer Keith
Mt Pleasant SC - Charleston
Indi-Go -Go-Go
jay (support)
What OS versions are you guys seeing this on?
gregjsmith
10.8.4
jay (support)
I've found the bug - should get it fixed in the next release.
berkinet
Post by berkinet »
Did this get into 6.0.6? I didn't see it noted in the announcement.
jay (support)
It should be - I believe we just forgot to get it into the change notes.
berkinet
Post by berkinet »
jay (support) wrote:It should be - ...
It is. Thanks.
Return to “WeatherSnoop”
