iRoomba iRobot Plugin
Tue Dec 08, 2020 9:42 am
t-star offline
Re: iRoomba iRobot Plugin
Start, Pause and dock work via plugin. have not tried anything else yet. looks good so far. As a note others. I did have to check the force SSL23 box for it to work.
Wed Mar 10, 2021 1:50 pm
boekweg offline
Hi Glenn, I have been using the iRoomba plugin for quite a while now and it works great and never fails on my 900 series. I have plugin 0.5.0
I bought another iRoomba i7 series for upstairs and it looks like I'm able to get it as a device in Indigo when I use the ssl checkbox, but the new created device only acts as a copy of my first 900 series. So If I start my 900 series machine I have two devices in Indigo that respond to it, but newly created device doesn't. Is there something that I have to alter to get two separate machines in Indigo? I Tried the later plugin version that I found in the user forum but that one does nt work at all on my roomba's.
- Paul
Wed Mar 10, 2021 2:18 pm
GlennNZ offline
That’s no good.
For you to run 2 or more iroombas that plugin has to connect/disconnect. In the plugin config setting there is a checkbox to enable multiple iroomba support. ‘Continuous connection;uncheck to enable multiple iroomba support’.
If haven’t stopped this - try this in first instance and if ongoing issues - PM me the a few logs/including getting password.
i7 is supported and should work...
Glenn
Fri Mar 26, 2021 4:32 am
Argelix offline
I just installed 0.5.6 on a new Indigo-installation on a new Mac Mini and hooked up a Roomba 980 and a Roomba s9+. Installing mqtt took quite a bit of trial error and getting the password for the 980 was a hassle. Somewhere (Indigo?) there is a 10s timeout and it seems to take a tiny bit over that. After about 20 tries it managed to fetch it though and since then everything kind of works.
I have an action to start both of them, it's seems to be pure luck if any of them start. The action to dock them both has the same problem; and it seems the s9+ needs to be paused first, I never got it to just dock. The 980 seems to have more communication problems, in both cases I would say the WiFi coverage should be good enough.
I turned on debug logging, two things stood out:
sometimes it prints "Error within RoombaAction:'NoneType' object has no attribute 'send_command'".
Here is the log of one action:
 Action Group                    Start cleaning
 iRobot-Roomba Debug             startRoombaAction for Roomba - Top: Action : start
 iRobot-Roomba Debug             connecting Roomba Device: Roomba - Top
 iRobot-Roomba Debug             Using config file: /Users/dlorenz/Documents/Indigo-iRobotRoomba/192.168.178.1
 iRobot-Roomba Debug             CONTINUOUS connection
 iRobot-Roomba Debug             Reading Config File: 192.168.178.142-config.ini
 iRobot-Roomba Debug             Reading config file... /Users/dlorenz/Documents/Indigo-iRobotRoomba/192.168.1
 iRobot-Roomba Debug             reading info from config file /Users/dlorenz/Documents/Indigo-iRobotRoomba/19
 iRobot-Roomba Debug             Sections ['192.168.178.142']
 iRobot-Roomba Debug             Posting DECODED data
 iRobot-Roomba Debug             Connecting: Top Roomba  :  192.168.178.142  :  :1:1616662260:ejtcWX5r4nn5KghP
 iRobot-Roomba Debug             Connecting Top Roomba
 iRobot-Roomba Debug             Selecting the best SSL TLS Settings
 iRobot-Roomba Debug             s9 iRoomba VERSION:  Using Protocol SSLv23
 iRobot-Roomba Debug             MQTT Client Succesfully setup
 iRobot-Roomba Debug             Client Connect Running now Top Roomba
 iRobot-Roomba Debug             Client LoopStart Running now Top Roomba
 iRobot-Roomba Debug             Roomba Connected Top Roomba
 iRobot-Roomba Debug             Received COMMAND: start
 iRobot-Roomba Debug             Publishing Roomba Command : {"command": "start", "time": 1616755560, "initiat
 iRobot-Roomba Debug             disconnecting Roomba Device: Roomba - Top
 iRobot-Roomba Debug             {u'state': OrderedDict([(u'reported', OrderedDict([(u'batPct', 100), (u'batte
 iRobot-Roomba Debug             Disconnected From Roomba Top Roomba
 iRobot-Roomba Debug             getRoomba Info Running..
