Triggering a zigbee device
lazlohollyfeld
Post by lazlohollyfeld »
Does anyone have any examples of triggering a zigbee device to do [something]?
I've got a bunch of leak sensors working and set-up, now I want to send an on or off message to a water valve.. The water valve is currently being read - just can't get it to do anything!
I've been trying different things and looked thru the board but can't seem to find any good examples..
thanks in advance!
tazswe
Re: Triggering a zigbee device
Post by tazswe »
How are you communicating with the zigbeedevices?
I use mqtt connector and mqttshims and it’s working great.
Sent from my iPad with Tapatalk
lazlohollyfeld
sorry - i thought that was obvious as I posted in this board :)
yes - reading is no problem - I have it all worked out with this MQTT plugin & shims.. Now I am trying to figure out how to send an action to a zigbee device... There are a lot of examples for reading from devices in this board - but I haven't been able to find anything for sending actions..
thanks!
Do you know the topic and payload you need to send to get the action you want?
tazswe
Post by tazswe »
As an exempel, this is my devicesettings for a simple power on/off device. If you get this right you can trigger it on and of like a normal device.
This is how it looks in mqtt Explorer.
Not sure about the settings for your device but you can most probably find it here.
https://www.zigbee2mqtt.io/supported-devices/
lazlohollyfeld
thanks for the quick response!
No luck based on your example..
here is my setup - no problem reading the device - and I can trigger to open/close via the zigbee2mqtt app, so I know it works.. Do I need to modify any of the device/variable control settings in the broker device?
tazswe
Post by tazswe »
Did you find your device here?
lazlohollyfeld
Yes - no problems with reading it - only controlling it.
Here is my valve:
https://www.zigbee2mqtt.io/devices/TS01 ... 0111-valve
Thx
Clear the MQTT Explorer memory, sent the command to control the device from zigbee2mqtt, then show what Explorer sees.
Better yet, enable logging on the MQTT Connector and show the Indigo log.
We need to see EXACTLY what's getting sent to the device that's controlling it. That's very hard to do with MQTT Explorer.
lazlohollyfeld
see attached screenshots - lmk if I missed anything..
re: Clear the MQTT Explorer memory
- i cleared the topic histories from the relevant devices - not sure if thats what you were looking-for...?
In order to test from indigo - i've been using the "Turn On" and "Turn Off" buttons on the device in indigo - assuming that's correct...
thanks!
debug log.png (110.51 KiB) Viewed 3205 times
Cut and paste the log. Never do screen shots of the log.
I thought you said you could control the device from the zigbee2mqtt app. I need to see the connector logs when you do that (not from the plugin). If that works.
lazlohollyfeld
hopefully this is what you need -
I went into zigbee2mqtt,
opened the device
went to "exposes"
clicked on on/off
here is the log from indigo:
Oct 31, 2022 at 1:34:06 PM
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Message topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload = {"linkquality":87,"state":"OFF"}
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: processReceivedMessage: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload: {"linkquality":87,"state":"OFF"}
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Saved states, topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload: {"linkquality":87,"state":"OFF"}
   MQTT Connector Debug            Receive Sav Water Sensor: type = topicMatch, broker = 1820104977
   MQTT Connector Debug            UTILITY_DEVICES: type = topicMatch, broker = 1820104977
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Message topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/state, payload = OFF
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: processReceivedMessage: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/state, payload: OFF
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Saved states, topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/state, payload: OFF
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Message topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload = 87
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: processReceivedMessage: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload: 87
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Saved states, topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload: 87
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Message topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload = {"linkquality":90,"state":"OFF"}
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: processReceivedMessage: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload: {"linkquality":90,"state":"OFF"}
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Saved states, topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload: {"linkquality":90,"state":"OFF"}
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Message topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload = 90
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: processReceivedMessage: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload: 90
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Saved states, topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload: 90
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Message topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload = {"linkquality":99,"state":"ON"}
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: processReceivedMessage: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload: {"linkquality":99,"state":"ON"}
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Saved states, topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF, payload: {"linkquality":99,"state":"ON"}
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Message topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/state, payload = ON
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: processReceivedMessage: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/state, payload: ON
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Saved states, topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/state, payload: ON
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Message topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload = 99
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: processReceivedMessage: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload: 99
   MQTT Connector Debug            NEW Zigbee2MQTT Connection: Saved states, topic: zigbee2mqtt/UTILITY_DEVICES/MAIN_WATER_SHUTOFF/linkquality, payload: 99
Try setting up actions for the connector that has these settings:
payload = ON
and
payload = OFF
Do they control the device?
lazlohollyfeld
thanks a TON for your responsiveness - i'll have to do that tonight (some of us don't yet hold the distinction of "Retired Computer and Network Geek" :) )
Return to “MQTT”
