Triggering on payload contents
berkinet
Post by berkinet »
I wish to monitor my wireless sprinkler system to be sure no watering events are missed. The key to this is the sprinkler controller that sends a MQTT message at the start and end of each session. I would like to trigger on the end-of-session messages and use them to reset a timer. Then, if the timer ever runs down, I will know I have a problem.
The question is, how do I trigger on an MQTT payload rather than the topic? For example, here is a typical end of session message:
cm/LinkTap2/up/0C928728004B1200 {"cmd":7,"gw_id":"27D88728004B1200","dev_stat":{"dev_id":"0C928728004B1200","plan_mode":0,"plan_sn":0,"is_rf_linked":true,"is_flm_plugin":true,"is_fall":false,"is_broken":false,"is_cutoff":false,"is_leak":false,"is_clog":false,"signal":83,"battery":100,"child_lock":0,"is_manual_mode":false,"is_watering":false,"is_final":false,"total_duration":0,"remain_duration":0,"speed":0.00,"volume":0.00,"volume_limit":0.00,"failsafe_duration":0}}
The key, in fact the only, part of that message I care about is the "cmd":7 (end of watering).
I know I can read the last_payload from the MQTT Connector in a script and reset the timer that way. But, I was wondering if there is a way to do this just using the MQTT plugins.
TIA
Re: Triggering on payload contents
You could create a "Generic" shim device and then trigger on the state corresponding to the "cmd" field.
berkinet
Post by berkinet »
FlyingDiver wrote:You could create a "Generic" shim device and then trigger on the state corresponding to the "cmd" field.
Thanks. Makes sense.
berkinet
Post by berkinet »
Well, it sounded good. This configuration...
Screenshot 2023-04-01 at 18.35.59.png (197.46 KiB) Viewed 2573 times
Throws this...
   MQTT Received                   cm/LinkTap/up/67AF5F25004B1200_2 {"cmd":3,"gw_id":"5150D91D004B1200","dev_stat":{"dev_id":"67AF5F25004B1200_2","plan_mode":0,"plan_sn":0,"is_rf_linked":true,"is_flm_plugin":true,"is_fall":false,"is_broken":false,"is_cutoff":true,"is_leak":false,"is_clog":false,"signal":72,"battery":100,"child_lock":0,"is_manual_mode":false,"is_watering":true,"is_final":true,"total_duration":3091,"remain_duration":961,"speed":0.00,"volume":161.52,"volume_limit":0.00,"failsafe_duration":0}}
   MQTT Shims Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 138, in runConcurrentThread
  File "plugin.py", line 165, in processMessages
  File "plugin.py", line 289, in update
type: 'int' object has no attribute 'strip'
   MQTT Shims Error                plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
That's not going to work. The "Unique ID" for for identifying the specific device sending the MQTT messages, In your case, it's the string "67AF5F25004B1200_2" in the message topic. So you need to change those fields to location = topic, field = 3 (zero based), value = "67AF5F25004B1200_2".
Then put a period "." in the Multi-Key States field, and when you get a message the plugin should populate the "cmd" custom state with the value.
berkinet
Post by berkinet »
FlyingDiver wrote:That's not going to work. The "Unique ID" for for identifying the specific device sending the MQTT messages, In your case, it's the string "67AF5F25004B1200_2" in the message topic. So you need to change those fields to location = topic, field = 3 (zero based), value = "67AF5F25004B1200_2".
Ah. That is a problem then. I don’t really care which device actually watered, Just if some device watered. So, any message with cmd=7 is sufficient. If I key on the specific device, I’d need 8 shim devices. (the cmd:3 was a status update message that happened to arrive when I saved the device)
Then use field 1 and the value "LinkTap".
berkinet
Post by berkinet »
FlyingDiver wrote:Then use field 1 and the value "LinkTap".
I realize I oversimplified this. In fact, I have two MQTT sources, LinkTap and LinkTap2. So, the pattern (re) is:
cm/*/up/*  '{"cmd":7, .*}
I guess I can key on field 2, value = "up"
Yeah, that should work. Just make sure your connector trigger is going to work for both:
Match: cm
Any:
Match: up
Any:
Or create two triggers but with the same Message Type.
berkinet
Post by berkinet »
FlyingDiver wrote:Yeah, that should work. Just make sure your connector trigger is going to work for both:
Match: cm
Any:
Match: up
Any:
All the rest of the parts were already working, so all I needed to do was find an easy and visible means to restart the timer. That is all working now. Thanks again.
Return to “MQTT”
