DigiTemp - 1 Wire Temperature Plugin (Locked)
Manage a 1-wire temperature sensor network.
travisc
Post by travisc »
Please see the post below for current information and installation instructions.
DigiTemp Plugin - Information and Installation
jay (support)
Re: DigiTemp - 1 Wire Temperature Plugin
Post by jay (support) »
NICE! This along with your writeup should help many people who've been asking for temperature sensing options. Heck, I may have to invest as well since I liberally spread Cat5 throughout my house when I built it.
matt (support)
Post by matt (support) »
Awesome plugin -- thanks a bunch for sharing it, Travis.
roussell
Post by roussell »
I get the following error (Indigo 5.0.4 on Snow Leopard using DS9097U and known-good serial/USB adapter):
DigiTemp Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 68, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/DigiTemp.indigoPlugin/Contents/Server Plugin/DigiTemp.py", line 382, in startComm
<type 'exceptions.UnboundLocalError'>: local variable 'nextScanTime' referenced before assignment
  DigiTemp Error                  plugin runConcurrentThread function returned or failed; will attempt again in 10 seconds
Using a separate build of digilink, I am able to read the sensors attached to the DS9097U from the command line.
BTW, I restarted the Mini that it's running on and still get the same error...
Terry
travisc
Post by travisc »
Hi Roussell,
When do you see that error? When the plugin starts, when you close the config dialog, when you hit the scan button?
EDIT: Actually, can you enable debugging in the plugin config, then restart the plugin. Send me everything in the log from the plugin start to where it chokes.
anode
Post by anode »
ooooh Does it only support the temp sensors? I have a couple switches from hobby boards that I'd love to use.
travisc
Post by travisc »
Yes. It can only support the 1-wire devices that DigiTemp supports.
roussell
Post by roussell »
travisc wrote:Hi Roussell,
Sorry for missing your post. It happens on restart, or upon enabling the plugin if I remember correctly. I'll enable debugging and send the log tonight.
Terry
MrJeffreyGee
Post by MrJeffreyGee »
travisc wrote: Currently only DS9097U and compatible adapters are supported.
What other compatible adapters are supported? I've got a LinkUSB that I would like to get working with your plugin. I read on this guys website (link below) that he got a LinkUSBi to work with digiTemp and the only difference between a LinkUSBi & a LinkUSB is a DS2401 ID chip is embedded in the LinkUSBi.
http://www.finnie.org/2010/03/07/extern ... ith-linux/
He also says on his site: "You'll want the digitemp package, which is pre-packaged in Debian and probably most other Linux distributions. Once it's installed, you'll need to know what program to use. Several are available for different DS masters, but in the LinkUSBi's case, you'll want digitemp_DS9097U."
So it seems like your plugin should work easily with a linkUSB am I right? Not sure if I'm wiring it up incorrectly, but the plugin doesn't seem to see my thermometers.
travisc
Post by travisc »
From that page it seems like the LinkUSB has an internal FTDI serial-usb chip, that's a good start. Does it show up in the serial port list in the DigiTemp plugin? You would need to have the FTDI serial drivers installed for it to show up, which you may already have if you are using an Insteon PLC.
The DigiTemp plugin is indeed using the DS9097U version of DigiTemp, so that shouldn't be the problem.
Turn on debugging and restart the plugin to see the detailed log. See if that sheds any light. Paste the log here if you still need help.
Travis
ELWOOD
Post by ELWOOD »
Travis
Just installed your plugin and connected it to a Link USB from ibutton link and there temperature sensor.
The plugin found the Link USB and is reading the temperature from the first temperature sensor I connected.
Got it to write the temperature to a variable.
Hopefully I will add more sensors over the weekend and let you know how its working.
Thank for you time and effort in developing this plugin
Elwood
travisc
Post by travisc »
@Elwood
Thanks for the update! Nice to hear it works with the LinkUSB.
MrJeffreyGee
travisc wrote:From that page it seems like the LinkUSB has an internal FTDI serial-usb chip, that's a good start. Does it show up in the serial port list in the DigiTemp plugin? You would need to have the FTDI serial drivers installed for it to show up, which you may already have if you are using an Insteon PLC.
Travis
Sorry for the delayed reply. It didn't show up in the serial port list and there was actually nothing to select, but that was cause I didn't have the FTDI drivers installed. I installed the latest drivers and then there was two available things to select. I tried both of them, but it doesn't see my thermometer. Could it be my wiring is incorrect? Right now I've got my 1-wire thermometers wired up to an Arduino board and I know they work. I only connected the blue wire (Pin 4 on TIA/EIA 568B cable wiring scheme) from my LinkUSB to the 1-wire thermometer and it doesn't see it. Does your plugin require the other wires to be connected too?
LinkUSB Pin Out
LinkUSB Pin Out
I'm also getting the errors below in the event log. I've tried reload/disabling/re-enabling the plugin with no luck too.
travisc
Post by travisc »
They call it a 1-wire interface but it actually needs two, Ground and 1-Wire data, for it to work. The 1-wire refers to how many signal wires are required for communication, the common ground requirement is assumed. It's a little mis-leading if you're not an electronics guru.
I'll need more log info than that, that just looks like the last error in the log which doesn't help me. Turn on debugging, reload the plugin, then send me everything from when the plugin starts to when it errors.
ELWOOD
Post by ELWOOD »
MrJeffreyGee
My setup has been working fine. I have the LinkUSB connected to 2 iButtonLink T-Sense Temperature Sensor using the RJ45 jacks.
Plus 5 Dallas ds18s20 in a TO-92 package. However I am using the third wire for 5 volt power. The ds18s20 can work with 2 wires (pin 1&2)
as "Parasite Mode" but I think this requires adding a capasitor at the LinkUSB between pin 2 and 4.
Since I am running the sensors on cat5 cable I have the extra wires to pas the 5 volt power to the sensor.
Hook up pins from the LinkUSB to the ds18s20 as the following:
LinkUSB pin 1 and 5 to ds18s20 pin 1 (ground)
LinkUSB pin 2 to ds18s20 pin 3 (+5v power)
LinkUSB pin 4 to ds18s20 pin 2 (1-wire data)
Hope this helps
Elwood
Locked
Return to “DigiTemp 1-Wire Temperature Plugin”