 iRobot-Roomba Debug             getRoombaInfo for Roomba - Top
 iRobot-Roomba Debug             startRoombaAction for Roomba - Bottom: Action : start
 iRobot-Roomba Debug             Publishing Roomba Command : {"command": "start", "time": 1616755570, "initiat
 iRobot-Roomba Debug             disconnecting Roomba Device: Roomba - Bottom
In the end it is disconnecting from Roomba - Bottom, then Disconnected from Top Roomba and *then* disconnecting from Roomba - Top? Also, there never was a Disconnected from Bottom Roomba. Usually I would say there is some multithreading going on but as far as I understood the plugin can only ever talk to one Roomba at a time, so how can the logging be out of order? Maybe somewhere the next connection is started while the old one is still going on and that spills over? Just guessing...
I'd be happy to help analyzing/fixing these problems, I know just enough about programming to be dangerous :-)
Dix
Fri Mar 26, 2021 4:54 pm
GlennNZ offline
That’s no good.
The get password bit is a bit of a pain - more so have to press the indigo button and the iroomba button combination within a few seconds of each other. The indigo dialog timeout doesn’t affect whether password got or not. But once done = done.
The other aspect - probably is the dual connection issue. I only have one, as went in another manufacturers direction. Was tempted by S9+ but stock non-existent and reviews about failures somewhat off-putting. Plus the price!
Would check update device frequency is high in config settings.
Continuous connection off (which seems to be despite the logging, which I need to check)
I’ll have a look and see if can make my one Roomba look like 2 to test. Currently based on IP address; but will see about modifying this bit temporality.
The first bit of what you have logged (below) - all makes sense - this is a command being sent, plugin connecting to iRoomba (because cannot stay connected), and sending command and then disconnecting.
What follows is the usual connection after a period of time. Check your Plugin Config 'Update device status frequency (minutes)'
Set this to 10 minutes or so. That what is clashing here I believe...
On further looking I can see issue which will try to fix in 0.5.8 = does come about when already connected to one device and quickly send command to the other.
Changing the Update frequency here to a longer number will help and stop your example. But will see if I can more robustly fix.
(Unfortunately I can't test as one iroomba just rejects a 2nd separate connection attempt ...)
Clearly more and more 2-3-4 iroomba homes and have been a couple of issues on this front. Will see what I can come up with.
Looking now - its problematic to test without 2 iroombas but will see what can do.
On the other note of some commands failing to respond. The different models have different responses to different commands. Eg. Some dock only works if stopped first etc. so may need a combo of command stop-dock.
Edit:
See above pointers and can try 0.5.8 on github.
This is 0.5.8
https://github.com/Ghawken/Indigo-iRobo ... 1795644a32
0.5.8 is minor update but I believe will overcome most of the dual connection issues; by checking more robustly for device connected.
Below is far bigger update 0.6.0
Changes to continuous connection for all iRoombas connected; means instant commands and 60secondly updates of states for all devices
Can also have multiple devices for same iRoomba (not sure why would want to) and if Roomba Name is the same will all be duplicates. (caveat to this all iRoombas need to have distinct names set in their app - which yours do I see)
Pretty happy single device is working well with this version... but still hard to test two+ continuous connections. May still be some bugs, but believe the bulk of the work is done will just be sorting out the odd bug that I can't access.
Welcome to test and report back, and email PM/email/post debug log. (can drop back to 0.5.8 if this fails; nothing breaking on device front)
https://github.com/Ghawken/Indigo-iRobotRoomba
Glenn
Sun Mar 28, 2021 2:40 am
Argelix offline
I had never changed the update frequency from 10 minutes.
I first tried the current (Sunday European morning, 0.6.2) version from GitHub, that didn't find either of the configuration files so I had to get password on both of them. Although that worked, the plugin practically went into a reset loop because it would not find one of the Roombas.
