Device Extensions continued
Maybe. ;)
I'll take a look at this, and see if it's possible for me to update the plugin to fix known bugs. If you have a bug, even if you reported it previously, please create a new issue at:
https://github.com/FlyingDiver/Indigo-D ... ons/issues
I'll copy over the existing issues from C4W's repository.
There's no license attached to the plugin, so we need to investigate that.
Different Computers
Re: Device Extensions continued
Post by Different Computers »
I'm taking another look at my "yellow" plugins and this is one.
Any thoughts about whether this will be updated for >2022.2?
juntta
Post by juntta »
Any News if this will be updated?
Heating season is just around the corner and need the thermostat wrapper…
DaveL17
Post by DaveL17 »
IMO, it's not likely that this (or frankly any of Colorado Four Wheeler's plugins) will be updated to Python 3. Many of the libraries that he uses in his plugins are proprietary and copyrighted.
My Plugins and Scripts
juntta
Post by juntta »
This was actually what I was afraid of based on activity in this thread.
Are there any other plugins that would provide similar functionality as this plugins thermostat wrapper?
Need is to have thermostat device in Home app so User can set heating setpoint in Home app and I can control HVAC unit via Indigo with action Groups (Python script + Modbus TCP connection). So basically nice UI (because of WAF) is needed!
Different Computers
My needs are simpler than above.
I'm looking for a way to take Celsius temps and have them displayed as Fahrenheit, and to show contact sensor on/off as Open/closed.
But seriously that latter really should be a core program feature.
on the temp thing: All I can imagine doing is creating a script that turns the °C temp into °F variable values.
DaveL17
Post by DaveL17 »
Different Computers wrote:I'm looking for a way to take Celsius temps and have them displayed as Fahrenheit, and to show contact sensor on/off as Open/closed.
Have a look at the Adapters plugin. I've been using it pretty much since it came out (I'm also the one that updated it to Python 3). It has several built-in "Pre-defined Scale Adapters" (i.e., ºC to ºF). It doesn't have a pre-defined adapter for boolean values like on/off, but it has a Custom Formula adapter where you're only constrained by your imagination (essentially).
Screenshot 2023-10-08 at 10.45.37 AM-2.png (428.45 KiB) Viewed 11986 times
jay (support)
Post by jay (support) »
Different Computers wrote:show contact sensor on/off as Open/closed.
Show where?
Different Computers
My contact sensors all show as “on/off”… pretty much everywhere.
Freezer door.png (309.9 KiB) Viewed 11929 times
jay (support)
We agree that a configuration option for displaying different boolean pairs is a good idea, and has been on the request list for a while. Other more significant functionality has always been higher priority.
