Zwave Lock manager doesn't appear in plugin list
stewkenly
Post by stewkenly »
Hi there,
I just noticed within the past week that the Zwave Lock Manager Plugin doesn't appear accessible in any way even though its installed and enabled. Has anyone else seen this?
Stew
plugin appears to be successfully installed and enabled
Screen Shot 2020-07-23 at 9.20.57 AM.png (160.02 KiB) Viewed 3955 times
Its no longer an option and is greyed out.
Screen Shot 2020-07-23 at 9.20.38 AM.png (90.28 KiB) Viewed 3955 times
jalves
Re: Zwave Lock manager doesn't appear in plugin list
Post by jalves »
I just checked and mine is easily available.
Jeff
matt (support)
Post by matt (support) »
Try restarting the Indigo Server. If that doesn't help, then check the Event Log window for errors.
howartp
Post by howartp »
This sounds like one of those weird case-sensitive issues.
Is your copy of Mac configured with case sensitive hard drive?
matt (support)
Good catch – that is probably the problem.
stewkenly
Post by stewkenly »
Thanks for the replies.
HD is formatted as APFS Case sensitive, that hasn't changed though for years. What would cause this to suddenly stop working recently ?
Restarted Server
Jul 26, 2020 at 8:33:42 PM
Starting Indigo Server version 7.4.1 (Mac OS X 10.15.6)
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7.4/Databases/PrimroseLn.indiDb"
Waiting for client to connect
Bonjour registered "Indigo - PrimroseLn"
Indigo Cocoa client connected
Waiting for client to sync
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Loading disabled plugins
Found disabled plugin "Alexa-Hue Bridge 3.0.35"
Found disabled interface "INSTEON Commands 7.4.2"
Loading internal plugins
Loading interface "Z-Wave 7.4.1"
Starting interface "Z-Wave 7.4.1" (pid 1343)
Loading interface "Virtual Devices 7.4.1"
Starting interface "Virtual Devices 7.4.1" (pid 1344)
Loading plugin "Action Collection 7.4.1"
Starting plugin "Action Collection 7.4.1" (pid 1345)
Loading plugin "Timers and Pesters 7.4.1"
Starting plugin "Timers and Pesters 7.4.1" (pid 1346)
Loading plugin "Airfoil Pro 7.4.1"
Starting plugin "Airfoil Pro 7.4.1" (pid 1347)
Loading plugin "NOAA Weather 7.4.1"
Starting plugin "NOAA Weather 7.4.1" (pid 1348)
Loading plugin "iTunes 7.4.1"
Starting plugin "iTunes 7.4.1" (pid 1349)
Started interface "Virtual Devices 7.4.1"
Started plugin "Timers and Pesters 7.4.1"
Started plugin "NOAA Weather 7.4.1"
Started plugin "Action Collection 7.4.1"
Started plugin "Airfoil Pro 7.4.1"
Started plugin "iTunes 7.4.1"
Started interface "Z-Wave 7.4.1"
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem1A13201 (firmware 1.00)
Z-Wave found module included in controller with no matching device (missing or disabled): 020 - Relay Switch
Waiting for internal plugins to intialize
Loading external plugins
Loading plugin "uniFiAP 7.32.270"
Starting plugin "uniFiAP 7.32.270" (pid 1350)
Loading plugin "WeatherSnoop 3.1.0"
Starting plugin "WeatherSnoop 3.1.0" (pid 1351)
Loading plugin "UPS and Battery Monitor 1.0.4"
Starting plugin "UPS and Battery Monitor 1.0.4" (pid 1352)
Loading plugin "Pushover 1.5.3"
Starting plugin "Pushover 1.5.3" (pid 1353)
Loading plugin "Z-Wave Lock Manager 1.0.56"
Starting plugin "Z-Wave Lock Manager 1.0.56" (pid 1354)
Loading plugin "Cynical SecuritySpy 2.4.3"
Starting plugin "Cynical SecuritySpy 2.4.3" (pid 1355)
Loading plugin "Irrigation Caddy 1.0.1"
Starting plugin "Irrigation Caddy 1.0.1" (pid 1356)
Loading plugin "Ecobee 2 2.2.2"
Starting plugin "Ecobee 2 2.2.2" (pid 1357)
Started plugin "Z-Wave Lock Manager 1.0.56"
Started plugin "UPS and Battery Monitor 1.0.4"
Started plugin "Irrigation Caddy 1.0.1"
Started plugin "Pushover 1.5.3"
Started plugin "Ecobee 2 2.2.2"
Ecobee 2 Starting Ecobee
Ecobee 2 Ecobee Account: Starting EcobeeAccount Device 1500458014
Started plugin "WeatherSnoop 3.1.0"
Cynical SecuritySpy API version 2.3
Cynical SecuritySpy Python version 2.7.16.final.0
Started plugin "Cynical SecuritySpy 2.4.3"
Trigger Weather Wind Variable Update
uniFiAP initializing ...
uniFiAP path To files: =================
uniFiAP indigo /Library/Application Support/Perceptive Automation/
uniFiAP installFolder /Library/Application Support/Perceptive Automation/Indigo 7.4/
uniFiAP plugin.py /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
uniFiAP Plugin params /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/
uniFiAP Warning logger enabled for WARNING ==> TEST ONLY
uniFiAP Error logger enabled for ERROR ==> TEST ONLY
uniFiAP Critical Error logger enabled for CRITICAL ==> TEST ONLY
uniFiAP check /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log <<<< for detailed logging
uniFiAP Plugin short Name UniFi
uniFiAP my PID 1350
uniFiAP set params for indigo V 7.4
Started plugin "uniFiAP 7.32.270"
uniFiAP testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
uniFiAP myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log; debugLevel= []
Embedded script executor host1 started
Ecobee 2 Living Room Tstat: Starting EcobeeThermostat Device 621367522
Waiting for external plugins to intialize
uniFiAP start runConcurrentThread, initializing loop settings and threads ..
uniFiAP initialized ... looping
Starting triggers and schedules
Jul 26, 2020 at 8:34:25 PM
Trigger Weather Heatindex Variable Update
Trigger Weather Temp Variable Update
Embedded script executor host2 started
howartp
Post by howartp »
What files are in the plugin’s folder?
/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/ZwaveLockManager.indigoPlugin
Peter
stewkenly
Post by stewkenly »
Hi Peter,
Here's the listing of the plugin contents.
Stew
file list
file list
Screen Shot 2020-07-27 at 8.08.22 AM.png (409.25 KiB) Viewed 3790 times
howartp
Post by howartp »
Rename actions, devices, events and pluginConfig to Actions, Devices, Events and PluginConfig respectively.
I thought i'd fixed all my plugins to use the correct case-sensitive file names but it looks like i've not done Lock Manager.
As to why it's only just gone wrong, I can only presume an Apple OS update has only just kicked up a fuss about the case-sensitivity. It's something me and Matt have known about for a while (it rears it's head occasionally when new Indigo users discover they're using case-sensitive hard drive configuration , and i've historically used lower case names as is fairly (but not exclusively) typical in programming).
Peter
stewkenly
Post by stewkenly »
Ahh that works, thank you very much!
Stew
howartp
Post by howartp »
Excellent.
I’ll get a new version out sims time this week with it fixed properly.
Oerer
