iRoomba iRobot Plugin
GlennNZ
Post by GlennNZ »
Hi all,
New iRoomba Robot Plugin to support the iRoomba mqtt communication protocol. (as of firmware v.2.2.9-1 29th December 2017). This was helped a lot by a recent python library for roomba control.
Models Supported: Confirmed in this post by other users.
- 980 Model https://store.irobot.com/default/roomba ... 80020.html
- 985 Model
- i7 and i7+ Model https://store.irobot.com/default/roomba ... 15020.html
- j7, j7+ combo
Currently - have it functioning well and it enables a continuous connection to one or more iroomba
The benefit of continuous connection is status is updated immediately - so can trigger events to occur which happen within a few seconds; Status is immediately updated.
The library I am using also supports mapping/drawing a map of cleaning - which I would imagine would look good on a control page. (I haven't worked through those aspects as yet - but have it on a todo list)
Installation:
If
Indigo 7 Only:
Needs paho-mqtt for python installed via terminal window:
Within a terminal Window:
 sudo pip install paho-mqtt
Or if using version of Indigo 2022.1 and python 3 version of plugin 0.9.13+
pip3 install paho-mqtt
Or if on latest Indigo 2023.2 + version, and python 3 plugin version of 0.9.35+
Does not need any libraries installed (well actually we need one more, aiohttp and paho-matt) but Indigo will manage this on install/or update!
So no terminal commands needed = just double click bundle to install.
https://www.indigodomo.com/pluginstore/132/
or
https://github.com/Ghawken/Indigo-iRobotRoomba
Setup
For this plugin to work correctly you irobot needs to have a fixed IP address so to know whom it is. Assign your iroomba a fixed IP address; either a router level (would be my recommendation) or within iroomba setup.
Install the plugin.
Configure the Plugin:
Create your iroomba Device
Edit Settings
Roomba IP Address: Enter the IP address (fixed ideally) of your iroomba robot
This can be a slightly tricky part as need to be quick between activating iroomba with holding Home button (four notes confirm) and pressing the Get Password button.
Indigo will also give a timeout error (as communication takes longer than allowed). This can be ignored.
This will possibility take a couple of goes to establish communication.
It then saves the communication password to a IP address based config file and will use this file if you happen to delete you device.
Status
The plugin reports the following status - and this is updated live in the setting of continuous communication.
Hopefully all straightforward
batPct - Battery Percentage
Binfull - true or false
Cycle - the cycle iroomba is currently performing
Error Code/Error Texts if any
RechargeM - time to be recharged
SqfFT - Square Feet cleaned
X & Y - Current Position
deviceStatus - running etc.
Actions
The plugin supports the following actions to control you iroomba.
What could go wrong:
1. Connection fails with a 'Broken Pipe' Error:
Debug info may display the following info about your iroomba during the Get Password connection phase:
iRobot-Roomba Debug Received: {
"robotname": "pmgk roomba rdc ",
"sku": "R980020",
"nc": 0,
"ver": "2",
[b]"proto": "http",[/b]
"ip": "192.168.1.13",
"hostname": "Roomba-",
[b]"sw": "v1.6.4", [/b]
"mac": "
This means that your iroomba is on very old software 1.6.4 and is still using its old http protocol. The iroomba automatically update when connected to cloud after a short period of time (unless blocked at firewall level).
This plugin only works on the newer firmware version.
Wait it out and your iroomba will be updated and try again.
2. If you do not have a fixed IP address for your device it will lose its connection when this is updated by your dhcp server. Set it to fixed.
3. Occasionally if the plugin loses its connection to iroomba it will restart the plugin itself to reestablish. It does this automatically with no user input required.
Glenn
RAID5
Re: iRoomba 980 iRobot Plugin
Post by RAID5 »
Hi
Does this plugin only work with 980 or does it also work with for example 696 that also have iRobot home app?
