ruvvitag https://ruuvi.com has a piece of hardware that fits well w pibeacon:
1. it sends an ibeacon message every second,
2. battery should last > 1 year
3. it sends as part of its message Temp, humidity, pressure (using BME280) and x,y,z acceleration ( gravity sensor)
With this beacon you can sense
1. presences
2. movement ( LIS2DH12 accelerometer)
3. environmental info (TPH using Bosch BME280)
The plugin offers 2 devices for each ruuvitag:
1. regular ibeacon. It will have regular signal, position.. as well as battery level info
2. sensor for TPH, acceleration in mg (1g= normal gravity)
it also calculates total acceleration (gravity sqrt(x*x+y*y+z*z)) and accelerationTurn (delta acc.%: ( |x-xlast|+|y-ylast|+|z-zlast|)/3*100): when you turn the device the total acceleration stays roughly constant while the acceleration_Turn info clearly shows a large change
How to setup
You get the MAC number of the device using the ruuvi tag station phone app.
show here also the option of having a color code for the state image, here for temperature. this does not work when you show more than one state in the state column (eg temp/humidity)
To add ibeacon type device you allow new sensors for 1 minute and pick the right one to keep: pick the right MAC number and the description field will show something like this "ruuviTag-xx:xx:xx:xx:xx-sensor" (xx:..=MAC number) (you could also just add an ibeacon device and add the mac number at the bottom of the edit screen, then you would need to to a manual push of config to the rpis, The TX- signal strength for distance calculation is ~ -63dBm (enter in the proper field in device edit)
To add the sensor device you add an indigo/pibeacon/ruuvitag device and enter the MAC number, configure some of the sensitivity parameters and which RPI should monitor the sensor, you could select all of them. Then save.
You then get the following states:
With a very long battery life and frequent updates this sensors can be used anywhere in the house ( < 30m distance tot the nearest RPI) - do not expose to rain! to
- measure temperature, humidity, air pressure with high accuracy
- movement / tilt sensor on doors - windows, fridge, dogs
- regular ibeacon presence
There is no config option for the device itself, just power on and it is ready.
THE ONLY BAD NEWS: it is not small. It fits in my pocket, but not everyone would accept the size.
You can only get it directly from ruuvitag in Finland (at least in the US). I got mine in 4 days.
pibeacon: 22 - BLE sensors
Re: pibeacon: 22 - Ruuvi Tag sensors
the is a posting on how to use the ruuvitag sensor for water level measurement, pretty cool.
http://mybeacons.info/swampFlood.html
Re: pibeacon: 22 - BLE sensors
iBS03-TP as pool thermometer. The device as a whole is IP67: "it has been tested to work for at least 30 minutes while under 15cm to 1m of water. "
1. oder a sensor / beacon @ eg[url]beaconzone.co.uk[/url]
2. open sensor; switch it on - tiny white lever; close it and tighten top/bottom part with the 2 small screws
3. in piBeacon plugin: menu/accept new beacons/ select "INGISCS iBSxx", after < 40 secs you should see a new beacon. Edit it & copy mac #
4. create new device: piBeacon / model=BLE-iBS03TP .. , give it a name, paste the MAC number from #3, select closest RPI to the pool. Set other parameters: if you like red/green/grey indicator and select ambient temp to be shown in status column
== that is all for indigo.
Physical setup
1. dump the sensor probe into liquid plastic and cover the screws and the edge where it holds together 2. use a spatular, heat it and "melt" /cut two plates of styrofoam (top and bottom) 10cmx10cm is large enough 3. Melt space for the sensor with the spatular in the bottom and top part. The sensor fit ~ 1/2 into the bottom part.. melt a hole into the bottom plate for the temperature probe 4. put everything together . You can use two small solid wires to hold top and bottom part together - poke the wires through the top and bottom plate and bend it around
5. curl up the long probe cable so that the sensor is ~ 20 -30 cm in the water. 6. let it swim, here shown w/o the top part You then should see the water temperature in the device state "AmbientTemperatur" (you can set that to be the value shown in the state column in device edit) it is updated every 30 secs
You can download the android ibs01 app and set the refresh timing parameter.
