Strategies for MQTT devices
I just downloaded FlyingDiver's MQTT broker and connector plugins. Currently I'm using an ESP32 and a breakout board to plan my door state sensors for the home project coming up. Up to this point I was using the UDP Listener plug-in to listen for UDP packets from the ESP32, which would send out a JSON payload when a door state changed.
With MQTT I can eliminate the UDP approach and use a tool like MQTT Explorer to see the state of the broker, which is very nice for debugging.
I've organized my doors states like so:
home/door/utility/state
home/door/front/state
home/door/rear/state
and so on. The value of each of these is 0 (closed) or 1 (open)
What I'm wondering about now is how to organize my 21 door states. Should I create a separate MQTT connector device for each door state, or should I create one MQTT connector that subscribes to all 21 door states? In any case, I'm going to need to setup a trigger to run a script on receipt of a specific topic match. Thoughts?
And finally, thank you FlyingDiver for these excellent plugins!
- FlyingDiver
You want one connector device for the connection to the broker. You want a shim device for each door. You’ll need one trigger to handle all the door devices. You’ll use the door name as the unique id for the devices.
- FlyingDiver
Re: Strategies for MQTT devices
And just subscribe to home/#.
Ok, I didn't know I needed the Shims plugin. That's installed now.
Just to be clear, this is how I have things setup right now... I have a MQTT Connector subscribed to cdb/# (not using home anymore, using cdb instead).
I also have an MQTT shim for a particular door, but am not sure how to configure that.
- Screen Shot 2022-05-23 at 1.46.07 PM.png (300.15 KiB) Viewed 3094 times
- Screen Shot 2022-05-23 at 1.45.38 PM.png (288.49 KiB) Viewed 3094 times
And just so you know how I'm publishing, here's. a screenshot of the door states from MQTT Explorer:
- Screen Shot 2022-05-23 at 1.49.00 PM.png (277.83 KiB) Viewed 3094 times
- FlyingDiver
Start with this thread post and see if it answers your questions.
viewtopic.php?f=316&t=26171#p210518
- FlyingDiver
Thanks for pointing me to those resources. After reading and trying a few things, I now have it working, though I'm not quite sure how
Following up with some food for thought.
I'm wondering the best way to structure my MQTT tree. What I have so far are three levels that comprise an object:
Level 0: Home name ('cdb' in my case)
Level 1: the item type ('door', 'window', or whatever)
Level 2: the name ('utility', 'front', 'rear', etc)
And then under there, either raw or JSON data for specific attributes for that object.
Is there a better, more granular way?
- FlyingDiver
That seems perfectly reasonable. The alternative I've seen is to have sub-topics for each possible attribute, with only raw payloads. But since we can deal with JSON payloads fairly easily, I wouldn't do that.
If you have all the attributes of a device in a simple JSON dict, then you can use the mutli-states key field (with a "." in the field) to put all the attributes in device states.
Excellent. I'm now going to retire UDP Listener, which I was using to listen for messages from the Arduino and then process them through a Python script.
Thank you FlyingDiver for making great plugins.
I have only now stared working my way back through older posts to see what I can learn and I came across your post. I don't know if you knew about this, but there are two forms of wild cards in MQTT. The # as noted already in this thread, and the +.boisy wrote:...
The + may be used to replace any single level in a topic. So, the pattern home/door/+/state would match all 3 of your topics.