RAID5 "A happy Swede addicted to automation"
GlennNZ
Post by GlennNZ »
As far as I understand it should work with all Wi-Fi enabled Roombas (980, 960, 890, 690)
But obviously untested.
pmgendon
Post by pmgendon »
Hi Glen,
I just updated to 0.2.1 and I can't connect to the roomba, I,m sure I have the right IP address (192.168.1.13 ) and this is the log:
iRobot-Roomba Debug getRoombaPassword called: 1397712158
iRobot-Roomba Debug file should equal:/Users/++++/Documents/Indigo-iRobotRoomba/192.1668.1.13-config.ini
iRobot-Roomba Debug waiting on port: 5678 for data
iRobot-Roomba Error Error in plugin execution UiAction:
File "plugin.py", line 301, in getRoombaPassword
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/iRobot-Roomba.indigoPlugin/Contents/Server Plugin/roomba.py", line 78, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/iRobot-Roomba.indigoPlugin/Contents/Server Plugin/roomba.py", line 118, in get_password
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/iRobot-Roomba.indigoPlugin/Contents/Server Plugin/roomba.py", line 90, in receive_udp
gaierror: (8, 'nodename nor servname provided, or not known')
can you help me with this problem.
best!!
pmgendon
Post by pmgendon »
tried rebooting my mac, here's a revised version of the log
Dec 27, 2017, 7:59:25 PM
iRobot-Roomba Debug getRoombaPassword called: 531666929
iRobot-Roomba Debug file should equal:/Users/-----/Documents/Indigo-iRobotRoomba/192.168.1.13-config.ini
iRobot-Roomba Debug found 1 Roombas
iRobot-Roomba Make sure your robot (pmgk roomba rdc ) at IP 192.168.1.13 is on the Home Base and powered on (green lights on). Then press and hold the HOME button on your robot until it plays a series of tones (about 2 seconds). Release the button and your robot will flash WIFI light.
"sku": "R980020",
"nc": 0,
"ver": "2",
"proto": "http",
"hostname": "Roomba-6977840021932810",
"sw": "v1.6.4",
"mac": "F0:03:8C:53:35:3D"
iRobot-Roomba Debug
Roomba (pmgk roomba rdc ) IP address is: 192.168.1.13
iRobot-Roomba Debug Connection Error [Errno 61] Connection refused
iRobot-Roomba Error getting password. Follow the instructions and try again.
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/iRobot-Roomba.indigoPlugin/Contents/Server Plugin/roomba.py", line 157, in get_password
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 687, in send
error: [Errno 32] Broken pipe
GlennNZ
Post by GlennNZ »
pmgendon wrote:Hi Glen,
best!!
Sure.
Sorry the documentation is a bit lacking. (on the to do list)
From the log it would appear that you have the IP address wrong - 192.1668.1.13 - note the extra 6.
As per the window - need to hold down the home button until 4 notes are played and then click Get Password (really quickly!). Can try to press just before - but often needs a few goes.
Glenn
pmgendon
Post by pmgendon »
thanks for the reply, i feel dumb for that extra 6 :evil: .
this is the new error I'm getting:
iRobot-Roomba Debug file should equal:/Users/++++/Documents/Indigo-iRobotRoomba/192.168.1.13-config.ini
"sku": "R980020",
"nc": 0,
"ver": "2",
"proto": "http",
"sw": "v1.6.4",
iRobot-Roomba Debug
GlennNZ
Post by GlennNZ »
pmgendon wrote: "robotname": "pmgk roomba rdc ",
"sku": "R980020",
"nc": 0,
"ver": "2",
"proto": "http",
"sw": "v1.6.4",
iRobot-Roomba Debug
e
Thanks for this. Was writing another reply when this came through.
The interesting thing is the 'proto' http (!) and the sw of 1.6.4
You are on now quite old software for iRobot (is it blocked from connecting to the internet? As typically hard to stop it updating to new 2.2.9-1 sw)
This plugin won't work on that old version of software.
FlyerDiver - older plugin - still should work though.
Finding it now.
https://github.com/FlyingDiver/Indigo-Roomba
Although as soon as updates to newer software will die. If a new purchase would just leave alone for a few hours/day and will be on 2.2.9-1 software before you know it. Set up this plugin then.
Glenn
pmgendon
Post by pmgendon »
Awesome, thanks, it's a new purchase, i'll wait for the upgrade.
cheers, thanks for your help.
happy holidays!!
GlennNZ
Post by GlennNZ »
pmgendon wrote:Awesome, thanks, it's a new purchase, i'll wait for the upgrade.
happy holidays!!
Cool. Thanks. Let me know how you go.
If have one only would enable the “continuous connection” option in plugin config.
Thats how I run it and going well.
Keep meaning to add as default on - will do so on 0.22!
Glenn
pmgendon
Post by pmgendon »
It works great!