The other temp value is from within the sensor. It gives you the temp just above the water line, somewhere between air and water temperature.
device edit: devices states: I have compared it to the old rfxcom pool temp device and the temp values where < 0.2 C apart
Physical setup
BLE sensors supported
This class of sensors send BLE broadcasts with sensor data on a regular basis or when button is pressed or when sensor value change.
Some of them can also be used as iBeacons when they send a message often enough (eg ruuvuitag, iBSxx Minew)
The reaction time between button press and indigo device change is <0.4 secs
In general they do not use a lot of power = have a longer battery life
Vendor sensorName battery Freqquency Size App Type of Sensor ------------------------------------------------------------------------
Ibeacon On/off or ON Temp ExTemp Hum Press Accell/Grav IR Light GAS CO Smoke
ruuvi opensource sensor w BME280 and LIS2DH22 Acceleration sensor
ruuviTag 1x cr2450 1/1s largeRound ruuvi Y Y Y X,Y,Z
Govee Temp & humidity sensors, they broadcast T, H, BatteryLevel
- H5101 3x AAA 1/3sec w small display Y Y
- H5075 2x AAA 1/3sec w medium display Y Y
- H5177 1x cr2032 1/3sec w large display Y Y
- H5174 outside 3x AAA 1/3sec no display Y Y
Xiaomi MiJia
- LYWSDCGQ/01ZM 1x AAA 1/1s large Round display YES Y Y
- LYWSD03MMC 1x CR2032 1/2Min small Square display YES Y Y requires 2 BLE dongles, get data through GATT command
- VegTrug 1x CR2032 1/2Min YES Y Y Y + Moisture+Conductivity
Flower Care requires 2 BLE dongles, get data through GATT command
INGICS: All have battery voltage support in regular bluetooth message
iBS01 2x CR2032+USB 1/4s large flat IBS01 Button ON/off
iBS01G 2x CR2032+USB 1/4s large flat IBS01 Button ON/off movement ON/off
iBS01RG 2x CR2032+USB 3/s large flat IBS01 X,Y,Z
iBS01H 2x CR2032+USB 1/4s large flat IBS01 Magnetic ON/off
iBS01T 2x CR2032+USB 1/5s large flat IBS01 Y Y
iBS02IR2 2x CR2032+USB 1/10s large flat IBS01 present, short distance ON/off
iBS02IRPIR 2x CR2032+USB 1/10s large flat IBS01 movement PIR ON/off
iBS02M2 2x CR2032+USB 1/10s large flat IBS01 ExtContact ON/off
iBS03G 1x CR2450 1/5s squareThick IBS01 Movement ON/off
iBS03RG 1x CR2450 3/s squareThick IBS01 XYZ
iBS03T 1x CR2450 1/5s squareThick IBS01 Y
iBS03TP 1x CR2450 1/5s squareThick IBS01 Y Y water prove IP67
iBS04 1x CR2032 1/4s key remote IBS01 Button ON, not easy to press
Minew All have battery voltage support in regular bluetooth message
E8 1x CR2032 1/s XYZ
S1 1x CR2032 1/s Y Y Y
Kaipule - iSensor
EN61 AC 1/hour Y
ES62 3x AA 1/hour Y
EC50 2x AA 1/hour Y
EW70 1x CR2032 1/10Min round Water ON
ET90 1x CR2032 1/10Min/ValCHg round Y Y
IM21 1x CR2032 ovalSmall Mag ON/off
IM24 1x CR2032 oval Mag ON/off
IM22 1x CR2032 Long square Mag ON/off
IX30 1x CR2032 1/10Min Large movement PIR
IX32 1x CR2032 1/10Min Large movement PIR
RB50 1x CR2032 none buttonPress ON well done looks like a real door bell
RC10 1x CR2032 none 4 buttonPress ON well designed, easy to use
WeatherHawk, outdated
myBueT 1x CR2032 1/1Min oval small Y
Satech .. not recommended SOS button disables the device, needs a power cyle
AKMW not recommended, requires APP/GATT with long read times
