Example - Adding Indigo Data to Calendar
Share your macOS, iOS, and iPadOS shortcuts here. Post your shortcut in a new topic and be sure to describe thoroughly (screenshots, full text of any scripts, apps used, etc).
DaveL17
Post by DaveL17 »
Level of Difficulty: Moderate
Knowledge of Shortcuts: Moderate
This example shows one way to create a new Calendar event from Indigo with included data. This kind of automation is probably most useful for tracking things that happen infrequently--you could easily overwhelm your calendar with something that happens multiple times per day. This is a bare minimum example that's meant to show the necessary pieces. It assumes that all the necessary pieces are set up on your Indigo server machine (access to Calendar, etc.)
You'll need three things at least:
  • Some way to cause the Shortcut to run - in this case, an embedded script that's fired using an Indigo Action.
  • An Apple Shortcut to process the incoming data and create the Calendar event.
  • An Apple Calendar to add the data to - I'd recommend a separate calendar (I've uncreatively called mine "Indigo").
Screenshot 2023-04-24 at 10.15.20 AM.png (189.65 KiB) Viewed 2458 times
Add the following code to the Action's Execute Script action:
import os
Obviously, you'll need to tailor the code to fit your situation (embedded scripts need to complete within 10 seconds, otherwise they should be added as linked scripts). "Post Event to Calendar" is the precise name of the shortcut (you might call yours something else, for example). Note that "Show Compose Sheet" is unchecked, otherwise it will open a dialog on the host machine and expect additional input/revision.
This example shows the event being added as an all day event; it could be modified to include a timestamp or time(s) to make the event more specific. You could also add more data to the payload to include things like location and notes (it would require passing the data in a recognizable format like JSON.).
A version of this example is also posted to the Apple Shortcuts Wiki
My Plugins and Scripts
DaveL17
Re: Example - Adding Indigo Data to Calendar
Post by DaveL17 »
This shortcut is available in the Indigo File Library
Here's an example to show how you can pass a more complex object to the shortcut.
Screenshot 2023-04-24 at 3.37.36 PM.png (18.93 KiB) Viewed 2420 times
Note the construction of the inputs (the shortcut is very particular regarding the format of the inputs). There iares likely other ways to do it.**
import os
import json
# If key 'AllDay' is set to "True" it will override the Start and End times.
# Double braces are required at the ends of the payload to ensure they're included (and not mistaken for a format specifier).
title = "My Title"
location = "My Location"
notes = "My Notes"
start = "11:00 AM"
end = "1:00 PM"
all_day = "False"  # a string
payload = f'{{"Title":"{title}", "Location":"{location}", "Notes":"{notes}", "Start":"{start}", "End":"{end}", "AllDay":"{all_day}"}}'
os.system(f'/usr/bin/shortcuts run "Post Event to Calendar" <<< \'{payload}\'')
  • A Title element is required, but the other elements are optional depending on your event data. For example, Start and End times aren't required if you create your events as "All Day" events.
  • Emoji characters are allowed in text fields (i.e., Title, Location, Notes).
  • Start and End times can be descriptive. For example, Start: "11:00 AM" and End: "Tomorrow at 1:00 PM"
Screenshot 2023-04-24 at 3.35.28 PM.png (62.88 KiB) Viewed 2420 times
** Here is another option to format the data for transmittal to the Shortcut:
payload = {
    "Title": "My Title",
    "Location": "My Location",
    "Notes": "My Notes",
    "Start": "11:00 AM",
    "End": "1:00 PM",
    "Calendar": "Indigo",
    "AllDay": True  # a boolean
payloadj = json.dumps(payload)
result = subprocess.run(["/usr/bin/shortcuts", "run", "Post Event to Calendar"],
                        input=payloadj.encode("utf-8"),
                        capture_output=True,
                        timeout=10
print(f"Return Code: {result.returncode}")
print(f"Output: {result.stdout.decode('utf-8')}")
print(f"Errors: {result.stderr.decode('utf-8')}")
McJohn
Post by McJohn »
Hi Dave,
Thanks for this very interesting information, nice job!
It this also possible the other way around?
Get data from the Apple Calendar app into Indigo?
John
DaveL17
Post by DaveL17 »
Hi John - thanks. Yes it is possible. See this post for one way to do it: viewtopic.php?f=298&t=27014
McJohn
Post by McJohn »
Thanks! Nice job Dave!
I'm going to play with it on these rainy and cold days here.
John
DaveL17
Post by DaveL17 »
I added another option for sending data to the Shortcut to the example above using the subprocess() library.
Return to “Apple Shortcuts”
