Hi all,
I'm trying to get information from my battery inverter via MQTT, which i've managed to do quite successfully. However I can't get the information from the topic GivEnergy/SA2230***/Power/Power/Grid_Power because when configuring the topic component match, it will not let you have two names that are the same I.E. "power" "power".
Is there any way around this?
Items with black lines though are my inverter serial number.
MQTT - Topics with same name
- Screenshot 2022-12-31 at 15.20.06 copy.jpg (455.69 KiB) Viewed 1780 times
- FlyingDiver
Re: MQTT - Topics with same name
Huh. I'll have to look at that. Can you open an issue for this in the GitHub repository?
Ok, i'll give it a go, not done that before!
Done!
Done!
- FlyingDiver
You did it right. Try https://github.com/FlyingDiver/Indigo-M ... g/2022.0.5
Wow, super quick reply! Thank you, i'll give it a try now
Tested and all working, thank you
Super impressed, fixed in under two hours!! Happy New Year Flying Diver!!
Martin
Martin