I binded a keypad button to the start the roomba and now I'm wondering how can I turn the button off once the roomba is done cleaning. I can't figure out how the status function works.
thanks
pm
GlennNZ
Post by GlennNZ »
pmgendon wrote:It works great!
thanks
pm
Hi
You mean a control page button?
The iRobot has separate action commands for start, stop etc. Mainly because there is also dock as command. I will create a action that toggles start/dock depending on status. I have a control page with status and then seperate buttons for start, resume, stop and dock.
The plugin has actions - create a Acton group - iRobot-Roomba actions, select your device and then - select from stop, start, dock or resume.
As I said I need to complete the documentation! Any questions ask away; as it make that process easier.
(have made a start and updated the first page)
Glenn
tatrog
Post by tatrog »
Communication Error and plugin keep restarting. New Roomba 980
I installed via PIP the Mqtt package and I get the following debug logs. Help please? I tried to install Mqtt again but it tells be that install has been satisfied. Thanks!
Stopped plugin "iRobot-Roomba 0.2.2"
Starting plugin "iRobot-Roomba 0.2.2" (pid 638)
iRobot-Roomba Debug logLevel = 10
Started plugin "iRobot-Roomba 0.2.2"
iRobot-Roomba Starting Roomba
iRobot-Roomba Debug updateFrequency = 86400.0
iRobot-Roomba Debug statusFrequency = 600.0
iRobot-Roomba Debug deviceStartComm called for Roomba Marvin
iRobot-Roomba Debug Continuous ON and not connected..
iRobot-Roomba Debug getRoombaInfo for Roomba Marvin
iRobot-Roomba Debug connecting Roomba Device: Roomba Marvin
iRobot-Roomba Debug Using config file: /Users/gerrytatro/Documents/Indigo-iRobotRoomba/192.168.55.230-config.ini
iRobot-Roomba Debug CONTINUOUS connection
iRobot-Roomba Debug Reading Config File: 192.168.55.230-config.ini
iRobot-Roomba Debug Reading config file... /Users/gerrytatro/Documents/Indigo-iRobotRoomba/192.168.55.230-config.ini
iRobot-Roomba Debug reading info from config file /Users/gerrytatro/Documents/Indigo-iRobotRoomba/192.168.55.230-config.ini
iRobot-Roomba Debug Sections ['192.168.55.230']
iRobot-Roomba Debug Posting DECODED data
iRobot-Roomba Debug Connecting: Marvin : 192.168.55.230 : bnfCuSe3xXYIJhSX
iRobot-Roomba Debug Connecting Marvin
iRobot-Roomba Debug Please install paho-mqtt '<sudo> pip install paho-mqtt' to use this library
iRobot-Roomba Debug Client Connect Running now Marvin
iRobot-Roomba Debug Connection Roomba Error: 'NoneType' object has no attribute 'connect'
iRobot-Roomba Debug Attempting new Connection# 1
iRobot-Roomba Debug Attempting new Connection# 2
iRobot-Roomba Debug Attempting new Connection# 3
iRobot-Roomba Debug Unable to connect Marvin
iRobot-Roomba Debug Setting restart switch....
GlennNZ
Post by GlennNZ »
tatrog wrote:Communication Error and plugin keep restarting. New Roomba 980
Sorry to hear about your troubles.
Can you post the contents of :
But it does look like paho-mqtt is not installed.
This is the code block causing the error:
HAVE_MQTT=False
    import paho.mqtt.client as mqtt
    HAVE_MQTT=True
except ImportError:
if not HAVE_MQTT:
       self.plugin.logger.debug(u"Please install paho-mqtt '<sudo> pip install paho-mqtt' to use this library")
        return False
It is possible you have two versions of python and you haven't installed it for the verison Indigo is using.
Away from Mac at moment - but could try below.
python2.7 -m pip install paho-mqtt
pmgendon
Post by pmgendon »
Hey !
thanks for the awesome work with this plugin.
Now I'm getting the following errors when running the start and dock commands:
Jan 9, 2018, 11:13:27 PM
Action Group roomba - ++ - rdc - start
iRobot-Roomba Error Error in plugin execution ExecuteAction:
File "plugin.py", line 544, in startRoombaAction
File "plugin.py", line 569, in RoombaAction
AttributeError: 'NoneType' object has no attribute 'send_command'
Action Group roomba - ++ - rdc - dock
File "plugin.py", line 556, in dockRoombaAction
the actions are not performed.
cheers!
pm
Return to “iRoomba iRobot Plugin”