After 5 mins of that I downgraded to 0.5.8; no more reset loop and it seems to work much better than 0.5.6. On the first try one didn't start and on the second try the other paused but didn't dock. But I might have been too impatient, on try 3 and 4 I saw some commands being executed up to a minute later.
Sun Mar 28, 2021 3:28 am
GlennNZ offline
Okay
Can you send me the debug log from 0.6.2? (of the reset loop? And may shed light as to why config files weren’t used)
(Should be saved in plug-in logs directory even if downgraded)
Will be something straightforward. May need to remove the reset (see below have done so blindly on 0.6.3)
But:
Any idea why it didn’t find the iroomba?
Nothing has changed with the config files - I have upgraded dev and prod machines back and forward versions and it has found and used them without skipping beat... Not sure why you had different behaviour. Presumably when went back to 0.5.8 didn't need to Get Password again? Still should be able to move up without needing to do this.
EDIT:
Timezones are going to be a bugger as usual
But can try 0.6.3 update just now
0.6.3
Changes Plugin Restart code given multiple devices- checks every hour and if no connected iRoomba after 4 checks will restart plugin.py.
(Found was needed as often after days -weeks-months of connection something fails at one end or another.  Restarting plugin and resetting the iRoomba connection completely was the best fix.  Nothing else completely worked)
But
Nothing has changed with Config Files or there support.
If failing to load config file following upgrade may be OSX security?
Can check files contents and copy and past old ones as needed. (I swap them from one computer to another as needed, via copy/paste)
Occasionally after updating from github find get security alert from Big Sur and need to then run
Terminal Command below:
sudo xattr -rd com.apple.quarantine /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.5/Plugins
As mentioned the major changes in 0.6.0 line are done, no going back now (well not easily)
Will be some minor bugs which need 2 connected iRoombas to trouble suit but some debug logs should enable that fairly quickly I would guess...
Glenn
Sun Mar 28, 2021 5:57 am
Argelix offline
unfortunately I didn't think to use debug for 0.6.2. No idea why it would not find the config files; going back to 0.5.8 I didn't need to do the passwords again.
I always get the security alerts, getting around it using system preferences, then reloading plugin and confirming once more, then it does run.
Testing 0.6.3: I didn't need to get the passwords again and there was no reset loop. But then, it finds both of them ok atm, seems to be stable. Trying it out the first time:
   iRobot-Roomba Debug             Roomba Name:Top Roomba
   iRobot-Roomba Debug             Roomba Name:Bottom Roomba
   iRobot-Roomba Debug             Connecting: Bottom Roomba  :  192.168.178.74  :  :1:1496074962:mVfImUOLM2iVO2NQ
   iRobot-Roomba Debug             Connection Roomba Error: not all arguments converted during string formatting
   iRobot-Roomba Debug             Attempting new Connection# 1
   iRobot-Roomba Debug             Connecting Bottom Roomba
   iRobot-Roomba Debug             Client Connect Running now Bottom Roomba
   iRobot-Roomba Debug             Connection Roomba Error: 61
   iRobot-Roomba Debug             Attempting new Connection# 2
   iRobot-Roomba Debug             Client LoopStart Running now Bottom Roomba
   iRobot-Roomba Debug             Publishing Roomba Command : {"command": "start", "time": 1616938253, "initiator": "localApp"}
   iRobot-Roomba Debug             Roomba Connected Bottom Roomba
Top Roomba (The s9+) doesn't start at all, it seems as if the plugin doesn‘t communicate with it at all. Although the device has a valid status, even when trying the action again:
   iRobot-Roomba Debug             Sending Command to myroomba:Bottom Roomba and action:start
   iRobot-Roomba Debug             Publishing Roomba Command : {"command": "start", "time": 1616938798, "initiator": "localApp"}
Same thing for stopping, only bottom roomba gets a command sent. I tried switching the order around and still only the Bottom Roomba got a command sent.
Reloading the plugin didn't change anything.
