Changed IP for Hub, but bulbs keep old IP
sumocomputers
Post by sumocomputers »
I am running Hue Lights plugin 1.7.19 on Indigo 7.4 with Catalina.
I had to change the IP address of the Hub and changed that in the plugin configuration.
Old = 192.168.2.85
New = 192.168.20.85
Even though I can turn bulbs on and off fine, in the Indigo UI, each bulb still shows the old IP. See attached screenshots.
I rebooted the entire computer, as well as selected "Reload Hue Hub Config", but still showing the same.
I don't want to delete and re-add each device, since there are so many triggers, groups, and schedules that reference them.
Although this could be a cosmetic/UI issue, it sure pushes my OCD buttons...
Chris
nsheldon
Re: Changed IP for Hub, but bulbs keep old IP
Post by nsheldon »
Hi Chris.
Thanks for the report. The Address field is strictly a reference for users and doesn't actually affect operation (as you've noticed). That said, if we're going to have a reference in the Address field, it should be meaningful. I'll work on getting that corrected in a future version of the Hue Lights plugin. For now, though, you can either ignore the incorrect address, or re-define the device (by double-clicking it in Indigo, selecting a different Type from the pop-up menu then re-selecting Hue Lights as the Type and selecting the correct Model from the Model pop-up menu).
sumocomputers
The instructions worked perfectly. On a related side note:
If I need to factory reset the Hue Hub, will I be able to re-establish all the connections, without losing all the Indigo references to specific bulbs?
nsheldon
Post by nsheldon »
Great! I’m glad that workaround fixed it for you.
As for factory resetting the hub, there’s no easy way to retain Hue device associations with Indigo because a factory reset resets all the hub’ s internally assigned device IDs. If you have to factory reset the Hue bridge, you’ll have to go through the same reset process you just used to reset the Address value for every Hue Lights device in Indigo, except that you’ll need to set ALL Hue Lights devices to a different Type before setting the Type back to Hue Lights.
sumocomputers
nsheldon wrote:Great! I’m glad that workaround fixed it for you.
The process I just went through was not bad at all, so I am good with that. I am more concerned about all the triggers I have referencing various bulbs.
Am I correct in understanding I shouldn't have to touch these parts of Indigo?
nsheldon
Post by nsheldon »
Correct. If you use the device redefinition process above, you shouldn’t have to worry about triggers and other references to the Indigo devices.
Locked
Return to “Archives”
