Hi all,
I do not know if this is a corner case of what, but I would like to make a match like this, and then insert the payload into a variable.
But I feel that the "column" in the last match is causing the problem, could it be the reason?
Marco
Trigger - Match String containing "column"
- Screenshot 2022-12-15 alle 20.59.18.png (125.81 KiB) Viewed 1448 times
- FlyingDiver
Re: Trigger - Match String containing "column"
I need to see the actual topic string, from Explorer or (better) MQTT Connector debug.
And I assume you meant "colon", not "column".
Yes, of course, but Safari decided to correct it
Here MQTT Explorer
and here the MQTT Connector Debug
Here MQTT Explorer
esense Topic Received - AmazFit Giorgia: Match OK: 'devices' == 'devices'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: match.split = 'Match' 'mifit:fefc0f0f32d2'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: topic_part 2 = 'known:fefc0f0f32d2'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: Match Failed: 'mifit:fefc0f0f32d2' != 'known:fefc0f0f32d2'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: Matching complete, is_match = False
MQTT Connector Debug Local MQTT: Message topic: espresense/devices/known:fefc0f0f32d2/bagno_og, payload = {"id":"known:fefc0f0f32d2","idType":210,"rssi@1m":-71,"rssi":-58,"raw":0.43,"distance":0.44,"speed":-0.00,"mac":"fefc0f0f32d2","interval":2302}
MQTT Connector Debug Local MQTT: processReceivedMessage: espresense/devices/known:fefc0f0f32d2/bagno_og, payload: {"id":"known:fefc0f0f32d2","idType":210,"rssi@1m":-71,"rssi":-58,"raw":0.43,"distance":0.44,"speed":-0.00,"mac":"fefc0f0f32d2","interval":2302}
MQTT Connector Debug Local MQTT: Saved states, topic: espresense/devices/known:fefc0f0f32d2/bagno_og, payload: {"id":"known:fefc0f0f32d2","idType":210,"rssi@1m":-71,"rssi":-58,"raw":0.43,"distance":0.44,"speed":-0.00,"mac":"fefc0f0f32d2","interval":2302}
MQTT Connector Debug ESPresense Topic Received - Bagno OG: type = topicMatch, broker = 1038765987
MQTT Connector Debug ESPresense Topic Received - Bagno OG: topic_parts = ['espresense', 'devices', 'known:fefc0f0f32d2', 'bagno_og']
MQTT Connector Debug ESPresense Topic Received - Bagno OG: match_list = match_list : (list)
Item : Match: espresense (string)
Item : Match: rooms (string)
Item : Match: bagno_og (string)
Item : Any: (string)
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: match_list = match_list : (list)
Item : Match: devices (string)
Item : Match: mifit:fefc0f0f32d2 (string)
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: match.split = 'Match' 'espresense'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: topic_part 0 = 'espresense'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: Match OK: 'espresense' == 'espresense'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: match.split = 'Match' 'devices'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: topic_part 1 = 'devices'
MQTT Connector Debug ESPresense Topic Received - AmazFit Giorgia: Match OK: 'devices' == 'devices'
MQTT Connector Debug Tapparella Lisa 1: deviceUpdated: doExcludes = False, listedDevice = False
MQTT Connector Debug Tapparella Lisa 1: deviceUpdated: id = 773580404, devList = published_devices : (list)
MQTT Connector Debug Local MQTT: Message topic: shellies/shellyplug-s-B4B29E/relay/0/power, payload = 0.00
MQTT Connector Debug Local MQTT: processReceivedMessage: shellies/shellyplug-s-B4B29E/relay/0/power, payload: 0.00
- Screenshot 2022-12-15 alle 21.04.40.png (185.11 KiB) Viewed 1445 times
- FlyingDiver
That looks like it should be working. Do you have (or can get) a log segment where that topic is actually received. It's not in the log segment you posted.