Sun Mar 28, 2021 2:14 pm
GlennNZ offline
Ok
Not sure system preferences would cover everything within the plugin. The string format error is odd, as is the config file access issue.
Update to new version - 0.6.4 - add new DebugOther checkbox - keep this enabled to maximise information. Check this one below:
When you the below "cannot be opened because the developer cannot be verified..." message
after downloading and updating plugin
Whilst this message is on screen, from a terminal run (copy and paste) the mentioned command below. (provided running Indigo 7.5 - otherwise change to version.
Once run, click Cancel on the image above. Indigo will show some red error messages, then reload the plugin and all should be up-to-date.
Are going to need some logs to get 2 connections working:
Old logs, including debug logs are saved in ‘Event logs folder’. Click the button to the top right of indigo log window and find the iroomba plugin folder.
Would suggest turning new log checkbox on.
Reload plugin, send a few commands to each iRoomba 10-20 seconds apparent and send me the log file? Either PM or upload somewhere that suits.
Mon Mar 29, 2021 12:58 am
Argelix offline
I sent a PM with the logs from yesterday and today with 0.6.4
Tue Mar 30, 2021 1:18 am
GlennNZ offline
Hi all,
Though should update this thread before I forget. After above PM and a couple of logs have helped resolved the few minor multiple connection issues.
New version on GitHub - overcomes above issues on our testing.
Version 0.6.8
Allows multiple (unlimited) vacuums/mops iroomba devices each continuous connected and instantaneously command-able. Status updates flow every 60 seconds.
Adds ‘evac’ command to empty iRoomba into bin
Add check for unknown states in case, new states/new robots/mops.
Fix Action for getInfo (shouldn't really be needed as all states updated every 1 minute)
Welcome to test further before release.
Sat Apr 24, 2021 10:36 pm
GlennNZ offline
New Release Here:
https://github.com/Ghawken/Indigo-iRobo ... /releases/
0.6.0 -0 .7.2
Summary of few updates summarised below:
Prior 0.6.0 - Adds SSL libraries to the plugin to bypass any issues with older versions of OSX having security/SSL issues
& 0.6.0 onwards
  • Updates code base to continuous connection for 1-100 iRoombas
  • Should fully support multiple iRoomba devices; almost continuous updates and immediate actions
  • Rewrite of Get Password code - moves to threaded; avoids UI Timeout errors
  • seems to be much less of a pain to get password
  • if iRoomba correctly makes noise and password fails for whatever reason, just press Get Password button again. Doesn't appear to need to press iRoomba button combo again.
  • Adds IP Address of iRoomba to Device State
  • Add MAC Address of iRoomba to Device Custom State
  • Add Menu Item - Debug Log Output for issues for posting.
  • Adds ability to update Roombas name from within Device Edit Box (only if name changed). Can rerun Get Password if needed but this update box obviously much easier.
  • Adds Further Debug Log check box
  • Updates to Plugin Config Menu - remove most options as all continuously connected
Note:
Terminal Command below: (change for version of Indigo - this example 7.5)
Plus: Soon to have 2 iRoombas to test more thoroughly on... Until then will leave this release here
But please report any issues...
Fri Apr 30, 2021 4:50 pm
GlennNZ offline
New Version 0.7.5
Continues from above with multiple iRoomabs supported.
Adds:
Save Last Command from Roomba (as an Action Group)
Enables you to copy the last run command from the App and save it as a Action Group
Enables Room, selective cleaning support for those iRoombas that allow this
Example:
From App Start cleaning on one or more rooms
Anytime after, but before other commands run
Go to Indigo, Create New Action Group, iRoomba Actions, Save Last Command
Select iRoomba Device, press button and save.
This command is now saved and accessible now and into the future
(if you change maps etc may need to be redone)
This appears the best way to get support for selective room-by-room cleaning. Unfortunately iRoomba doesn't publish names just region_id's that are somewhat random and may change.
So whilst could trial and error figure out what is what and rename etc.
The above seems to me a far better option and also far more future proof... May also allow creation of action group for unknown commands, or mop specific commands etc.
