Apr 14, 2025 at 6:28:23 PM
HomeKitLink Siri ==============================================================================================================================================================================================
HomeKitLink Siri ==================================================================================== Logging info follows ====================================================================================
HomeKitLink Siri ================================================ Initializing New Plugin Session =================================================
HomeKitLink Siri Plugin name: HomeKitLink Siri
HomeKitLink Siri Plugin version: 0.6.75
HomeKitLink Siri Plugin ID: com.GlennNZ.indigoplugin.HomeKitLink-Siri
HomeKitLink Siri Plugin Path: /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin
HomeKitLink Siri Indigo version: 2024.2.1
HomeKitLink Siri Silicon version: arm64
HomeKitLink Siri Python version: 3.11.6 (v3.11.6:8b6ee5ba3b, Oct 2 2023, 11:18:21) [Clang 13.0.0 (clang-1300.0.29.30)]
HomeKitLink Siri Python Directory: /Library/Frameworks/Python.framework/Versions/3.11
HomeKitLink Siri FFmpeg : /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/homekitlink_ffmpeg/ffmpeg_binaries/arm/ffmpeg
HomeKitLink Siri
HomeKitLink Siri ================================================== Contents of Library Install: ==================================================
HomeKitLink Siri Contents of 'pip-install-log-success.txt':
Collecting cryptography==41.0.7 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 1))
Obtaining dependency information for cryptography==41.0.7 from https://files.pythonhosted.org/packages ... l.metadata
Using cached cryptography-41.0.7-cp37-abi3-macosx_10_12_universal2.whl.metadata (5.2 kB)
Collecting homekitlink_ffmpeg (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 2))
Obtaining dependency information for homekitlink_ffmpeg from https://files.pythonhosted.org/packages ... l.metadata
Using cached homekitlink_ffmpeg-0.0.25-py3-none-any.whl.metadata (2.8 kB)
Collecting orjson==3.8.10 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 3))
Obtaining dependency information for orjson==3.8.10 from https://files.pythonhosted.org/packages ... l.metadata
Using cached orjson-3.8.10-cp311-cp311-macosx_11_0_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl.metadata (47 kB)
Collecting async_timeout==4.0.3 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 4))
Obtaining dependency information for async_timeout==4.0.3 from https://files.pythonhosted.org/packages ... l.metadata
Using cached async_timeout-4.0.3-py3-none-any.whl.metadata (4.2 kB)
Collecting aiofiles==23.2.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 5))
Obtaining dependency information for aiofiles==23.2.1 from https://files.pythonhosted.org/packages ... l.metadata
Using cached aiofiles-23.2.1-py3-none-any.whl.metadata (9.7 kB)
Collecting tlv8==0.10.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 6))
Using cached tlv8-0.10.0-py3-none-any.whl
Collecting base36==0.1.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 7))
Obtaining dependency information for base36==0.1.1 from https://files.pythonhosted.org/packages ... l.metadata
Using cached base36-0.1.1-py2.py3-none-any.whl.metadata (2.0 kB)
Collecting pyqrcode==1.2.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line
Using cached PyQRCode-1.2.1-py3-none-any.whl
Collecting slugify==0.0.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 9))
Using cached slugify-0.0.1-py3-none-any.whl
Collecting pypng==0.20220715.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 10))
Obtaining dependency information for pypng==0.20220715.0 from https://files.pythonhosted.org/packages ... l.metadata
Using cached pypng-0.20220715.0-py3-none-any.whl.metadata (13 kB)
Collecting h11==0.14.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 11))
Obtaining dependency information for h11==0.14.0 from https://files.pythonhosted.org/packages ... l.metadata
Using cached h11-0.14.0-py3-none-any.whl.metadata (8.2 kB)
Collecting zeroconf==0.131.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 12))
Using cached zeroconf-0.131.0-cp311-cp311-macosx_14_0_arm64.whl
Collecting chacha20poly1305-reuseable==0.12.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 13))
Using cached chacha20poly1305_reuseable-0.12.0-cp311-cp311-macosx_14_0_arm64.whl
Collecting cffi>=1.12 (from cryptography==41.0.7->-r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 1))
Obtaining dependency information for cffi>=1.12 from https://files.pythonhosted.org/packages ... l.metadata
Using cached cffi-1.17.1-cp311-cp311-macosx_11_0_arm64.whl.metadata (1.5 kB)
Collecting ifaddr>=0.1.7 (from zeroconf==0.131.0->-r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 12))
Obtaining dependency information for ifaddr>=0.1.7 from https://files.pythonhosted.org/packages ... l.metadata
Using cached ifaddr-0.2.0-py3-none-any.whl.metadata (4.9 kB)
Collecting pycparser (from cffi>=1.12->cryptography==41.0.7->-r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 1))
Obtaining dependency information for pycparser from https://files.pythonhosted.org/packages ... l.metadata
