Domio - Questions and support
Coolcaper
Re: Meet Domio - your new iOS App and AI assistant
Post by Coolcaper »
Any chance you can make this available worldwide? Not available in the Australian App Store.
siclark
Post by siclark »
Ah sorry. Yes I will do. I had an issue with Chinaand my use of AI so turned off all of Asia. I’ll put Australia and NZ back on.
Coolcaper
Post by Coolcaper »
Thank you
siclark
Post by siclark »
In the meantime, some screen shots. Image
Coolcaper
Post by Coolcaper »
I like the unifying look. It fits in as an alternative to the Home app which is what everyone at home has been using. Looking forward to a smooth transition but with the Indigo perspective. Does it work on the iPad? Does it support Split View on the iPad?
CliveS
Post by CliveS »
Coolcaper wrote: Thu Feb 26, 2026 6:21 am I like the unifying look. It fits in as an alternative to the Home app which is what everyone at home has been using. Looking forward to a smooth transition but with the Indigo perspective. Does it work on the iPad? Does it support Split View on the iPad?
Yes it does.
Split View.jpg (66.96 KiB) Viewed 1297 times
CliveS
Coolcaper
Post by Coolcaper »
:D
siclark
Post by siclark »
Coolcaper wrote:I like the unifying look. It fits in as an alternative to the Home app which is what everyone at home has been using. Looking forward to a smooth transition but with the Indigo perspective. Does it work on the iPad? Does it support Split View on the iPad?
Yes. I built it to replace the Home app and remove that dependency but then to offer indigo specific items like logs and control pages and a better AI experience.
Thanks Clive for showing the Split View.
durosity
Post by durosity »
siclark wrote: Thu Feb 26, 2026 7:00 am
I'm curious, why did you want to remove the home app? I find the very tight integration with iOS via HomeKit to be exceptionally useful.
durosity
Post by durosity »
Also I'm curious, is implementing push notifications plausible? I know it's been minefield in the past due to having to host a server and such, just not sure if it's actually still that complex.
siclark
Post by siclark »
A lot of my motivation for building this was also to remove the Home app. Not that there was anything wrong with it, it’s the initial design influence behind this app. But it needs another plugin running, manual setup in that plugin for every device, then reliance on an Apple TV and Apple servers to work.
It can be simpler.
But I’ll still keep the plugin running as it’s very useful for Siri
DaveL17
Post by DaveL17 »
I researched this not too long ago and it seemed that a service like Pushover was still recommended more globally (beyond a native app that could take care of such things). I wanted to build something for myself, but am too cheap to spend $100/year to run my own software on my own devices. :wink:
My Plugins and Scripts
siclark
Post by siclark »
durosity wrote:Also I'm curious, is implementing push notifications plausible? I know it's been minefield in the past due to having to host a server and such, just not sure if it's actually still that complex.
No not easily. Indigo doesn’t offer it and it needs something centrally to manage it. It is possible and I can certainly consider it but might need to be a small in app purchase for that. And no promises or timeframes.
Also Apple restricts apps from running in background outside limited updates so can fetch data for say widgets periodically it can’t maintain a websocket for live updates so no easy way that way.
Push notifications wouldn’t offer much more than pushover but you could have them deep linked straight to the device or variable.
durosity
Post by durosity »
My vague understanding was that with a push notification service you can enable background processing for a short time.. do you know if that’s the case? If so, might help with that side of things.
As for an in app payment, I’d be happy with that. Considering the work you’ve put into it, perhaps you should add a donations IAP option, I’d gladly contribute to your development of this, once I actually have any money :lol:
ryanbuckner
Post by ryanbuckner »
I'm getting the following errors when launching Domio on my phone. All features appear to be working ok.
I also added this to GitHub
App version: 1.1
iOS version: 26.3
Indigo server version: 2025.1
Describe the bug:The following errors are written to the log when I launch Domio
Mar 3, 2026 at 11:55:08 AM
   Web Server Warning              HTTP API v2 GET call received for indigo.devices from 173.79.109.136
   Web Server Error                Invalid log command payload received, id: '- no message id -'
   Web Server Error                message handler failed: plugin with id 'com.simons-plugins.logs-over-reflector' isn't installed
   Web Server Warning              HTTP 501 error for request /message/com.simons-plugins.logs-over-reflector/log from 173.79.109.136
   Web Server Warning              HTTP 501 error for request /message/com.simons-plugins.logs-over-reflector/dates from 173.79.109.136
   Web Server Warning              HTTP 501 error for request /message/com.simons-plugins.logs-over-reflector/sources from 173.79.109.136
   Web Server Warning              HTTP API v2 GET call received for indigo.actionGroups from 173.79.109.136
   Web Server Warning              HTTP API v2 GET call received for indigo.variables from 173.79.109.136
   Web Server Warning              HTTP API v2 GET call received for indigo.controlPages from 173.79.109.136
Steps to reproduce:
Launch Domio on the phone and go to Event logs
Screenshots (if applicable):
Screenshot 2026-03-03 at 12.01.07 PM.jpg (424.11 KiB) Viewed 397 times
<img width="590" height="1278" alt="Image" src="https://github.com/user-attachments/ass ... 2447dda445" />
> Warning: For Indigo server or plugin issues, please visit the [Indigo Domotics forums](https://forums.indigodomo.com/) instead.
Return to “Domio”