Give it a whirl:
Thu Jun 17, 2021 5:35 pm
GlennNZ offline
Release 0.8.5
In Plugin Store.. Combines updates as below
0.8.5
Creates Variable with Current Status of Each iRoomba Device for use in Virtual Devices Status
eg. Virtual Device for Clean Kitchen - set ON for Action Group Clean Kitchen, OFF - Dock
Status updates - select the variable for that device from variable
== "Alexa, Turn on Clean the Kitchen"
Converts each iRoomba to a Relay device with ON/OFF/Toggles - means more compatible with HomeKit/Alexa
THIS VERSION REMOVES OpenSSL libraries; this removes support for OSX versions lower than High Sierra
(TLS old version problem)
This removal is needed to support ongoing functions moving forward, if you are running an old version of OSX
stick with 0.7.5 below
(0.8.1 Bug Fix, 0.8.3 Change variable to True/False)
0.7.5
Few Logging changes
Couple of rare bug fixes
Add:
Save Last Command from Roomba (as Action Group)
Example:
0.7.2
Move to IP Address to differentiate iRoombas
Few bug fixes for connect/disconnect - hopefully starting up with needing restart
Add IP address as Device State as well for CP use
Default to forceSSL checkbox True - think needed for all versions now
Add Debug Log Menu Item for troubleshooting down the track
0.7.1
Further naming fixess
Move GetPassword Code to thread - so no more timeout messages!
Use GetPassword info to update device before connection
Add Mac Address to device State
0.7.0
Further Updates for iRoomba Name issues introduced in new multiple version
Along with 0.6.9 - Device Edit Name: This is needed if setup device with old config file with Wrong Name saved
Add:
Automatically update name from Stream if connected - should allow app renaming to be seemless
Ignore ConfigFile stored Name if device state Name exists instead - overcomes old ConfigFiles
Fix disconnectiRoomba - would disconnect all iroombas rather than just that selected
0.6.9
Fix for iRoomba name
Add Device Edit option to rename/update name of iroomba - this needs to match App Name
(on closing sets device state Name to that selected)
Will look at moving to MAC address etc. to overcome name issues
0.6.8
0.6.6
Hopefully fix evac - can't test this one
& fix for commands!
0.6.5
Add string unicode checks for names/text
0.6.4
Changes debug logging - adds Debug Other to enable to show more verbose logging without all the iRoomba communication
0.6.3
Nothing has changed with Config Files or theree support.
Can check files contents and copy and past old ones as needed. (I swap them from one computer to another as needed)
Multiple iRoombas supported continuously with immediate commands/status updates
0.6.0
Move to continuous connection for all iRoombas 1 - multiple
Moderate code base changes to faclitate
Update About links, remove a few unneeded menus
Fix updateStates menu link
Update Error messages to latest
Wed Aug 04, 2021 9:57 am
Mark offline
Hi all!
Very excited to find this plug-in!! I've just run my Roomba i6 1.5 times, so it's still building its map. I installed the plug-in. That went OK. I seem to have a slightly different plug-in config window. It's missing the frequency settings.
For Device Settings, the Roomba Password field is reporting "OK. Using Saved Config File." Hopefully that means I got that done correctly. I have Force Use of SSLv23 turned on.
Custom States reports:
BinFull = false
IP = xxx...
MAC = xxx...
Name = xxx...
software Ver = lewis+3.14.16...
but nothing else. My Roomba is currently recharging in the middle of its second "Vacuum Everywhere" job. As I couldn't figure out how to install paho-mqtt, perhaps that is the problem. Where can I find guidance, and the file(s), to install paho-mqtt?
Thanks in advance for any help you can offer. And BIG THANKS for creating and maintaining this plug-in. Hopefully I can get it working, as seeing status and starting a job from an Indigo control page would be amazing...
On a side note: I have the iRobot Roomba Home app (v5.7.0) installed on my iPhone X. Works fine, except every time I return to it, it reports "Not connected." I have to force quit the app and launch it again to get it to connect. Thoughts? Anybody else seeing this issue?
Page 12 of 18 1 ... 9, 10, 11, 12, 13, 14, 15 ... 18
