Yet to test it thoroughly (the room with the AC is occupied by others who have great dislike at my testing routine!!) but actions not generating errors in the log.
I don't think so. When COMFORT is enabled the manual states:I wonder is Econo is equivalent to Comfort. I have this working with mine
When ECONO or QUIET are enabled the manual states:The flow of air will be in the upward direction while in COOL/DRY operation and in the downward direction while in HEAT operation, which will provide a comfortable wind that will not come in direct contact with people
We won't't use the ECONO or QUIET functions via Indigo (if ever!), so there is no reason, other than completeness to pursue these further. I will test further when I can get unhindered access to the actual unit and let you know the outcome.ECONO operation enables efficient operation by limiting the maximum power consumption. This function is useful to prevent the circuit breaker from tripping when the unit operates alongside other appliances on the same circuit.
OUTDOOR UNIT QUIET operation lowers the noise level of the outdoor unit by changing the frequency and fan speed of the outdoor unit. This function is convenient during the night-time operation.
Again, can I thank you for the prompt and accurate responses in adapting your plugin to the Alira. Perhaps we can find a way of shouting you a pint - although the current Australia/UK airfares would make it VERY expensive
Thanks again
mclass