Using cached pycparser-2.22-py3-none-any.whl.metadata (943 bytes)
Using cached cryptography-41.0.7-cp37-abi3-macosx_10_12_universal2.whl (5.3 MB)
Using cached orjson-3.8.10-cp311-cp311-macosx_11_0_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl (237 kB)
Using cached async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
Using cached aiofiles-23.2.1-py3-none-any.whl (15 kB)
Using cached base36-0.1.1-py2.py3-none-any.whl (3.5 kB)
Using cached pypng-0.20220715.0-py3-none-any.whl (58 kB)
Using cached h11-0.14.0-py3-none-any.whl (58 kB)
Using cached homekitlink_ffmpeg-0.0.25-py3-none-any.whl (45.1 MB)
Using cached cffi-1.17.1-cp311-cp311-macosx_11_0_arm64.whl (178 kB)
Using cached ifaddr-0.2.0-py3-none-any.whl (12 kB)
Using cached pycparser-2.22-py3-none-any.whl (117 kB)
Installing collected packages: tlv8, slugify, pyqrcode, pypng, ifaddr, base36, zeroconf, pycparser, orjson, homekitlink_ffmpeg, h11, async_timeout, aiofiles, cffi, cryptography, chacha20poly1305-reuseable
Successfully installed aiofiles-23.2.1 async_timeout-4.0.3 base36-0.1.1 cffi-1.17.1 chacha20poly1305-reuseable-0.12.0 cryptography-41.0.7 h11-0.14.0 homekitlink_ffmpeg-0.0.25 ifaddr-0.2.0 orjson-3.8.10 pycparser-2.22 pypng-0.20220715.0 pyqrcode-1.2.1 slugify-0.0.1 tlv8-0.10.0 zeroconf-0.131.0
HomeKitLink Siri ================================================ Xcode Command Line Tools Check: =================================================
HomeKitLink Siri
HomeKitLink Siri
HomeKitLink Siri
HomeKitLink Siri
HomeKitLink Siri
HomeKitLink Siri ======================================================= Advanced Settings: =======================================================
HomeKitLink Siri Selected IP version: IPVersion.All
HomeKitLink Siri Select interfaces: InterfaceChoice.All
HomeKitLink Siri HKLS Advertised Ip address: None
HomeKitLink Siri HKLS Server Ipaddress: None
HomeKitLink Siri HKLS Advertised Ipaddress and HKLS Server Ipaddress are None, which is acceptable. The server will decide the best option.
HomeKitLink Siri ========================================================================= Device Bridges enabled and up and Running ==========================================================================
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1890735876 Name: Bedtime DeviceName: Bedtime Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1618526344 Name: TV Lift DeviceName: TV Lift Type: Blind
HomeKitLink Siri Bridge: 731921 : Indigo Id: 847090575 Name: Conversation Pit DeviceName: Conversation pit Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1085465880 Name: Outdoor lights on DeviceName: Outdoor Lights On Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1030106652 Name: Set Late Evening DeviceName: Set Late Evening Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1892089501 Name: Master Candle lit DeviceName: Master Candlelit Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1638016553 Name: Master Shade DeviceName: Master Bedroom Shade Type: Blind
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1546200237 Name: Master Shower Fan DeviceName: Master Shower Fan Type: Fan
HomeKitLink Siri Bridge: 731921 : Indigo Id: 772172334 Name: Guest Bath Fan DeviceName: Guest Bath Fan Type: Fan
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1465659697 Name: Monolith DeviceName: Monolith Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 63179188 Name: Edison's Strip Light DeviceName: Edison Strip Light Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1885735989 Name: Master Strip DeviceName: Master Strip Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 438116415 Name: Edison's Shade DeviceName: Edison Shade Type: Blind
HomeKitLink Siri Bridge: 731921 : Indigo Id: 445945928 Name: Chandelier DeviceName: Chandelier Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1283455183 Name: Master Shower Light DeviceName: Master Shower Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 983210579 Name: Cray DeviceName: Hot Tub Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 467490520 Name: Playroom Shade DeviceName: Playroom Shade Type: Blind
HomeKitLink Siri Bridge: 731921 : Indigo Id: 151818458 Name: Master Mirror DeviceName: Master Sink Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 73249627 Name: Kitchen Island DeviceName: Kitchen Island Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 400481373 Name: Bedroom Night Scene DeviceName: Bedroom Night Scene Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 597338718 Name: Party Mode Candle lit DeviceName: Party Mode Candle Lit Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1105998823 Name: Outdoor lights off DeviceName: Outdoor Lights Off Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 1086770028 Name: Playroom DeviceName: Playroom Type: LightBulb
HomeKitLink Siri Bridge: 731921 : Indigo Id: 6400108 Name: Party Mode Disable DeviceName: Party Mode Disable Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 405718129 Name: Party Mode Enable DeviceName: Party Mode Enable Type: Switch
HomeKitLink Siri Bridge: 731921 : Indigo Id: 137586430 Name: Pantry DeviceName: Pantry Type: LightBulb
