Error message upon installing 7.4.8
mundmc
Post by mundmc »
Not sure if I should post this here or on github. Upon installing the latest update, I get this message every several seconds:
Roku Network Remote Error Error executing effect for device id 1527675311 Traceback (most recent call last): File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkDeviceResponse.py", line 179, in executeEffects eval(u'rpDevice.' + effect.updateParam + u'(responseObj, rpCommand)') File "<string>", line 1, in <module> File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/rokuNetworkRemoteDevice.py", line 264, in updateDeviceStatusInfo channelNumber = deviceInfoDoc.find("channel").find("number").text AttributeError: 'NoneType' object has no attribute 'text'
Very much appreciate your many Indigo contributions!
justlen
Re: Error message upon installing 7.4.8
Post by justlen »
I too am getting the same error. The plugin does appear to be working, however.
Roku Network Remote Error       Error executing effect for device id 812584718
  File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkDeviceResponse.py", line 179, in executeEffects
  File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/rokuNetworkRemoteDevice.py", line 264, in updateDeviceStatusInfo
RogueProeliator
Post by RogueProeliator »
Sorry guys, I should be able to fix that up tonight -- those are part of some new states that I added that are only used for Roku TV devices. I tested this on my non-Roku TV and two Roku TVs, but it appears you guys have devices where the return isn't including that info. I will code it up to ignore the state if it isn't present -- which I should have done anyway.
This is technically a trapped error, just seeing the output from me logging it (that's why control should still be working). Anyhow, I'll get you a new version up to suppress the errors.
Adam
mundmc
Post by mundmc »
Awesome and thank you!
I should have included that this is a TV with built-in Roku functionality; I only use it for the IP control of the TV's On/Off and VOlume functions
justlen
Post by justlen »
Wow, thanks for the quick reply.
I've been doing some fun things with my elCheapo TCL/Roku TV. It normally displays a GeoChron clock, but if there is a NWS alert it kicks over to weather information.
RogueProeliator
Yeah, this is a state that only loads for TVs.. I think perhaps what is happening is that you two both have TVs that get in a state other than mine (different settings, input, configuration, something) so where mine always returned a value via the API, you guys are getting an empty result. No big deal, just didn't know that could come back in that manner.
Cool - that is what I use for the TVs that are potentially exposed to some weather (mostly humidity) on the screened porch and in shop. Honestly I am decently happy with them, especially for the price.
If you guys don't mind, try this beta version which attempts to address the issue you are seeing:
https://github.com/RogueProeliator/Indi ... 2.4.9-beta
Direct Download
If all looks good I will release that to the plugin store.
Adam
whmoorejr
Post by whmoorejr »
I'm still getting the same error. I think I downloaded the updated beta one.... but the info.plist still shows 2.4.8.
Here is the error message I'm getting...
   Roku Network Remote Error       Error executing effect for device id 398247524
<-- I get that x4 TVs about every 3 seconds.
Bill
My Plugin: My People
whmoorejr
Post by whmoorejr »
justlen wrote:... GeoChron clock, but if there is a NWS alert it kicks over to weather information.
<-- How do you have that set up? The one in my office has a CCTV NVR on HDMI1, my Indigo Server on HDMI2 and a RPI running domopad on HDMI3. After resizing some control pages for the TCL screen, the domopad is my preferred standard backdrop.... But I really like the clock idea.
Bill
RogueProeliator
I think that is what I get trying to do this from work computer... looks like I fudged up that ZIP download. I've since replaced it, and it is available from the releases page again or this direct URL:
https://github.com/RogueProeliator/Indi ... Plugin.zip
It most definitely should show .9 once updated. My apologies for that.
justlen
Post by justlen »
Similar setup. I have a Geochron Atlas on HDMI 1, An Action Group kicks it over to HDMI 2 connected to my Mini and AppleScripts throw up a full screen page with the alert. I would do it all in Indigo but they dropped AppleScript support, which for me killed a lot of the reasons why I use Indigo in the first place.
I know there are Pi based clocks that are similar to the Geochron.
justlen
Post by justlen »
That fixed it for me, and my Action Groups to control the TV work just dandy. Thanks!
Screen Shot 2021-01-22 at 3.04.52 PM.png (90.68 KiB) Viewed 5857 times
whmoorejr
Post by whmoorejr »
RogueProeliator wrote:I've since replaced it, and it is available from the releases page
:D I haven't tested everything the plugin can do, but all my stuff (on/off, input) are all working and no error messages.
justlen wrote:Switch TV to BBC
Sounds like there is still something screwy going on. :lol:
Bill
joeaug
Post by joeaug »
I'm still having this problem too and I am confused: was this fixed in the most recent release available on the Insteon Plugin Store or is there a different version to be downloaded from Git? ??
justlen
Post by justlen »
It's been awhile, but I believe I used the GitHub version.
joeaug
Post by joeaug »
Yes, I've just verified that as well :D
Return to “Roku Network Remote”
